Question about Canon PIXMA MP230 Multifunction color photo Inkjet Printer
When I turn my mp230 it just flashes the Green on buttom and goes back in forth with the orange triangle for 22 times and then it pauses in the Green light for a few seconds and it repeats itself
The purpose of writing this letter is to inform you that my machine got some technical problem.
We unable to solve this problem since last year.My machine is Konica R1 DP-1000E. And the machine always show the words "The machine error printer no: err-D1301-0 link with processor failed." We are here request for your technical help
If possible, please contact my cellphone +673 8896003.
Posted on Aug 02, 2013
I also have this problem, with the orange triangle flashing 22 times
Posted on Nov 09, 2013
4 Suggested Answers
envision507
  • 30 Answers
SOURCE: The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Posted on Sep 07, 2009
JackHeath
  • 1049 Answers
SOURCE: Pixma 4500
12 times is listed an AP position error:
Carefully slide and top covers off to reveal the print head. There is a device that slides back n forth and acts like a window cleaner squeegie on the printhead. This mechanism is probably stuck at its full extention rather than being back at home base. Every time you turn it on and off you should see it try to move but it will seem to be stuck. Give it a little assistance and that should release it. It can get glued up with drying ink. The mechanism that drives the sliding squeegee relies on a spring for it to return and the spring isn't strong, so the whole thing jams up...
which is probably what the code means - jammed mechanism.
Posted on Mar 08, 2010
SOURCE: flashing orange light 5 times followed by green
I am also having this problem, would love someone to give us a solution before I through it out the window.....
Posted on May 30, 2010
Green orange then red flashing 3 times light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 04, 2014 | Televison & Video
Canon Pixma MP230 flashes green and orange alternately 3 times. What should I do ?
guys is it possible that these LEDs can also indicate that the catridges are drying up??
Feb 03, 2013 | Office Equipment & Supplies
Pixma 4500 Alternate green orange lights flashing Green Orange repeats 12 times pause then cycle starts. Tried unplugging power cable and replugging. Rang Canon tech: no use. Couldn't even tell me what...
Mar 08, 2010 | Canon Pixma iP4500 InkJet Printer
The light first flashed orange causing printer to pause printing. After restarting the machine and printer several times, it is constantly flashing green. printer did not initiALISE.
The light flashing orange or green could mean a couple of things. First could mean that the paper size that you are using is not the same that you have configured on the printer or the paper size that you have selected on your software is not the same as the one configured in the printer. Also it could be a message of the toner low. You can try resetting he printer to factory defaults. Turn Printer off and open the front cover. Then Press and hold the Button with the Triangle and the Cancel Button the one with the X and turn the printer back on. You will have to keep the buttons pressed until the exclamation light comes up solid then release the two buttons and close the cover. That should reset the printer to factory Defaults.
Dec 15, 2009 | Lexmark E120n Laser Printer
My printer flash green then oranfe and again and
5 times says the feed roller is not turning properly, sometimes the gears break and other times something falls in the back and stops the roller from turning. It's a different error if the orange flashes 5 times, or if it flashes orange and green 5 times.
Sep 01, 2009 | Canon BubbleJet i560 InkJet Printer
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
Canon ip1300. Three orange flashes, one green.
Hi emdos,
Did you mean blinking three times in Orange?. Well, the problem is paper jam error occurs in your printer. First, check if any broken paper inside printer. If it so, remove broken paper. If problem still persist, it seems that drive assy broken or paper feed sensor fault. Find more useful article about this below.
Soruce:
Canon Inkjet Printer Forum
Nov 26, 2008 | Office Equipment & Supplies
Orange lights (3)
Three orange flashes between green indicates a paper jam on this model. Look closely in the paper feed area and the paper exit area for any torn scraps of paper. Also open the top and check in the platen area (where the print head moves back and forth). If you don't see anything, it's possible that a sensor has broken or gone bad.
Jun 11, 2008 | Canon BJC 3000 InkJet Printer
Canon i250 flashing orange / green light
turn the printer off by the socket. hold down the on button and keep held down whilst turning on the socket switch. Then press the button next to the on (i don't know what it is called) , so it goes onto orange then again to get to green. now it should stay on green and print. i hope this i useful
Feb 17, 2008 | Canon i250 InkJet Printer
Need help with S-400 Canon
How many times from pause to pause?
May 13, 2007 | Canon S400 InkJet Printer
Canon PIXMA MP230 Multifunction color photo Inkjet Printer Logo
842 people viewed this question
old marine
old marine
