Question about Yamaha CRW 8424 Burner
Cre8424s scsi my cdrw is showing a red light solid and it isnt reconised in the device manager or my computer.
  • Yamaha Master
  • 12,061 Answers
Your CDRW has broken and you will need to replace it.
Posted on Sep 01, 2007
SOURCE:
Will not burn a CD
Have you checked which CDR media the device can use.
This may be as simple as using a CD-R rather than a CD+R or vice versa,
Also check if you may be burning to a CDRW or CDR.
Apr 03, 2014 | Marantz CDR420 CD Recorder
Usb device not reconised
This message is usually shown when the flash drive is burnt. Try to see if it presents the same message in different computers. if it does, unfortunately it is damaged beyond repair.
If it is recognized as a drive, but it is asked to format the flash drive, try formatting it and see if you can copy and delete files from it. If you cannot, it is really burnt.
Hope you may find this information helpful!
Regards,
Miguel L. Martins
Nov 08, 2013 | SanDisk Cruzer Blade Usb Flash Drive 8 Gb...
Good afternoon, my card dont have problem but i need the drivers for install in hp server Win2008 operative system my scsi card LSI20320C-HP you can send the drivers, apreciate that
the drivers might be installed properly for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
if these driver packages aren
Sep 05, 2011 | HP (LSI20320C) (LSI20320C-HP) SCSI...
Need driver for Hitachi CDRW/DVD GCC4244
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps
Jun 20, 2011 | Hitachi LG GCC4244N DVDROM CDRW Drive...
Dear friends! Where I can download drivers for Win XP for my SCSI controller SYM 20810? It connected with LINOScan 1400
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Jun 09, 2011 | LSI Logic SYM20810 32BIT PCI SCSI...
I purchased LG SATA DVD writer after installing it, unable to read any CD or DVD. Its detected in device manager but cant ready media. tried to SATA cable & SATA port, still same. Another thing i...
Can you hear it "spinning" the media? If not, you have a "defective" unit (motors or bearings).
If it spins, but nothing is read, then you have a "defective" unit (dead laser).
Take it back to where you bought it, and get them to test it, to prove that it is "bad", and then for them to replace it.
> in Hardware details it shows HL-DT-ST DVD RAM GH24NS50 SCSI CDROM Device.
Normal for most SATA devices.
> it shows as HT-DT-ST CD-RW GCE-8526B ATA device.
Perfectly normal.
Feb 21, 2011 | LG GH24NS50 DVDRAM Burner
My exterior Apple CD 600e will not show on the desktop of my Maci
As I recall, this is a SCSI device. Like many electrical connectors, SCSI connectors can develop a light corrosion which can keep the signals from being transmitted. The easiest way to clean such light corrosion is to shut down the Mac & power down *all* SCSI devices in the chain. Then gently unplug & replug all SCSI connectors. This will scrape off much of the corrosion & usually results in connectivity being restored. Be sure to unplug and replug the SCSI terminator attached to the last device in the SCSI chain. Restart by powering up the SCSI devices and finally restarting the Mac. Good luck!
Apr 02, 2009 | AppleCD 600e (M3958LL/A) CD-ROM Drive
Laptop keeps turning off and DVD-CD-RW Rom won't work.
The turning off problem may be a memory problem, download and run a memory checker (memtest 1.7 or later) it may also be a virus problem
ensure your virus checker is up to date and run a full scan,these would be a first step to try and solve these issues.
good luck
Terry
Mar 12, 2008 | Computers & Internet
Crw8424s scsi
the drive is ready to give up, when it cant read dvds or cd's and unable to eject because it cannot read tracks and commands it's time to buy a new one, they are very cheap and easy to fit yourself.
Sep 26, 2007 | Yamaha CRW 8424 Burner
Open Questions:
See all Yamaha CRW 8424 Burner Questions
Yamaha CRW 8424 Burner Logo
215 people viewed this question
Top Yamaha Computers & Internet Experts
Ekse
Marvin
Marvin
Harrie
Are you a Yamaha Computer and Internet Expert? Answer questions, earn points and help others
