Question about Vehicle Parts & Accessories
Winnebago motorhome ..the security system in our 2010 Journey---it will not engage --both keys worked fine up to yesterday. System was put in last fall. ..light flashes to indicate there is power to the system. ...click is heard on the drivers side where the panel is. ...the door will not lock
    New Friend:
  • 34 Answers
Wire prob. came off in the door
Posted on Aug 02, 2013
lastech
  • 408 Answers
SOURCE: Security system locked down on 2003 CL55AMG
hello,try to check your battery in your remote key or use your spare key,then try lock and unlock your car,maybe 3 to 4 times until it"s work,ty
Posted on Apr 24, 2009
sodeep
  • 3267 Answers
SOURCE: Just purchased a C4 1989
You have inadverantly triggered the security system and the red light is flashing 'cos of that. Now if the system is new then you can call the dealer for the code(installation/activation code) to switch off the red signal and reset the settings to default factory settings. The same can be done at the local service station eqqiped with a PC for solving such related problems....sodeep
Posted on Jul 25, 2009
logosc75
  • 625 Answers
SOURCE: My DEI Valet system will not operate the door
You failed to mention the year/make/model of the vehicle so, I will assume that there existed some sort of door lock/unlock/alarm disarm bypass module in your vehicle that is no longer functioning. There is no simpler fix then either resetting the module or, remove and replace it.
Posted on Sep 30, 2010
slick42371
  • 42 Answers
SOURCE: I have a highlander 2005 and had a Avital remote
It sounds like the tech who installed this in your truck doesn't know what he is doing. I have been a tech for 20 years and have done 100's of these trucks for keyless remote starts. The door lock wires are in the drivers door or behind the glove box. There is some time in doing this because you have to build relays and use diodes for them to work, but it is possible to be done.I would find another place to do it and bill the first place that could not do it.
Posted on Feb 02, 2011
diodeic
  • 1622 Answers
SOURCE: My 2002 CRV security alarm
Hi,most times issues like this are use problem. Fues controlls most functions like parking light etc..
There is a box in the engine area that controls those function, Open the bonnet of the car check where those fuse are,there are always name on it and it's usually to box,one on you left and the other on your right..
Before you open the boxes, on it they wrote the descriptions on how to locate each fuse check each fuse and see if they are sillt working properly..
If you can get your way through..you might need help from a specialist with wiring in cars....
Good luck to you..
Posted on Mar 23, 2011
WHAT KIND OF TRANSMISSION IS IN MY RV? IT HAS A CHEVY 454 ENGINE.
454 chevy engine in motorhome - RV-Coach Online
www.rv-coach.com > Discussion Forum > Mechanic's Corner - Engines
Mar 25, 2010 - I have a 1995 winnebago elanden Chevy chasis and Chevy 454 motor.... I am trying to tighten or replace all the belt on my 1987 Fleetwood Southwind ... What type trans fluid,oil and filter does the 1984 chevy rockwood motorhome take? .... Havereplace ignition switch, check neutral safety switch at transmission, all OK. RV with Chevy 454 engine problems
Oct 18, 2015
454 P30 radiator removal
Jul 23, 2012
Overdrive Transmission Conversion
Nov 6, 2010
4L80E Transmission Problems
Nov 15, 2009
More results from www.rv-coach.com
Nov 24, 2015 | Cars & Trucks
Transponder keys
I would check the circuits at the key switch first. The anti-theft should only affect the starter and engine, not things like power windows.
Feb 28, 2014 | Mercury Cars & Trucks
1994 lexus es 300 starting issue / alarm reset?
I think that's the alarm system as well.the most important thing is the alarm system is still working?step out yr car try to use remote key to lock n unlocked,if that's working.i don't worry at all.lock n unlock are alarm system reset itself.should be normal,battery is super low or dead .good luck for u
Jan 20, 2014 | Lexus ES 300 Cars & Trucks
2009n dodge journey bad key
Actually yes I do. We have a dodge 2009 journey and it came with two if the same keys. They just reprogrammed the key. Dodge charged us like 45.00.
Jul 31, 2012 | 2009 Dodge Journey
When you put the key in to start it says bad key is that a battery problem in the key?
ur dodge might have a dead battery but more likely its because of a faulty ignition system.
Mar 13, 2011 | 2009 Dodge Journey
1990 lexus ls 400 security system went off now vehicle will not start. keys open door, turn alarm off but starter will not engage. had problem 2 months ago changed car battery. vehicle started, but the...
Okay you may want to check to see if the sensor on door lock cylinder hasn't fallen off from the lock itself. Pull of the door panels and check the wires at the door lock cylinder. Hope this helps.
Mar 25, 2010 | 1990 Lexus LS 400
Electrical problem in motor home
id need to know what shorts to really tell you exactly want wire it is man but id really suggest grabbing a olm meter and testing every wire arround the short if thats what you think it is my friend
Nov 14, 2008 | Ford E-350 Cars & Trucks
Vehicle Parts & Accessories Logo
65 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
