Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I can't get the battery compartment open on my KEYPAD. Recently bought the house and former owner gave me codes but I am getting no response so need to ck battery. LiftMaster 973LM is model # on the remotes which work.
There is a small hole on the bottom of the unit. Take the pointed end of a pen and press it in the small hole.....that will help pop the cover open to replace the battery.
Posted on Aug 02, 2013
  • 11 Answers
SOURCE: Sears Craftsman Garage Door Opener Wireless Keypad Model and a LiftMaster Chamberlain Professional Garage Door
I had the same frustrating dilemma with my Craftsman LiftMaster garage door and Keypad, Model 139.53754-01 (dated 10/06; and has the # 315 MHz).
To resolve “the dilemma”, grab your keypad, climb up on a ladder to access the garage door opener’s motor unit. On the right side of the motor unit, remove the white plastic casing by pressing buttons on each side and pulling down. This will expose the programming area, and for our purposes, the “Learn” button.
1. On the motor unit, press and release the “Learn” button. The Learn indicator light will glow steadily for 30 seconds.
2. Within 30 seconds, enter a four digit personal identification number (PIN) of your choice on the keypad. Then press and hold the ENTER button.
3. Release the ENTER button when the motor unit lights blink. The code has been “learned”/stored/activated.
Good Luck, and I Hope this Helps!
Gail
For possible future reference:
How to change an existing, known PIN
(Changing an existing PIN can be done with the wireless remote keypad, and does not require access of the motor unit.)
From the keypad:
1. Enter the four digits of the present PIN, then press and hold the # button. The opener light will blink twice. Release the # button.
2. Enter your new 4-digit PIN and press Enter. The motor unit lights will blink once when the PIN has been “learned”/stored/activated. Test by entering the new PIN, and pressing Enter.
Posted on Jun 24, 2008
  • 3197 Answers
SOURCE: I have LiftMaster garage door model 41A3039 and
To program the keypad, first unplug the garage door opener from the electrical outlet. Next remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Posted on Jul 13, 2009
  • 3197 Answers
SOURCE: Liftmaster Keypad problem
First thing to do is make sure it has a good battery installed. If this doesn't take care of the problem then the keypad is going bad and needs to be replaced. It is important that you get the same keypad as there are others out there that look the same but will not work.
Posted on Jul 23, 2009
  • 3197 Answers
SOURCE: Liftmaster 1/3 HP. Remote and wireless keypad stopped working.
The LED flashing 3 times is the code for a bad wall control. You can easily verify this by removing the wire from terminal 1 on the rear of the motor unit. If your remote and keypad start working you will know the wall control is bad.
Posted on Aug 03, 2009
  • 3197 Answers
SOURCE: Liftmaster wireless keypad closes but won't open the door
If you are sure the battery is good you have a bad keypad. The signal strength is so weak it will not penetrate the door.
Posted on Aug 25, 2009
How do I change the battery of the keyboard
The battery compartment slides open. Try using a putty knife in the joint of the cover and housing to pry it open. Be patient getting it into the joint and twist it.
Wireless Keypad for Garage Door
Dec 11, 2014 | Building Materials
Bought house with craftsman garage opener. Owner only had one remote. Bought a new remote at Sears that matched color code. followed instructions to code remote...that worked but made the old remote non...
Post the model number of the opener and the model numbers of the remotes. The opener model number is found on the end closest to the door and starts with 139.
Try programming the keypad like this:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
After programming the keypad see if either remote will work with it. Post this information also.
Oct 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do I find the radio code for a 1999 Mazda Miata? The battery was replaced by the former owner and they do not know how to re-program it.
sometimes it is somewhere in the owners manual or glove compartment. if not you will need to call the mazda dealer and they can look it up for you
Mar 12, 2010 | 1999 Mazda MX-5 Miata
How do I program a Craftsman Wireless keypad for Chamberlain garage door opener? I purchased the home and the former owner does not remember the code.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this button and then walk over to your keypad and key in any 4 digit code you want and press enter.
Make sure the battery is good in the keypad.
Feb 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
No lighting of keypad or response toentering code
Sounds like your keypad has failed if you are sure the battery you put in was good.
Dec 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad Chaimberlain 32B2171-1 does not work any more
You can try programming but if it still doesn't work then your keypad is just bad. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in your 4 digit code and press enter.
May 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
When I bought my house I was not given the code or manual to my keypad. Is there anyway to reprogram a new code without the original password?
be glad to help but need more info. type of keypad, wird or wireless. Model number (On back-take off wall by taking out battery and removing screw and push up)
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Bought a house with a craftsman garage keypad, but no code.
yes. hit learn button on logic board on motor and enter 4 digit code and hit enter. light bulb should flash. that is it.
Garage door keypad & remote
You need to sync both. I have a LiftMaster. If you want to change the code on your keypad you need to open up the garage door motor compartment where the light is (mine is in the back). Press the learn button, within 30 seconds enter the new code on your keypad and hold down the enter button for several seconds until the light on the opener blinks to tell you it has learned the code. Test the new code to see if it works. If the new keypad code works, then try the remote. My remote will not work after I reprogram the keypad. If the remote does not work (check battery) then climb back up the ladder and press the learn button on the garage door motor again, press the remote button and hold down until the light blinks again and the opener has learned the new code. This process works when I need to sync my remote and keypad. Good luck, I hope this helps.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftman Garage Door
I enrolled in the Assistant Premium Plan and am waiting on a response.
Apr 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
109 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
