Question about Arris SURFboard SB5101 Cable Modem
I have haxorware sb5101 got no power lights- send -receive or pc/ethernet just stuck on standby all lights come on for a slit secound them stays on just stanby light got no problem with RF feed so carnt understant it carnt get 192.168.100.1 web page either tried everything can anyone help with this??. any help would be very greatful thanks...
Wndr3700 does not get internet through sb5101
you know what lets make this easy and not over think it. power cycle the modem. the modem paired your ip to the PC and now it needs its ARP table cleared so it can give the ip to the router.
Oct 15, 2012 | NetGear WNDR3700 Wireless Router
Ethernet led is not working in Motorola surfband sb5101
Hi
Try unplugging and replugging ethernet cable from the back of modem and from your computer- make sure you here a click when you plug it back in.
Check the standby light if on. Pressed standby button to disable standby mode.
Hope this helps. Cheers!
Dec 18, 2010 | Arris SURFboard® SB5101 Cable Modem
How do I bypass my router and connect my motorola sb5101 to my laptop?
use an ethernet cable and connect the modem with your PC
power cycle the modem to make it recognize your PC
At your PC, http://192.168.100.1 with username and password admin/admin to check the result. If your PC cannot get to that IP, you need to use ipconfig /renew command or simply reboot your PC.
Oct 31, 2010 | Arris SURFboard® SB5101 Cable Modem
My Motorola sb5101 won't come online how do I troubleshoot this? My cable connection is fine. When the modem boots up the green power light comes on and stays on followed by the receive light and the send...
These modems are very tricky. When this type modem goes into stand by modem that indicates that you do have a connection to your internet service provider. The reason you cant get online is because all internet access is disabled wile the modem is in standby. If you look closely there is a button located on the top of the modem. This is the stand by button. If you hit that button it should take the modem out of stand by mode and reestablish your connection to the internet.
I hope that information above has helped is some way.
If possible please rate this solution.
Aug 02, 2010 | Arris SURFboard SB5101 Cable Modem
Wont send
The send light will only flash when you are sending request not stay on all the time
May 09, 2010 | Arris SURFboard® SB5101 Cable Modem
Keeps flashing Receive light but not connected
when the receive light blinks it means its either receiving or attempting to receive a signal. If its not connected with the ethernet cord then its trying to receive and find the signal from your ISP (internet service provider).
Apr 28, 2010 | Arris SURFboard SB5101 Cable Modem
Motorola cable modem sb5101 the receive light blink an the same as the send light
If you are able to access the internet this is a normal operating status. These lights are just letting you know there is activity present with the modem and the modem is sending and receiving information with your provider.
Nov 08, 2009 | Arris SURFboard® SB5101 Cable Modem
My Motorola Sb5101 modem will not let me access the internet, the send light constantly flashes and i can't attain any internet connection.
If you have the following lights :
Power light - on
Receive light - flashing
Send light - flashing
Online light - off
PC/Activity - on
Standby - off
Then your Network Access is OFF - modem is successfuly registered but Network Access Control is disabled via DOCSIS configuration file.
Call your internet service provider....
Nov 06, 2009 | Arris SURFboard SB5101 Cable Modem
No connectivity; constant blinking LED lights "Receive" and "Send"
Or you didn't pay your subscription on time and the ISP disabled your cable modem to send user traffic over the cable network. When both Send and Receive lights are blinking that is a visual aid that the modem is working fine, but the ISP disabled its access to the network (unpaid bill, legal issues, etc.)
May 17, 2009 | Arris SURFboard SB5101 Cable Modem
Arris SURFboard SB5101 Cable Modem  Logo
82 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
