LG LRTP1231W Top Freezer Refrigerator Logo
A
Anonymous Posted on Aug 02, 2013
My LG Model lrtn18320WW fridge handle broke how can I replace it?
2 Related Answers
Anonymous
  • Posted on Nov 26, 2010
SOURCE: my LG Model LRTN18320WW is
Drain in freezer compartment is plugged.
Mold (fungus) buildup sometimes restricts water flowing into condensate tube in the defrost cycle, and water somehow can enter in the refrigerator compartment and out the bottom of the refrigerator door.
You must clean the condensate tube!
You must remove back cover in freezer. One screw in left upper corner behind plastic screw plug will allow you to remove the cover exposing evapourator coil and condensate drain tube hole below it. Must also remove back cover at rear of refrigerator exposing the condensate drain tube END which may be restricted also.Tube must be totally cleared to allow the water created from defrost cycle to exit to the drain pan in the bottom of the refrigerator.
Anonymous
  • 1543 Answers
  • Posted on Feb 03, 2011
SOURCE: I have an LG fridge - model LRTN18320WW that has
No requirement for a yearly defrost. Landlord is a tight a**. Call for service.
Lrtn18320ww
I would check ebay or equal site. You never know what you can find. Awhile back I found a part for a 35 year old sewing machine.
2helpful
HI! I broke the handle on the door at the freezer. Can that be fixed? If not where can I buy a new door? The model of my fridge is: Kuppersbusch Integrated Fridge- Freezer Modell: IKE 318-6. Thank...
We were able to purchase a replacement handle for our freezer from RepairClinic.com . You'll need the model #, Serial #, and date of manufacture.
2helpful
Refrigerator section light broke. Replacement
Immediately when you open the fridge door the light has to go on,if it is a screw bulb,just tighten it little while'
if pin bulb push it harder,finally you may have to change
the bulb handle in the fridge.
LG fridge waterline broke
witch water line, one on the fridge or external line going to the house water line ? did you install the water line to the house water line or did they install it ?
LG LMV1650ST handle falling off and needs to be replaced
The lower door handle bracket broke and I'm trying to find out how to replace it. I already have the new bracket.
LG fridge model LRDN22724SW. Door handle (bottom part) is broken. I need a replacement part. Color is white Thanks
Still can not find that exact model number. Similar numbers I found were:
LRDC22743SW, LRDC22744SW, LRDN20724WW, LRDN20725SW, LRDN22712SW, LRDN22720WW, LRDN22725SW, LRDN22734WW
LG Fridge...door strickers
here is a link to an exploded view of your fridge model.. which parts are you looking for? Perhaps your description of the part differs from mine.. what is the part you need? Please be specific so I can assist you in finding a supplier...
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Exploded.pdf
1helpful
Need a handle for the freezer
heres the parrt number, although i dont really know who supplies the part, i guess you can call lg direct
3651JA1033C titanium handle for freezer door approx $40 US
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
