Question about Fish
Why has my blackboy gone brown - Fish
Honeywell power supply F50A1017 not working
could be the switching board switch they fail over time capacitors you can tell by looking at them in most cases, diodes bit more harder but if there is any black or brown marks round them then theses can be faulty.. but if there is any yellow/brown colour round the capasitoes then they will have gone.
Mar 16, 2014 | Honeywell (F50F1032) Air Purifier
There is brown oil coming down the 2 supports for the drum so the bearings may be gone how do I replace them
Check on YouTube with your bosch bearing change demo; excellent vids there. For parts look in Fixya.
Click helped if helped
Mar 26, 2013 | Bosch WFL 2063 Front Load Washer
Oil in my water
At least not yet.
As you already know, brown coolant is usually a sign of engine oil leaking into the radiator coolant. Could be a gasket leak such as the intake or a head gasket, or the oil cooler if your car is equipped.
You said the warning light was on, was the radiator coolant level low ?
Feb 10, 2013 | 2002 Audi A4
Battery charger shows charged. however when tun throttle, nothing. no indication of loose wire connections. have a pocket mod
Make sure it is not battery or motor, jump the battery + & - to the motor + & -, if it works it will be the control box
30 minute fix for very cheap
ITEMS NEEDED
Get a Potter & Brumfield relay (5 poles)
2-3 feet of wire
4 female wire ends to plug into relay
HOW TO FIX
Take apart razor so you can see the black control box
Unhook throttle plug, this is the one with 4 wires (2 brown & 2 orange on mine)
Wire relay:
85: Ground
30: Red wire from switch to control box, if you wire this straight to battery it will work with switch on or off (killing battery)
87: Red wire to motor
86: Brown wire from throttle plug
Run a wire from 12v (battery) to other brown wire on throttle plug
END RESULT
When the throttle is activated, it closes the loop in the brown wires, triggers the relay, activates the motor
You WILL NOT have the throttle control, it is wide open or off when you activate/de-activate the throttle
This will save you $30 for a new control (brain) box.
Jun 10, 2011 | Razor E100 Electric Scooter
Small brown particles are found in filter and also what appeaars to be small grease stains on clothing what could be the problem?
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
if it's appearing on whites mainly (hot cycle)...
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa
Feb 07, 2011 | LG WFT1071TP Top Load Washer
My machine has brown spots of grease/oil appearing on the floor beneath it. The machine is still functioning but it is much louder than it used to be when filling and spinning. The model number is...
those brown spot are rust your main seal is failing if too far gone your washer will be noisy on spin suggest you replace bearing and seal before shaft is damaged hope this has helped let me know
Oct 06, 2010 | Fisher and Paykel IWL12 Top Load Washer
My transmission slips in just about every gear before it slowly grabs and creeps along
I would ck the fluid lvl and ck to see if the fluid looks brown if it is brown the transmission has been slipping for a while and it could of been cause by a Oring that has gone bad or the clutches just wore out and also could be the torque converter
Aug 22, 2010 | 1988 Dodge D-Series Pickups
Brown screen
Try unplugging your television for a minute and then re-plug and allow it to reboot. After re-start, you will need to access the menu to re-scan for channels.
Hope this helps!
Jun 13, 2010 | Vizio VW32L 32 in. LCD HDTV
Fish Logo
74 people viewed this question
Top Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you a Fish Expert? Answer questions, earn points and help others
