Question about Yamaha RXV471
Push power button and unit came on and went off. Now nothing happens when you push power on button
3 Suggested Answers
agent91
  • 2100 Answers
SOURCE: Push statrer button and nothing happens
Sounds like too much oil! Yeah it sounds like a switch. You can probably get that thing apart and see what's happening. Have you ridden in the rain lately or trailered it through heave rain? I trailered my Ducati through some heavy rain in North Carolina and washed all the grease out of the throttle, wouldn't even turn. I have a feeling, you have corroded the connection some how, check it out.
Posted on May 31, 2010
SOURCE: 2006 yamaha bruin will not start by push button. Battery is fine, all lights come on but when button is pushed nothing happens
Hi. Depending on your skill level the starting point would be check "ALL" the fuses with a test light/multimeter. Next point would probably be check the starter itself, Again with a test light or multimeter you should have the main positive to the starter - make sure you have good battery voltage and check this whilst attempting to crank. Then the crank feed itself which is the small wire to the starter solenoid, Again check for good voltage whilst attempting to crank. If there is voltage on both then make sure the starter has a good earth by using the starter motor body as the earth whilst testing the main feed at the starter. If you have good main feed and crank the starter has failed. If not you need to post your test results for further help, Jon
Posted on Dec 09, 2013
Testimonial: "Thanks, I will try this."
Nothing happens when I push the power button on the front panel of NAD917 Preamp. Any idea why? Is there a way to reset the box?
Probably a fuse in the unit. Unplug it and open it. If you see a blown fuse, take it out and look at the writing on the metal part. buy a fuse with the same power ratings.
Apr 11, 2016 | NAD Audio Players & Recorders
Nothing happens when push start button. power cord etc good ??? is this a power unit failure?
make sure the outlet is recieving power
unplug the tower from the outlet & then replug it in & see what happens
make sure all cords are plugged in correctly in the back of the tower
then if nothing happens after you push the start button, power supply & cord could be bad
the same thing happened to my daughter's pc & had to replace power supply & shorted out the motherboard
Nov 18, 2010 | HP Compaq Presario SR2050NX PC Desktop
Power button problem
i think that the power cable went fastly try replacing it
Jun 07, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
My big screen tv went off and reset it but you push the button and the power comes on and goes right back off
when we push power button the green light flashes as if thinking about turning on and nothing happens, any way to fix this?
Feb 18, 2008 | Televison & Video
Power cuts out on PT-53WX42
unplug tv check the fuse and the rating on it,.see if filament inside is burnt
Oct 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
TV wont turn on
just throw it out and never buy a sony again. Sony really went down hill
May 01, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Yamaha RXV471 Logo
35 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
