Question about NADY Cmx16a Mixer
Need a new power supply cord - NADY Cmx16a Mixer
  • NADY Master
  • 3,368 Answers
It has an external power supply, I do not know if it has a fixed cord or one that plugs in. If it is not a fixed cord you can take the cord to your local computer store and see if they can match it. They may be available on line as well. You can always order one from Nady.
Posted on Jul 01, 2014
I need to find a replacement power cord for this tv, any suggestions? I can't find it
you don't say what has happened to existing cord or what is wrong with cord. Have you tried to get a replacement cord at a tv repair shop?
Nov 24, 2012 | Televison & Video
Do not know how to connect power supply
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Unplug all electronic cords connected to the computer.
At no time during the installation should any cords be connected to the computer.
Remove the screws holding the computer cover case, and remove the cover case.
Locate the computer power supply box, which looks like a large box out of which a bundle of wires run and connects to the power cord jack on the outside of the computer case.
Unplug the power cables from the internal devices connected to it.
Be careful not to damage any of the sensitive control boards or devices inside the computer, and be certain to remember--write it down if you need to--what devices will need reconnecting to the new power supply when you finish the installation.
Unscrew the power supply from the inside of the computer case and remove it. Check the original power supply's red voltage switch for the correct setting.
It should read 120 or 240 if you live within the United States.
Confirm this setting as the correct voltage setting for your power outlets.
Make sure your new power supply gets set to the correct voltage setting before you install it.
If it cannot be set to the correct voltage, do not proceed with the installation or you may damage your computer.
Return the new power supply and buy one that is compatible with the voltage requirements.
Install the new power supply, reattach the screws that will hold it in the proper place inside the computer.
Reattach the power cables that come from the new power supply to the devices that were connected to the old power supply.
Make sure all of these connections are firmly in place before you turn the computer back on.
Reattach the computer power cables and all the cords connected to the computer during normal operation, but do not close the computer case yet.
Keep your hands clear of the inside of the computer case as you attach power cords and peripheral devices.
Turn the computer on and observe the performance of the computer without touching anything inside.
Do all the computer fans function normally?
Does the computer operate as well as or better than before?
If you feel that the computer behaves normally and you do not encounter any problems, turn the computer off, remove all the power cords and peripheral cables once more, and close the computer case.
Then reattach the power cords and peripheral cables and begin using the computer.
Check for errors if you encountered any problems starting the computer or if it would not start at all, unplug all the power cords and computer cables connected to the computer and look inside.
Make sure that you connected all the correct power cables inside the computer securely and did not miss any.
If you have confirmed this and the computer still doesn't start or operate normally, call your computer manufacturer or a professional computer repair shop for assistance completing the installation
http://www.youtube.com/watch?v=xvClS_M-09o&feature=watch_response_rev
watch video
hope this helps
Oct 10, 2012 | Computers & Internet
Power supply was cut
you can buy a new power cord or you can use another wire to replace the cord. just buy the same size then you will need to remove the rear cover to access the internal. and then the old cord must be removed from the ac terminal pin and the assembled wire with plug that you buy can be replaced. you can directly re soldered the end of the ac wire at the pcb for ac supply.
Aug 16, 2012 | Mitsubishi WD-57732 Projection Television
I need a new power supply cord for my Cafe Collection electric skillet Model SY-101K or LPH-5
try an appliance repair shop as most have replacement cords for most appliances
contact the manufacturer on line in their spare part section and order one
Jan 23, 2012 | Wolfgang Puck Kitchen Appliances - Others
When I plug the power cord it won't boot. I need to charge the batterry first so I could use it. What is the possible trouble.
It sounds like you need a new power cord. The power cord may be giving just enough juice to charge the battery, but not enough to charge WHILE running. You can pick up a universal power supply from Radio Shack to diagnose if this is the issue. If it is, you can either keep the universal supply or return it and pick up a power supply from e-bay or toshiba.com. Just put in your model number with the toshiba link and look for "accessories", then find the power supplies.
Aug 23, 2011 | Toshiba Satellite Pro L300 Notebook
The power supply cord does not charge or supply power to the laptop. I purchased a new power cord only to find out that it is an internal issue. What part do I need to replace the internal power supply?
in all likelyhood it's the connect that the power cord plugs into. the soldering often fails in that area. it needs to be resoldered to make a good connection
Mar 28, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
Need new LG AC Power Supply Model H-P 220
I had a similr problem It turned out that the power supply cord was not the problem, it was the main battery. Luckily, in 2000, I bought 2 extra main batteries. I took out the old battery and put in one the 2 new unused ones and my machine is working and charging perfectly now.
Jan 06, 2009 | LG Phenom Express
Red Light on Plug in connecter thing
Sounds like there is something wrong with the Xbox 360 power supply, try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord. Give it a minute then reconnect it all back, also try it on another wall outlet without any extension cord at all.
If it's still red that suggests fault with your Xbox 360 power supply so will need to contact Xbox 360 customer support if its under warranty they should be able to sort it out for you. If out of warranty it might cost you for a new power supply!
Dec 13, 2008 | Microsoft Xbox 360 Console
I need to know what the power supply cord is called and if i can buy a new one? my printer is a hp psc 1410 all in one
It is called a power supply cord. On the back of the printer it might til you the appropriate volts and mAmp you will need. You can probably buy a new one from HP, but you can certainly find used ones as well and probably less expensive. Try this website Printerfixer.net
If the power supply cord is not listed on their website send them an email to see if they have a power cord for your printer model.
Nov 14, 2008 | HP Office Equipment & Supplies
NADY Cmx16a Mixer Logo
320 people viewed this question
Top NADY Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NADY Audio Player and Recorder Expert? Answer questions, earn points and help others
