Question about Hardware & Accessories
How do i clean under the elements?? - Hardware & Accessories
    New Friend:
  • 55 Answers
Could you give some more context? Your category says "Problem with Timers".
Posted on Aug 02, 2013
I have Whirlpool Gold Quiet III dishwasher model GU 2300XTLB1 and the clean light flashes 7 times. The sump pump is clean. How can verify if my element needs replacement. And how to replace it ? Tx ML
To check the element, you need to remove the unit from under the counter, lay it down so that you can see the connections on the bottom, look for the wires that go to the element. You can either take the element out by removing the fasteners on the connections that hold it to the tub and take it into an appliance store and have them test it or you can get a ohm meter and check it yourself.
May 24, 2015 | Whirlpool Dishwashers
How do I clean under the electric elements on my basic westinghouse stove
Hello friend, thanks for your post!
I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
Sep 16, 2014 | Electrolux White Westinghouse Stove Range...
How to remove/test the heating element?
You probably have a clogged drain which causes the water to stay and then freeze. Remove the ice and clean the drain with HOT water until you see water in the drain pan below and then you know the drain is clean.
Jun 22, 2014 | Refrigerators
There is water in the bottom of the dishwasher, under the silver screen. Our glasses have been coming out filthy, while going in clean. I pulled the screen out. It has a lot of gunk in it. Also in the...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Oct 26, 2010 | Dishwashers
Want to know where the filters are that need to be cleaned, glasses are not coming clean during cycle
The filtera are under the bottom spray arm..often you need to remove it to get to the filter...but...also...
Check your heating element..
A bad heating element causes many problems in dishwashers…
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 23, 2010 | Dishwashers
Lower element does not heat
most likely the element needs replacing, check for arcing holes,melted spots. check fuses, normaly under cover at top of stove. element is easy to replace(a few screws), unplug stove when doing so.
Jun 17, 2010 | Maytag Gemini 30" Self-Cleaning...
THere is no bottom element in this oven. Is there supposed to be one??
you are right jsrock, there is an element under the floor pan, but if this person bought it from someone (not a dealer) that may explain the lack of knowledge. The benefit here is in the cleaning, and not having to lift the heating element to place foil or teflon sheets underneath as in "the old days." I like it this way better!
Mar 18, 2010 | Amana ACF4215 Electric Kitchen Range
I have a kenmore self cleaning oven and when i turn the oven on it wont heat and just flashes clean
could be that the heating element is bad, but u should get a kenmore dealer to take a look at it once it is under warranty and try replacing the element
Jul 03, 2009 | Kenmore Kitchen Ranges
Jennaire broiler doesnt work on slidein range after using self clean oven. Its only 14 mo. old
if just your broil element does not work and the bake element does work after using a self clean cycle then your broil element must have went out , self clean is a torture proccess for any self clean oven and it runs both elements at 500 deg. F, it may be still under warranty , if not then replace the broil element for the fix.
Phil
Jun 10, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Oven heat
There is a bottom hidden element that is the main element used for baking and cleaning. If its not heating then the element has gone bad and needs replacing. If you have a volt meter then you can confirm this by checking the voltage between the two terminals sticking out of the rear of the range. There should be 240vac across the two. If you have that then you need a new element if you don't then you need a new control board.
Nov 03, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Hardware & Accessories Logo
14 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
