Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
I have a F&P Washing Machine (Eco Intuitive) that is displaying code 105. The water has drained out of the tub but, it has not spun. When I try to turn if off it automatically turns itself on again, beeps and displays the 105 code. This machine has never been repaired. Can you help?
  • Sheid Aug 02, 2013
    Thanks Ian Greenland! Yes, it was the pump. I found a really good UTube on how to remove the pump and it is all fixed now.
  • Fisher and P... Expert
  • 554 Answers
That good you got it working,
If you ever need Fault codes for F&P machines i have them.
Posted on Dec 17, 2013
2 Suggested Answers
  • 351 Answers
SOURCE: fisher and paykel intuitive Eco. FAULT 136
blocked pump scoop the water out and remove pump from underneath just clicks out move the white plastic clip
Posted on Mar 03, 2008
Hi i have a fisher & Paykal IW812 Intuitive Eco washing machine it gets to the rinse drains a little water then nothing happens time still counts down but nothing happening gets to the spin cycle then...
Hi just read your posting.Unless the machine shows an error code the diagnostic mode will not help.Does the machine agitate in the wash cycle?Does the machine drain the water completely?Does the machine spin the clothes dry.Please reply with additional information on the questions I have posted and I am sure I can help you rectify this fault.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Water sensing level not working on Fisher & Paykel Eco Intuitive washing machine . The water just keeps filling up until I stop it manually . We can't use the machine to wash clothes as the Service...
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
May 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
I have a fisher & paykel intuitive eco and on the display screen it reads needs a service code 37 ?
Hello, It sounds like you have a restricted or blocked drain pump. This usually occurs in the outlet of the pump between the pump and the diverter valve. 1st check that the drain hose is not kinked or crushed and does not have too long of an extension on it. If the tub did not drain you will have to bail or otherwise remove the water. Of course unplug the machine before any service. Once that is done, lean the machine backward the drain pump is located under the machine on the right side close to you. unplug the wires to the pump and remove the pump by lifting the small plastic catch and turning the pump assembly a quarter turn counterclockwise. Next disconnect the pump from the hose to the diverter valve. you can also remove the pump hose from the diverter valve and check to see if anything is caught in the valve. That's really all there is to the drain system. Good Luck.
Mar 12, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
What is code 105
Error code 105 means you have a Comms. Error Time out. This means there is a communications error between the display module and the motor controller.Now have you replaced a part in the machine recently?Just looked in my manual and it also says, to rectify this fault you might need to replace the rotor sensor on the motor.Please reply and tell me if the machine became faulty or a part was changed for another fault and then Error 105 started appearing in the display.Hope to hear from you soon.
Jun 04, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Code 49
it probably Needs a new cold water solenoid valve.
Sep 02, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher&Paykel Intuitive Eco 'Help, I need water'
If the water is coming into the machine in spurts, you may have a problem with the out of balance switch but it's very difficult to determine by your description & also without knowing the model number. The manufacturers call center is open 24/7 if you want to call them - you can get a number for a repair guy too from them.
Sep 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Error codes
We have an instruction manual but there are no codes.
Apr 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Thanks for you help in fixing our washer. I printed your instructions which my husband Charlie found easy to follow and like you, he freed from the pump two bits of toothpicks and a little cellophane....
Hi there
We have a washing machine model IW810AU and is coming up with code 105 and have phoned and they have said it has to have a technician to to fix it we are hoping that you can help us with this and I can cancel technician coming out and save ourselves some money this was an expensive machine when purchased and dont feel we should have to spend money on a technician so if you can help would be greatly appreciated.
Mar 28, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
366 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
