Question about Cub Cadet SLT1054 54 in. 26 HP Kohler V-Twin Hydrostatic Front-Engine Riding Mower
Still working on a fix for my cub cadet lawn tractor. Starts and runs for a few seconds then quits. I am wondering if this symtom fits a carbuerator solenoid that isn't working. The solenoid clicks once when I put 12v on it but doesn't pulsate. does the solenoid get activate the same time as the spark plug to make it open and close or does it get steady power and should pulse on its own?
    New Friend:
  • 32 Answers
If your talking about the solenoid sticking out the bottom of the fuel bowl that is just the fuel shutoff solenoid. when you turn key on that gets 12v hot all the time your running. when you turn off mower the solenoid extends outward inside the bowl to shutoff fuel going up to the venturi. if you take the bowl off and hold it against metal for ground you can watch the solenoid pull inward when you turn key on and outward when key off.
Posted on May 17, 2014
Testimonial: "Turns out the solenoid was only getting 9 volts of power. I re routed to a different spot and it works fine. Thanks for the help!"
3 Suggested Answers
  • 6468 Answers
SOURCE: Does a Cub Cadet Model 1170 lawn tractor charge it's battery ?
when a engine has factory electric start it will have a charging system but it is only a couple amps keep in mind a small mower battery is only good for a couple years
Posted on May 14, 2012
SOURCE: 2004 cub cadet starts and runs when jumped once turned off doesn't restart
it could be a dead battery
Posted on Mar 03, 2013
Need diagram to replace belt on cub cadet mower
Hi there r photos on how to fit the belt. Type in Google. cub cadet mower photo of belt. There r also movies on YouTube how to fit belt. Type in how to change the PTO belt on ? cub cadet , good luck
Apr 20, 2016 | Cub Cadet Street Sign- tractor lawn riding...
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
Will a model OEM 190-621 snowblower fit on a cub cadet LT 1024
Have you tried the cub cadet forum? If not, give it a click:
http://onlycubcadets.net/forum/forumdisplay.php?f=42
Nov 21, 2014 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Cub cadet starts and then quits
you should see some gas in filter no usually full though
Jul 27, 2013 | Cub Cadet Garden
Cub cadet RZT 22 starts but dies after a few seconds
Sounds like a fuel starvation problem to me the carbitrator need cleaning and inspecting for a blocked jet if there's is a jet blocked the an ultra sonic carberetor clean and service is required
Apr 20, 2013 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet model 12A-18M7010 will not start. It has an automatic choke. No primer. I've changed the gas, checked the plug, cleaned the carbuerator. What could it be?
Also check the air filter. Some times if the paper filter is wet or clogged it will choke out the machine by not allowing air in to the ignition chamber.
Apr 17, 2013 | Cub Cadet Garden
Riding lawnmower starts but will not continue stay running?
its probably in your ingnition switch, grab the switch and turn it right the turn key I had the same problem and that fixed it. It also wasnt starting and it was the same problem the switch is lose.
May 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet SLT1054 54 in. 26 HP Kohler V-Twin Hydrostatic Front-Engine Riding Mower Logo
83 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
