Question about Radio Communications
Technika TDX8SS is supposed to be fully integrated but how do you take door off to add a kitchen panel to it
2 Suggested Answers
  • 12 Answers
SOURCE: Hello. Can i put
Yes but it must be a material that is made to withstand the heat dont cover any vents or spaces around the dishlex
Posted on Nov 09, 2008
Hi, this is an integrated dishwasher and with the kitchen door attached won't open fully.
Maria, adding the door to the front of machine has increased over all thickness to what was existing, washer was not designed for the extra thickness and will catch on lower part of washer.
You may have a few choices, shorten added door panel, taper bottom of panel to allow operation, or remove added panel.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 04, 2016 | Dishwashers
My frigidaire gallery french door with ice maker is making a knocking noise every 5 seconds. Sounds like from the ice maker. How do I fix or stop the noise.
I have a different type. I rubber banded the little ARM in the UP position ( to fool the unit that I have enough ice). NO MORE SOUND>>
Jun 03, 2015 | Frigidaire FGHB2866PF3PCKIT Gallery...
How dismantle oven door to clean between glass panels?
The glass is a supposedly sealed unit that should not be removed for maintenance. This is a common failing of ovens with glass panels.
Mar 03, 2013 | Jenn-Air JGS8860BDP Stainless Steel Gas...
I cleaned my technika stove and now there's no gas coming out it won't ignite even with the use of matches , there is a spark but it won't fully work
If no gas is coming out then the nipple from where the gas is released in the burner is choked due to oversight while cleaning. You may try opening the same as it is screwed onto the stove and open the little hole in the middle of the nipple with the help of a thin needle or a thin steel wire and then blow into it to make sure that it is open.
Apr 05, 2012 | Kitchen Ranges
Amana range model 770M door won't fully close
Is the door hitting the door lock hook. Or a strike pin hitting the inside door panel. If this is a self cleaning range the door seal is a metal mesh and does hold the door slightly away, this is normal. More info ?
Sep 01, 2009 | Amana ACF4215 Electric Kitchen Range
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
Hidden control panel not accessible on dishwasher
no thats correct installeation of machine, its meant to be a "hidden" control. simply open the door, choose your options, press start and close door.
Feb 28, 2008 | Dishwashers
Door lock does not engage for self-cleaning
when the oven is in clean the door is supposed to lock. if not the panel will show the word door. its sounds like the door is not locking, and you need to replace your door lock mechenism.
Jan 23, 2007 | Thermador RDDS30 Dual Fuel (Electric and...
Radio Communications Logo
81 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
