Question about Garden
MY CAB CADET RZT 50 WONT START. THE BATTERY LIGHT COMES ON IT MAKES ONE CLICK AND THAT IT. CHECKED BATTERY IT IS FULLY CHARGED PLEASE HELP!!!!
  • 55 Answers
Maybe it needs to be primed - getting gas flowing into the engine. There will be a knob of some kind which you pull out and push in several times, or a rubbery button of some kind which also pumps a small amount of gas into the engine to get it started.Otherwise, it's probably a problem with the ignition starter.
Posted on Aug 02, 2013
pippall
  • 1486 Answers
SOURCE: my rzt 50 series cub cadet zero turn mower slows
The saftey wires wont cause it to slow down.Thats more of a fuel problem.Check the carb remove and clean the float chamber.Also check advance and ****** springs are still in good working order on carb.
Posted on Jul 06, 2009
mowerman1857
  • 389 Answers
SOURCE: I HAVE A RZT TROYBILT 50
Your machine has a warranty on it and in many cases if you attempt any unauthorized repairs, it will void your warranty.
My best advice it to first contact your dealer or an authorized service center regarding the problem and what you can do yourself without voiding the warranty
Posted on Oct 31, 2009
  • 10865 Answers
SOURCE: cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
Posted on May 28, 2010
  • 146 Answers
SOURCE: I have a Cub Cadet RZT 50 mower. The left drive
First, check the level of the hydraulic fluid (usually the dipstick is right inside the fill cap, and you just raise the seat to access it). If it's low, fill 'er up with the right fluid.
If that's OK, test if the lack of 'pull' affects the left wheel in both forward and reverse -- try going up a hill forward, and backing up it in reverse. If it affects both directions, maybe you will be lucky -- the problem could be that the bypass for the left hydraulic motor has opened somehow. (The bypass is used to let you push the mower by hand in case of an engine failure, etc.) So look for a fat-headed bolt sticking out of the left hydraulic motor. Check that it's tight -- rotate it just like you would tighten a bolt, clockwise. If it wasn't tight, that may be the problem; just tighten it and try the mower.
If this doesn't resolve it, you probably have a problem in the hydraulic valves, hoses, or motor, and a trip to the dealer is needed. Probably won't be cheap, sorry my friend. Good luck, and please rate if this was helpful, thanks!
Posted on Jun 04, 2010
SOURCE: Craftsman riding mower clicking noise - wont start
RIDING MOWERE JUST CLICKS AND WON'T START HOWEVER IT WAS RUNNING FIND JUST 5 MIN. BEFORE I TURNED OFF.
Posted on Jun 11, 2010
Have cub cadet rzt 50 ground wire pulled loose
green wire is a ground for the wire harness and needs to be grounded with the ground cable and it usually grounds to an engine mounting bolt or close to it
Oct 19, 2014 | Garden
How do I find year model on Cub Cadet rzt 50
The Manufacturers Serial and model numbers should be on a plate under the seat. Go to the Cub Cadet Website navigate to Manuals, enter the Serial/Model numbers and the year of manufacture should pop up.
Sep 21, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
Wont start but audible click sound is heard when key is turned
could be just a low charged battery,or troubles with starter solenoid,check these thing first,hope this helps you.
Aug 07, 2013 | Mustang Rzt 50" Zero Turn Riding Lawn...
When I turn the key on to start my Troy-Bilt RZT 50 zero turn mower, there is nothing. No ignition light, nothing. I have a new battery and I put a new fuse unit but still nothing. Help!
Do you hear a clicking sound???NO ?? Do you have the speed ?turning handles in the extrem OUT position? Is the ground cable connected to the engine block?? Is the Red cable connected to the + Positive post on the battery?? Is the BLACK cable connected to the - Negetive post on the battery?? Why did you need to replace the fuse? Is the battery charged??
If none of the above corrects the problem replace the ignition switch
May 02, 2011 | Mustang Rzt 50" Zero Turn Riding Lawn...
Pto blows the fuse everytime i engage it on my rzt 50 cub cadet mower.
Wire harness for the PTO on the RZT's is designed dangerously near the drive pulley. After time, the harness drops and comes in contact with the pulley which grinds through the coating and shorts out the circuit. Repair (tape up) the wiring, relocate the the wire to the opposite side of the crank pulley (may have to zip-tie in place) - shouldn't be a problem anymore.
Sep 25, 2010 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub cadet rzt 50, hit stump, blades wont engage but not bent
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cub cadet 2140 wont start or turn over
check the cilanoid or the stater , you may also have a lose conaction, try cross jumping the cilanoid
Aug 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
