Question about Drills
Dewalt hammer drill dw511 makes grinding noise on
Dewalt hammer drill dw511 makes grinding noise on hammer and drill settings.
2 Suggested Answers
emissionwiz
  • 76649 Answers
SOURCE: Dewalt dw511 hammer drill won't hammer, only
The hammer inside the drill head are most likely damaged ans/or broken, it is likely the best thing to do is just replace the tool.
Posted on Feb 16, 2012
Drill slips when in forward drill mode, sounds like a gear is grinding on another gear. Does not slip in reverse or in hammer mode.
Dewalt XRP drill gearbox - YouTube
? 3:16
https://www.youtube.com/watch?v=s262yXyUYD4
Nov 23, 2011 - Uploaded by Ultimate Handyman
This is extremely useful if the gearbox on your drill is damage... ... i was using my dewalt hammer drill in the drill mode and suddenly got slower i though the battery was running out. as i ...Looking forward to the repair video.
Nov 22, 2015 | Drills
Dewalt hammer drill chuck won't turn model DCD985
Make sure the speed selector lever on the top of the tool is all the way in gear, and the dial selector on the tool is in drill or hammer drill mode. If in screw mode make sure it's set to a level that it won't "clutch" out.
Feb 17, 2015 | Dewalt Drills
How do I connect the chuck key to the chuck key holder on the DW235G drill?
Easiest is to tape the chuck on the cord about 18" away from the plug, this way-for safety reasons, you should disconnect it before making adjustments (with the chuck in hand and you accidentally pull the trigger and bad things can happen.)
Aug 27, 2013 | Dewalt 1/2 Hammer Drill DW511
Feb 15, 2012 | Dewalt Drills
When i drill with my 18volt cordless, and the bit catches it makes an awful grinding noise inside the drill, its not the adjustable clutch set low. its set on drill?
Your speed switch is between gears, pull the trigger lightly and slide the speed switch back and fourth until it is fully engaged. Also turn the clutch setting all the way down then all the way back to lock it is not uncommon for them to get dodgy.
Cheers,
Kevin
Mar 23, 2010 | Dewalt DC6PAKRA Heavy Duty Xrp 18volt...
Chuck is locked open
you have three jaws in your chuck, one of them will probably have a small burr on it causing it to stick.
try this...
tap the chuck with a small hammer then try to use the chuck key gently in the opposite key hole to the hammer blows. turn chuck though 120degrees and repeat.
if this does not work chucks are fairly universal and easily replaced (i would recommend a keyless jacobs). you can get the old one off by removing the ph2 (phillips) machine screw inside the centre of the chuck... be careful!! this screw is usually soft and counter threaded... when screw removed bash off the chuck with a hammer and cold chisel...
good luck
Oct 23, 2009 | Dewalt 1/2 Hammer Drill DW511
Strange wurring sound and slight vibration at full speed Dewalt sds hammer drill dw25003.
On most sds drills the movement of the beat piece inside the piston cause then to vibrate, even at slow speed, this is normal, the most speed the louder the noise and vibration., note: is not a grinding noise, it should be a smooth nocking constant sound, as so the vibration.
Aug 07, 2009 | Dewalt Drills
Replaceing chuck on a Dewalt Dw511 1/2" hammer drill.
Open the chuck jaws and you will see a screw in the center of chuck, it is left hand thread. remove it and use a large bent handle allen wrench putting the short portion in the jaws and tightening. Shift the drill to the low position and have the clutch in the drill only position. place the handle of the wrench at about a 30 degree angle to strike it counterclockwise. put the chuck on a block of wood or workbench and hit it, this might take a couple times but it will come off. Let me know if you still need help
Mar 09, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 volt cordless hammer drill
You should try to charge the battery again. Or you can try to fix it or then its time to get a new battery.
May 10, 2008 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
57 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
