Question about Ovens
I have a wall mounted Moffat Gourmet 2000 Double Oven - 411X. The turbo fan is not working. Any suggestions and recommended service agent - thanks Wayne, Auckland.
  • 25 Answers
SOURCE: Moffat Electric oven
check your breaker
Posted on Dec 12, 2007
SOURCE: wall mounted self clean convection oven by Frigedaire!
Unplug it or turn off the breaker
Posted on Apr 19, 2008
SOURCE: Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Posted on Oct 04, 2008
  • 112 Answers
SOURCE: GE double oven wall, JKP85B0A3BB
I would start by checking all of the door switches. Once you remove the shell, you will see them all on a rail where the door latch goes. Some will be normally open, some normally closed. If they all check out, check all of your overloads and thermal fuses. They should all read closed. If they all check out as well, replace your magnatron, capacitor, and diodes.
Posted on Oct 25, 2008
barkencoa
  • 3463 Answers
SOURCE: noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Posted on Feb 09, 2009
Frigidaire Gallery series model GLEB30T8CBA key pad not working
Hello Dana, thank you for your post!
From my understanding your Frigidaire oven is displaying an error code of "F8" and your keypad is not working properly. An "F8" error stands for runaway temperature (overheating). I would recommend performing a reset on your oven and you can do that by disconnecting the power cord for at least ten minutes.
If that does not help correct your issue then you could have a problem with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful. -Matt
Jan 10, 2016 | Frigidaire 30 in. Electric Gallery Series...
Wall oven needs a reset- wont heat
Hello John, thank you for allowing me to assist you!
I understand your wall-oven is no longer heating. The wall-oven has a safety thermal to prevent the oven from overheating. If the unit will not bake or broil, more than likely the safety thermal has tripped. Other possibilities are incorrect power supply or faulty main control board. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Best regards!
Oct 27, 2013 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire 30" Self-Cleaning Freestanding Gas Range, electricity randomly turns off and on.
Good Morning Jason, thank you for your post!
First, I suggest plugging another appliance in the same circuit/plug to confirm that the issue does not lie with your household circuit. If your circuit breaker is working properly and the issue continues, then it sounds like your range may possibly have a faulty power supply within the unit, a communication issue with the EOC (electronic oven control), or a potential wiring failure. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Best regards!
Oct 18, 2013 | Frigidaire 30 in. Electric Gallery Series...
Whirlpool built-in double oven model# RBD305PDB12
the humming sound is coming from the "squirrel cage" fan in the back of the unit, there may be some resonance vibration from the fan this issue should be addressed by a qualified service tech, the whole wall oven needs to be pulled out, i would have him check the fan.
Aug 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Replacement Door Hinges Miele Oven
hi the only place to purchase Miele spare parts is through Miele directly or from a Miele authorised service agent
Jun 14, 2009 | Miele DG 4080 Stainless Steel Electric...
E32MS Convection Oven not heating properly fan working intermittently
Replace thermostat. Service Engineer best but if you are competent then you could replace yourself.
Sep 19, 2017 | Moffat E32 Full Size Electric Convection...
Built-in Electric Double Oven
The fan is controlled by a temperature sensitive switch. Apparently the switch is not shutting off when it should. It will have to be replaced. If you are not comfortable working around appliances, you will need to call a service technician. There is usually a set of maintenance instructions in the top of the oven. Check it out for any suggestions. Temperature switches can be purchased on line.
May 18, 2007 | Whirlpool RBD306PD Electric Double Oven
Ovens Logo
130 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
