Question about Health & Beauty
When I turn on the key for a Lark mobility scooter it beeps three times every four seconds. How can I make it work?
4 Suggested Answers
gewiz
  • 1263 Answers
SOURCE: pride mobility scooter. turn key on it keeps
Are you sure that it not in FREEWHELL mode, lever at the back, Regards
Posted on Jun 13, 2009
  • 177 Answers
SOURCE: Scooter just beeps when key turned
Hi. That fault is the speed lever. It can also be the small dial that alters your top speed. It pays to replace both of these at the same time. Some of these machines also develope the same fault from a faulty controller. Good luck. Neil.
Posted on May 28, 2010
ginko
  • 19396 Answers
SOURCE: Scooter with fully charged battery
Hi.
Seven beeps means faulty Throttle potentiometer or speed potentiometer fault. If using contact cleaner is not enough, that means that the faulty part must be replaced. The potentiometer is tested reading Ohms with a multimeter. Touch its contacts with multimeter probe set on Ohms while using the accelerator at the same time.Contact your authorized Pride Provider to get replacement part or to get a quote on repair.
Posted on Sep 05, 2010
Looking for info on Lark 4 (user manual)
regrettably this is the only thing I can find. I can't even find the manufacturer website!
http://www.usatechguide.org/itemreview.php?itemid=996
you could ask here on the contact page.
http://www.wheelchairs-guide.com/lark-mobility-scooter
Jan 24, 2016 | Health & Beauty
Why does it beep five times when key is turned on and controls won't work
hi, the 5 bleeps are related to the brake,,, located at the rear of the scooter located on the side of the motor, attached to that is the free wheel lever,, in drive mode ,, check that the microswitch is working correctly, check the wire( connectors etc ) from the brake to the controller ,
www.facebook.com/gewizrepairs
Aug 07, 2014 | Pride Mobility Products GoGo Elite...
What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
Mobility scooter
Check the freewheel lever is not engaged.
Jun 03, 2017 | Health & Beauty
Hi there my mother has a lark 4 plus mobility scooter she lost her key to it so I brought a new key and barrel took it apart to repair and brought the wrong barrel so brought a new I'm the mean time of...
Hello,try visiting the scooter website to see if you can view the item as a PDF File on an Adobe Reader.Or type the exact name of the part into your brouser & see what you find.I say take a pic of anything before you take apart,then you have something to relay back to.Colin
Mar 07, 2013 | Health & Beauty
I have a gogo three wheeler and some times when i turn on the switch the scooter will not move, but when i turn the switch off and on two or three times it will work and some times the horn will start...
The go go controller has a controller which will give you a specific beep code to indicate the problem with your scooter. From what you are describing, it seems that the throttle potentiometer is out of neutral at start-up. The controller needs to electrically sense the throttle pot is in neutral (center of left and right) to start. By turning the scooter on and off you are jiggling the pot enough to get it to zero out(go to neutral).
Please get back to me with the exact model of the go go and with the exact number of beeps in the error code and I will be able to diagnose the problem in a more definitive way.
The most common error codes involve the throttle pot out of neutral at start-up and the brake freewheel lever is in freewheel.
You can see if the throttle pot is out of neutral by moving it slightly in either direction with one hand and turning the scooter off and on with the other hand. If the scooter works by this slight adjustment of the pot, then this part needs to be replaced. Hope this helps.
Jan 30, 2011 | Electric Mobility 3 Wheel Motorized...
Intermittent loss of mobility, get beep beep sound
I sounds like the switch is not making contact relieably. Make sure your key is clean and if that does not work, than the switch inside the console will need to be replaced. Contact Pride Mobility for a technician local to you.
Nov 12, 2008 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
