Question about Horizon T6 Motor Control Board
Belt does not move motor does not run - Horizon T6 Motor Control Board
    Top Expert:
  • Horizon Master
  • 12,223 Answers
Belt does not move motor does not run - 0914e5e0-9c42-4186-884e-c875598d8660.gifSee the video and lube. Of course you must do the same with the rollers bearing front +back. Test the drive belt motor, and if necessary replace the belt.
If after you lube, the problem remain, is TIME to repalce the deck belt.
However you mus test too. the control board see the diagram
measure the input voltage for motor, if there are voltage the motor is faulty, repair or replace, see my personal TIPS.
test the output voltage for control board, for input voltage motor, if there are NOT the control board is faulty. replace.
God bless you
Posted on Aug 02, 2013
My vintage kenmore hand wheel was frozen now it turns manually but not when I use the foot pedal, then it won't turn
Either you will replace the belt or have to adjust the motor/belt tension.
1. The motor can be loosened by a couple of bolts. This allows the motor to be moved to adjust the tension of the belt.
2. The tension can be adjusted properly by turning the motor on with the foot pedal; low speed.
3. While the motor is running move the motor in a fashion that will loosen or tighten the belt. The correct location will allow the motor to run at it's highest speed.
4. Re-tighten the bolts and retest the machine.
May 04, 2017 | Kenmore Sewing Machines
My machine is not running ,the motor sounds like it ok but the bobbin is not moving? Thank you It is a Singer 3116 Simple
if the motor is running and neither the needle or the hook are moving, then your motor belt has come off(the motor will sound like it is racing). If the needle is moving, but the hook is not, you may have a broken gear, or timing belt.
Dec 01, 2016 | Singer 3116 Simple
Weslo Candence 5.9 won't run after being moved
Check for any loose electrical connections between control panel and motor especially any plug together connections. Moving may he have loosened or unplugged one of these connections. Hope this helps.
Dec 29, 2013 | Weslo Cadence G 5.9 Treadmill
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
Incline and decline wont move, so the belt wont move either. Have a jazfit treadmill
1)LUBE THE DECK BELT, INMEDIATELY.
2) tES THE MOTOR INPUT VOLTAGE, IF THER ARE THE MOTOR NEED REPAIR.
3) tEST THE OUTPUT VOLTAGE BOARD, FOR INPUT VOLTAGE MOTOR, IF THERE ARE NOT THE BOARD IS FAULTY.
4) tRY TO RUN THE SOFTWARE CALIBRITATION.
SINCERELY.GOD BLESS YOU
May 08, 2012 | Exercise & Fitness
Hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
May 14, 2010 | Reebok Exercise & Fitness
How to replace belt by motor
To replace a washer belt, remove power, remove back panel. On the left side is the motor, clutch, pump and belt. The pump is driven by a coupler clamped to the pump and clutch assembly. Loosen one of these clamps enough to move the coupler away so the old belt can be slipped past the coupler and also to facilitate the new belt to be installed. The belt runs in a pulley built into the top of the clutch assembly and can be "run" onto the transmission pulley very easily. To adjust the belt tension, pull out the washer, tilt it back against the wall......there are 3 nuts and bolts holding the motor assembly to the bottom frame, loosen these nuts off, the holes on the motor bracket are oval shaped so the motor assembly can be moved back and forth. You can move motor to tighten or loosen the belt, just make the belt fairly snug and don't over tighten it.
May 03, 2009 | Washing Machines
CHANGING A BELT ON AMANA MODEL # ALW990EAW/PALW990EAW
May 03, 2009 | Amana LWA90A
New belt runs too close to drum on pully
adj belt in motor pulley groves 1 grove at at time spin with hand to center on drum pulley
Dec 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Dryer will not move but power good
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Oct 05, 2008 | Samsung 7.3 Cu. Ft. Super Capacity...
Horizon T6 Motor Control Board Logo
78 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
