Question about HTC Inspire 4G Smartphone
Battery is fully charged but phone wont start up
  • 1,800 Answers
Try to using a fin sandpaper to scratch a bit the battery receptors on the phone.
Posted on Aug 02, 2013
2 Suggested Answers
SOURCE: My battery is fully charged but my phone wont turn
I can tell you if your battery is an aftermarket one they tend to stop working after a short tim. Either they stop working in the charger or they wont make the correct connection in order to power up. the may be the problem even if its an HTC battery. I have two batteries right now that are fully charged but wont turn on the phone. this is not uncommon for this to happen with lithiem batteries.
Posted on Oct 16, 2011
Blackberry 9720 suddenly went dead wont charge
Hi Michelle. I have the same phone and it happened to me a few times. On most phones the battery swells up when it reaches it's charging life end. In the 9720 the battery can still LOOK okay even though it might have reached its life-span. I eventually purchased a new battery, and wholaa, problem solved. A piece of additional advice is: Do not chat with you phone on the charger. Unplug the charger when battery is fully charged: We tend to charge the phone anytime and every time before we go to work or somewhere - you have to let the battery run flat on its own at least once a month, then start a fresh charge from fully flat to fully charged. This will prolong battery life. I a new battery does not solve the problem, have the charging pin checked out. Alternately if you know someone that has the same handset as you, ask them to stick your battery into their handset and visa versa. Hope this info help :)
Aug 26, 2014 | Blackberry 9720 Smartphone White, Factory...
My phone keeps shutting on and off and wont charge when plugged in
Cell phone batteries have what is called a "memory" over time if they are charged without being fully drained they can start to not hold a charge. Unfortunetly the only fix for an issue like yours is to purchase a new battery. Your local retailer / service provider should have batteries in stock or they can order one for you.
It is recommended to allow the batteries to drain completely before charging, then allow at least 8 hours or more to fully charge. Most cell phone will show a full charge after a few hours, but this is more a fault with the software that check the batteries charge, then an actual indication of the battery being fully charged.
Dec 28, 2013 | Samsung Galaxy Admire 4G MetroPCS
Not starting up
hello there!
so you're phone won't charge up...you should buy a new battery...your old battery is not functioning well...
tip:
don't use the phone while charging. let it be fully charge before using it again. and don't let it to overcharge too. this will reduce the life span of the battery.
Thank you for choosing fixya and kindly rate this post.
Dec 30, 2011 | Sony Ericsson Cell Phones
My battery is fully charged but my phone wont turn on
Oct 14, 2011 | HTC EVO 4G Smartphone
Bought my phone yesterday...Battery was losing charge quickly.. battery was down to half charge after about 15 minutes of fully charging.. Was trying to let the phone die completley then fully charge it,...
Ok first of all you should never let a phone die out of charge at all.IF it dies out of charge there are chances it might charge again once you charge it but in some cases it wont, you need to boost your battery just like jump start your car.It cannot be done anywhere except some service centre. If you are not taking to your service center , then you need to buy a new battery.
Oct 08, 2009 | Cell Phones
My jank phone, incapable of charging, turned off and wont turn on
As the phone keeps turning on off there is some loose contacts or some dirt is there at battery terminals try cleaning phone and battery contact terminals
Jul 21, 2009 | LG VX5200 Cellular Phone
Phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
Aug 08, 2008 | Sony Ericsson K600i Cellular Phone
Phone is dead wont take charge
You simply need a new battery. Razr batteries are notorious for loosing life and the entire problem is the chargers you are using. You MUST have one with an IC chip that tells it when to stop charging otherwise watch how long you are charging it. Also when you have a new battery let it fully charge and fully die twice before you start normal charging this helps a lot.
Feb 24, 2007 | Motorola Mobility RAZR V3
HTC Inspire 4G Smartphone Logo
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
