Question about General Water Leak Detector - WA500
Flotec pump fp4322 08
My fotec fp4322-08 pump is leaking. i do not know where it is leaking from. It doesn't seam to be comming from an of of connections to the piping or tubing.
  • General Master
  • 3,368 Answers
Try putting news print below it, be sure it is dry, then check later and you will shortly find the area the leak is located.
Posted on Jun 18, 2014
Why isn't my pump pumping any water
Flotec FP4012-10 1/2 HP Shallow Well Pump Jet ...
www.amazon-associate.com/Flotec-FP4012-10...Well.../B0002YXB14?...
Find helpful customer reviews and review ratings for Flotec FP4012-10 1/2 HP ... After realizing the failure was due to a high amount of sediment in my well I ...
Aug 30, 2015 | Flotec Pump FP4022-10
My flotec pt4012 shallow well 1/2hp is leaking water from the pump. please help. It's a yr old
Usually it is the pump shaft seal located where the motor shaft turns the pump. It consists of two ceramic faces that are held together with a spring:
images?q=tbn:and9gcsqhemjvhz47gerqjd8xbjrm6rs_krzskup94w7_irt2dnk22eh
Feb 01, 2015 | Flotec Plumbing
Where is this adjustment on the flotec laundry pump
Owner's Manuals - Flotec Pump
www.flotecpump.com > Flotec Resources
Are you having a hard time locating a hard copy of your owner's manual? No sweat. We've got it right here. 4" Submersible Pumps. FP3222 ' FP3232 ' FP3212 ...
Jul 26, 2014 | Flotec Fpos1800a 1/4hp Sump Pump
Sump pump doesn't shut off
The floats could be binding on the pump or may have developed leaks so they don't float. Another possibility is that the switch mechanism is defective
Apr 01, 2013 | Flotec 1 3 HP Submersible Sump Pump -...
Flotec Model FP4012-D8 stopped pumping water. I took pump apart except for small impeller housing edge break I can see no reason for no suction?????
Hi jandh40...
You have an air leak somewhere in your piping, housing of the pump or maybe the mechanical seal and that is causing your pump not to pump.
Try to disconnect the piping and hook a water hose up to the pump and turn the pressure on, it should show you where the air leak is by spraying water out of the leak area.
Please take time to rate me
Aug 15, 2011 | Flotec Corrosion Resistant Shallow Well...
I have a broken sump pump, Flotec model # FPOF360AC
Same pump, same problem. H/D sells the pumps, but no parts. Here's a link to a vendor of Flotec parts. http://www.pumpvendor.com/Flotec_Parts_List.html
Apr 01, 2010 | Flotec Simer/Flotec/Omni 2105 Swimming...
Pump is leaking oil
very iffy to get to seal properly and for the $40 bucks cheaper to get new one
Apr 29, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Pump works but is not pumping water
IT SOUNDS AS IF THE PUMP IS NOT PRIMED. MAKE SURE THE THE PUMP IS FUL OF WATER
Jan 11, 2009 | Flotec Corrosion Resistant Shallow Well...
General Water Leak Detector - WA500 Logo
74 people viewed this question
Top General Plumbing Experts
ka4iup
ka4iup
Gil Shultz
Marty Shuman
Marty Shuman
Are you a General Plumbing Expert? Answer questions, earn points and help others
