Question about Cameras
Chinon 2000 gl film projector blows fuse bord when turned on
2 Suggested Answers
SOURCE: Chinon Sp 330 super 8 movie projector.
this is a super 8 sound projector, not regular 8mm.
Posted on May 12, 2010
NEC V260XG temperature error
The most common cause is dust inside the projector that leads to overheating & auto shutdown. If you have an air compressor you can use the blow tip accessory to blow as much dust out as you can without taking apart the projector. You may get by using a can of compressed air available at Walmart, etc. electronics section. Concentrate on vented areas & where you can see or hear any fans. Do this outside so it doesn't make a mess. If you know how to take out the lamp there's usually close access to the main cooling fan through the lamp compartment, blow air through there & it will follow the right path to exit correctly without blowing dust all over the inside.
Apr 12, 2016 | NEC Display NP-V260X Dlp Projector - 3D...
How do I stop my Dad's Bell & Howell projector from "skipping" while running a film, model L, design 122.
For a projector to run right, the motor has gear teeth in it that engage with the hollow points on the film itself. The motor has to turn at a steady speed with no friction or hesitation. It is possible the motor on the inside of the projector needs to be oiled or cleaned out...or rebuilt at worse.
There is also the motor that pulls the film thru the projector and winds it onto the receiving spool. Sometimes that motor is out of synch with the projector drive motor and trys to pull the film thru to fast or turns to slow and the you get that "clicking " sound when the receiving spool isn't winding the film up fast enough and the film gets dragged on by those projector teeth and make that plastic clicking sound.
Watch the film while it is running between the two reels and the projector lens. The film should be slightly taunt going into the projector and slightly taunt coming back out of the projector. If you see the film grouping up in front of the projector drive or after, then you know your spools are needing greased up or there is a drag on the motors causing things to be unsynchronized.
This is definitely a mechanical problem and you need to watch the film being fed into the projector and how it is wound up n the receiver spool to see where the fault lies.
Feb 23, 2015 | Bell & Howell Service Manual: Model 122...
Can a bad ac relay in a 1999 chevy truck keep ac from blowing cold air
It could be your inline filter witch is called a orifice tube Check the pressure sensor next to the accumulator and check the fuse box for the ac compressor fuse
Apr 23, 2014 | Ipcw Chevrolet S10 / S-pu 1998 1999 2000...
98 s10 code p0113 blows ecm 1 fuse
test ignition coils,,,, have ecm and coils tested at auto zone!!
Sep 03, 2012 | Ipcw Chevrolet S10 / S-pu 1998 1999 2000...
I cannot power up my Sanyo PLV-70 projector. I have changed the power cable but the box is still dead, no sign of any power input.
try another wall outlet if that dosent work try a nother cord, than if it still wont respond it could be a blowed fuse or a bad power bord.
Jun 04, 2011 | Sanyo PLV 70 Multimedia Projector
1) Minolta XG1 35mm Film Camera 2)Minolta X300 35mm Film Camera Which batteries can I use for the cameras listed above?
XG1:
Two 1.55v silver-oxide (SR44 or equivalent), or two 1.5v alkaline-manganese (LR44 or equivalent).
You can download a copy of the manual at
http://butkus.org/chinon/minolta/minolta_xg-1/minolta_xg-1.htm
X-300:
Two 1.55v silver-oxide (SR44 or equivalent), or two 1.5v alkaline-manganese (LR44 or equivalent), or one 3v lithium (CR-1/3N).
http://butkus.org/chinon/minolta/minolta_x-300/minolta_x-300.htm
Feb 17, 2011 | Konica Minolta X300 35mm Film Camera
Need to upload. download, sideways load a user's manual, official or unofficial of canon eos rebel 2000 film camera. Thanks
You can download the manual from
http://butkus.org/chinon/canon/canon_eos_rebel_2000_300/canon_eos_rebel_2000_300.htm
The webmaster requests a contribution if you find it useful.
Dec 10, 2010 | Canon EOS Rebel 2000 35mm SLR Camera
Chinon sound projector sp-330 magnetic
Hello John.
I have a Chinon SP-330. What do you need to know?
mark@mjl-it.com
Jul 09, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
Cameras Logo
27 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
