Question about Craftmade International Craftmade Constantina in Antique White with Standard 3 Speed Pull Chain Fan
I have a similar fan to this one. Mine is 10 years old and has another bowl type light underneath. The up light started flashing and I couldn't shut it off. I replaced the batteries in the remote. Worked for a while. Now when fan is turned on the up light buzzes and flashes. Help.
    Genius:
  • Craftmade In... Master
  • 1,617 Answers
Probably needs a new receiver.
Posted on Aug 02, 2013
Truck will start but engine dies and service engine soon light comes on/truck was idleing fine for 10 minutes then began to hesitate then shut off when first happened
When the engine dies the Check eng light is supposed to come on. You need to do a fault code test on the OBD2 engine control module.
Jul 07, 2017 | Cars & Trucks
Security light is flashing. car will not start on my 2003 oldsmobile alero
I OWN a 2001 Olds Alero and the same thing happens to mine.. It's an easy fix..
1. Turn the Key to ACC (keep it in this mode for the entire 10 minutes).
2. The security light on the Dashboard will flash for exactly 10 minutes..
3. Once the 10 mins are over, the security light will stay solid..
Wait for the red light to disappear off the dashboard...
YOU ARE NOW READY TO TURN YOUR CAR OFF AND RESTART YOU CAR....
SIMPLE FIX..
I DO THIS ALL THE TIME TO MINE..
Nov 06, 2012 | 2003 Oldsmobile Alero
What is the recommended ball weight for a 10 Year old girl?
For children the ball weight should be similar to the age,so for a 10 years old girl, you should take a 10lb ball. For more info aboutweight and age, use this link: http://www.bowlingball.com/info/ball_weight.html
Jul 09, 2012 | Sport & Outdoor - Others
How do u change fuel filter on a 1997 F-350 powerstroke ?
1 Open lid/remove plastic cover over fuel bowl .
2. Open drain valve (to the left side at the bottom of the bowl) by pushing it to the left (back of the truck). You may want to attach a piece of 5/16" hose to the bottom of the drain so you can avoid a mess.
3. Unscrew the fuel bowl lid. You may need to use tools to loosen the lid, but I can usually get mine by hand. If u need to u can use a 1/2" drive ratchet to loosen the lid.
4. Remove the old fuel filter and o-ring (from the lid).
5. Close the drain valve on the fuel bowl.
6.This is optional. Fill the fuel bowl about 1/2 way with Standyne Lubricity Formula or a similar product.
7. Install the new o-ring on the lid making sure to follow the instructions for the beveled edge. Lightly coat the new o-ring with fresh diesel fuel.
8. Attach the new fuel filter to the lid.
9. Install the new filter/lid and make sure it is on straight and snug, do not over tighten!
10. Turn the key and wait for at least 10 seconds, especially if you didn't add any additive to the fuel bowl. This will allow the fuel bowl to fill before you start the engine.
You can use filters that come attached to the lid, but don't throw your lid away. You may need it if you go back to the other style filter...
That's it...your done. Hope this helps FixYa.
Jun 29, 2011 | Ford F-350 Cars & Trucks
My refrigerator is not pumping water through the door. It is making ice properly. What would cause that? Thanks GE GSL25JFPR BS
If this is a newer fridge, less than 10 years old, the problem likely lies within the freezer door itself. Underneath the freezer door, behind the toe plate, is a water line union, either a screw in type, or blue, push-in type of connector, with 2 white collars on either end. push these collars toward each other while pulling the water line out of the connector..if its the screw in, simply unscrew it by hand. once you have it seperated, put the water line NOT coming out of the door into a bowl on the floor, and actuate the water lever, does the water fill up the bowl? Then your door's insulation has pockets of air, which over time build up with ice, and then freeze the water inside the door, preventing it from dispensing..
There is no fix for this, other than replacing your door, and i couldnt even tell you if the new door will solve the problem.
My advice, complain to GE.
Apr 07, 2010 | GE CleanSteel GSL25JFTBS
I have a Fujitsu 42'' PDS4221 - 10 years old - shuts itself off
See Fixya tips and tricks:-
'Fujitsu Plasma 42" random shutdown - continuous flashing red'
While the model of your set is slightly different, the checks described generally still apply, as it is very similar.
Nov 18, 2009 | Cars & Trucks
My tv won't turn on, i get five flashes in green of the power light then one red flash and that's it????
Mine had a similar problem. Unfortunately mine was about 1.5 years old, and LG only has a one year warrantee. What most people do not remember is that most mastercards and some other credit cards used to purchase consumer electronics extend the manufacturers warrantee 2x. I had to take mine to a TV repair place and get an estimate which turned out to be more than the purchase price. After chasing down my credit card statement from the purchase and the original reciept, I got a check for basically what I paid for the LG. Then I looked at consumer reports and bougt a different model.
Sep 10, 2009 | LG 37LC7D 37 in. LCD HDTV
Flash/sparks occrred (no metal in oven)
You know I just had a similar problem on my old unit. There was a spark and my bowl had no metal rims. I figger your ground connection has corroded at the rivets. So if you can drill a 1/8 inch hole in there and install a #8 sheet mtal screw or two to bond it togeter again.
May 04, 2009 | Microwave Ovens
Fan turned on by phantom signal
If you have more than one fan and they have remote controls they may be set to the same frequency. You can re set one fan to operate at a different frequency. The instructions ar in the manual or online.
May 26, 2008 | Casablanca Fan 3245T Ceiling
Optoma EP739 Projector Overheating
Set the projector to "high altitude mode." It will be noisier, but won't overheat. I wonder whether using one of those $10-$20 laptop coolers underneath it might be a quieter solution.
Mar 09, 2008 | Cameras
Craftmade International Craftmade Constantina in Antique White with Standard 3 Speed Pull Chain Fan Logo
43 people viewed this question
Top Craftmade International Dryers Experts
Andrew Taylor
Andrew Taylor
Jerry Kramer
Jerry Kramer
Rani wadia
Rani wadia
Are you a Craftmade International Dryer Expert? Answer questions, earn points and help others
