Question about Mtd Garden
I WASHED THE TOP OF MY LAWNMOWER DECK ON MY MTD YARD MACHINES AND NOW IT NO LONGER WILL PULL WHEN IN GEAR FORWARD OR REVERSE
    Novelist:
  • 212 Answers
It sounds like maybe your belts are wet and slipping. Try it tomorrow when its dry and see what happens, if there is still a problem, let me know.
Posted on Aug 02, 2013
5 Suggested Answers
  • 32 Answers
SOURCE: MTD Yard Machine does not go forward or reverse - I replaced belt
I think that the belt is not on right. if you look at the belt diagram from the top, then on the left side then the belt is hooked up to nothing. on the right side then the belt goes through the left side of the clutch pulley.
Posted on Jun 20, 2009
  • 78 Answers
SOURCE: Riding mower surges in forward and not reverse. It
Ok first of all is not an automatic.Its a pedal operated transmission. The motion is accomplished by tightening a belt with a moveable idler and it is only shifted with a lever to forward and reverse. The belt probabley has a burnt spot in it and it hits that spot and it feels like a surge. Replace the motion belt
Mike
Posted on Oct 22, 2009
wireguy212
  • 1627 Answers
SOURCE: I need a key to my MTD yard machine, serial #
The key for your model is available from where you purchased it and is used by every tractor sol of the same model.
Posted on May 12, 2010
  • 256 Answers
SOURCE: what type of oil do i use for a mtd yard machine
Hi there. Use SAE 30 in temparature above 40 deg F, and 5W-30 if anticipated temparatures are below 40 deg F. You could also download your manual at http://www.mtdproducts.com/webapp/wcs/stores/servlet/OwnersCenterView?storeId=10500&catalogId=20500&langId=-1 just enter your model nubers in the center field and click dowload. Hope this helps
Posted on Jun 04, 2011
Hi i just bought a second hand MTD C4510 ride on mower yesterday, and the drive belt came off , where can i view a diagram to fit it so it can drive forward etc
u should have two drive belts .go to nearest seller of mtd ,get owners manual .u can'not push foot speed lever to quicky up & down .start to learn how to use your mower slowly .there is no gear box for forward & reverse speed. but u have forward & reverse gearbox .talk to your dealer he will explain
Dec 10, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
I have a Yard Machine Gold 22 h.p. 8 speed with a 46" deck. Where can I find an online manual that will show me how to remove the deck step by step?
lower deck remove belt from engine disconnect any hangars connecting deck to tractor raise deck lever pull out deck reverse prosess to install
Aug 01, 2010 | Yard Machines MTD Gold 23 HP Garden...
The cluch doesn't work. The gear pointer doesn't
Do you have a model number? Front tine or rear tine? I will try to help you.
May 29, 2010 | Mtd Products Yard Machines 158CC Tiller
Does anyone know whether these Yard Machines lawnmowers take straight gasoline or mix? I cant find an onwers manual online to clarify it. To be clear I seem to have a bit of an oddball machine;...
Straight gas. Look around, and you will see where to fill the engine with regular sae 30 oil, and on lawnmowers, if you have a place to fill it with oil, you don't mix oil with the gas.
May 18, 2010 | Yard Machines 11A08MB006 22Inch 139cc MTD...
The deck will not raise even , the riding lawnmower is a MTD Yard Machines, and when you raise the deck the left side does as it should, but the right side stays lowered to the ground and will not raise....
There is a pin that has come out of it's holf from the right side of the deck. Have someone raise the deck up and down and you should see a bracket or rod moving up and down. This attaches to the deck with a clevis pin to hold it in place.
HTH
Good Day.
Oct 27, 2009 | Mtd Products Yard Machines 158CC Tiller
Jun 18, 2009 | Mtd Garden
Yard Machines - Won't shift into gear
The problem most likely is the shaft on which the interlock slides back and forth on inside the transmission. The yardmachines have a continous spinning shaft which ends in a bevel gear. The is an interlock plate which is connected to the Forward Reverse shift lever, this plate slides back and forth and either engages the forward gear or the backward gear. This shaft is most likely galled up, preventing everything from sliding the way it needs to. This is not a difficult thing to fix if you are somewhat mechanical. Disassemble the transmission and check if everything slides
Apr 22, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
87 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
