Question about Hampton Bay Dryers
Why not turn the fan on high speed or because my fan does not turn. Is 54WDL Hampton Bay model.
    Genius:
  • Hampton Bay Master
  • 1,617 Answers
You should never have to use a fan on high speed inside the house unless it's a cheap store brand with no decent blade pitch.
Posted on Aug 02, 2013
4 Suggested Answers
SOURCE: broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
Posted on Jun 08, 2008
  • 10865 Answers
SOURCE: i bought a hampton bay ceiling fan model uc7083t but i didn't
hi there i can help. There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Posted on Jun 20, 2009
SOURCE: I can't find a replacement fan 3 speed switch for
Hi azwaverid!
I just had a similar problem with my ceiling fan, not sure if I have the same model as you (the fan was in the house when I bought it). I do have the exact same pull chain switch (K.T.E 2035080).
I went to a big home improvement store and the salesman gave me some 3-way switch and guaranteed it would work. The switch had only 3 wires, not 4 like the original. Can you guess what happened next? That's right, their part didn't work.
Being an engineer, I could not admit defeat. I consulted with other engineers I work with, and they pointed me to a "mom & pop" electronics store close to my house. I went to Centennial Electronics in Colorado Springs, CO. The sales staff didn't have experience with this problem, but at least helped me and offered suggestions.
I ended up buying a Philmore Pull Chain Switch for $2.51 after tax. This worked perfect! Just be sure to place the wires in the right slots. On my fan, the following positions and wire colors were: L - Orange, 1 - Yellow, 2 - Purple, and 3 - Blue (I just matched them up the same as the K.T.E. switch colors & positions).
Hope this helps!
Bob
P.s. The exact part I used was:
Philmore No. 30-9152 (UPC code: 0 38975 39152 6). The box says (everywhere you see a semi-colon is a line break): Philmore PULL CHAIN SWITCH; L-1-2-3, L-2-3, L-1-3, L-1-2, PUSH-IN TERMINAL; 6A-125V AC, 3A-250V AC; Made in Taiwan No. 30-9152; LKG Industries - Rockford, IL
Posted on Jul 09, 2010
How do I lubricate Hampton bay model 54wdl ceiling fan?
You don't! Throw it away and get a good fan, not a store brand.
Aug 13, 2015 | Hampton Bay Dryers
My Hampton Bay fan instlled on a slopped cielling on High speed I hear TIC TIC TIC when I rduce speed o MED no more TIC TIC what is the solution. Does the model 459-664 can it be installed on a sloppe
What do you expect to get from a store brand fan? They're cheaper because they use lower end parts. Always look for a fan with at least a 13 degree blade pitch for better air movement.
Mar 28, 2014 | Hampton Bay Dryers
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
EXCESSIVE FAN WOBBLE AT HIGH SPEED Hampton Bay Model Edisto 844 854
Two things you need to check: One or more of the fan blade irons may be loose or the ball on the end of the fan motor's mounting rod is not properly fitted into the ceiling-outlet bracket. If it only happens on high speed, I'm betting on the mounting rod ball not sitting in the ceiling bracket, properly.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 20, 2011 | Hampton Bay Heating & Cooling
Hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Oct 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
No middle speed.
Replacing the pull switch (reostat) should have solved your problem. Try going to the internet at www.google.com and in the Google search box enter "Hampton Bay Fans homepage". If any of these suggestions have been helpfull, please rate my solution. Thanks D. Lange
Jul 31, 2008 | Hampton Bay Sidewinder 04890 Ceiling Fan
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Dryers Logo
85 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
