Question about Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT
FL code with Great Lakes spa ...Pumps won't run and tub is cold... light won't even come on.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
FL code is because no flow from pumps check to see if recirculation pump fuse is ok
Posted on Nov 02, 2014
2 Suggested Answers
Ian  Hot Tub
  • 77 Answers
SOURCE: FL code on a Great lakes spa I have turned of
'Fl' means that there's insufficient flow of water through the heater, or non at all.
1) Check the water level - top up if low.
2) Ensure that all jets are open and flow water - if they don't you may have a pump issue.
3) Remove the filter(s) and see whether or not this clears the fault, if so clean or replace the filters.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 17, 2010
I have a great Lakes Spas with two pumps. The first one works, but the second one will not come on. Could it be the switch or something else? Nothing happens when I hit the switch.
The pump might need to be serviced, look at the pump for water damage that's a sign it needs repair= bearing and a shaft seal can spark it back to life. and if you are handy you can check the power going to this motor.
Jay the pool pump repair guy longwood fl
Jun 30, 2017 | Great Lakes Spas Pool & Spa
F2 error code 2004
Balboa Direct has an excellent error code listing on their site.
Mar 29, 2014 | Pool & Spa
Great lakes hot tub
Normally f2 is not an error code.
It is informing you that you are in a "Filtration" mode. In this case Filter Mode #2
But, if we knew what make & model of the control system you have, will assist us better in helping you. Spa manufacturers normally do not use their own proprietary control systems. They will use a 3rd party vendors unit & install them on their spa.
Drained my 2000 Great Lakes Spa now OH is displayed when I turn up the heat it kicks out the breaker..
OH is overheat due to insufficient water flow through the heater.
Common Causes:
  • Gate valves not opened/partially closed.
  • Air trapped in suction lines or pump
  • Blocked suction fitting
  • Dirty filter
  • Restricted water discharge lines
Try remove filter cartridge and run spa.
Check pressure switch for continuity.
Unplug & plug hi limit sensor.
Oct 14, 2012 | Qca Spas Majestic Series Aruba Xl Hot Tub
FL code on a Great lakes spa I have turned of power twice code still there also the the water is warm
Regards,
Ian.
Mar 02, 2010 | Jandy Laars Lite2 Pool & Spa Heater -...
I have a 2004 great lakes hot tub with a balboa controler. My hot tub heats up fine when the pump runs on high but the temp light never comes on when the pump runs in low.
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Feb 04, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Reset error code hot tub
tub is in sleep mode usually to change u must press temp button then light button you want to b on standard mode STD
Oct 04, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT Logo
181 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
