Question about LG LWD3081ST Electric Double Oven
F9 error on lg double wall oven, lower oven works fine but upper oven does not heat. Initial I was able to use the upper oven as long as it wasnt on bake now it doesnt work at all. I was going to replace the thermostat...any suggestions
2 Suggested Answers
some1cares_m
  • 5323 Answers
SOURCE: My lg convection oven works fine in microwaveode but in convection mode things don't get baked properly...what could b the problem? Pls help
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advice bcuz God is so good!
Posted on May 18, 2015
Whirlpool gbd307 why will The upper oven not work but the lower oven works
Have you checked the heating element supply voltage with a VOM? And have you checked for a popped/burned fuse to the bake element?
Aug 06, 2014 | Whirlpool GBD307PDS Electric Double Oven
Jtp45 lower oven hot heating on any cycle
Possibly a tripped thermal fuse. Should be located behind the panel in between the upper and lower ovens. Might have a red reset button on it you can push down. If it clicks and then works again, look for possible cooling fan problems.
May 12, 2014 | GE JTP45 Electric Double Oven
Error f19
Error code F-19 means "Lower oven is not heating".
The manual suggests:
"Press UPPER CLEAR/OFF or
LOWER CLEAR/OFF to clear the display
and stop beeping. Reprogram oven. If fault
reoccurs, record fault number. Press UPPER
CLEAR/OFF or LOWER CLEAR/OFF and
contact a qualified service technician."
May 04, 2014 | LG LWD3081ST Electric Double Oven
Hotpoint 24in double electric wall oven 20RJ83D not heating, element is working
The thermostat for the upper element has gone bad. Needs to be replaced.
Apr 15, 2017 | Ovens
F19 error code on lg double oven
had F19 error code on lower oven, F9 on upper. Pulled stove out and turned the regulator switch ON. Worked instantly. I thought I had the regulator on because the stovetop worked. The stovetop regulator is separate from the main regulator!!
Jun 22, 2011 | LG LWD3081ST Electric Double Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
GE Double Oven JKP45BA, lower oven wont heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jul 30, 2007 | GE JTP48 Electric Double Oven
Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Nov 17, 2006 | GE Profile JTP56 Electric Double Oven
LG LWD3081ST Electric Double Oven Logo
32 people viewed this question
Top LG Ovens Experts
Coss
Mike Carew
Are you a LG Oven Expert? Answer questions, earn points and help others
