Problem with GN Netcom (9120-48) Wireless Headset
Cannot hear anything out of the earpiece of my GN netcom 9120 wireless headset
I cannot hear any sound out of my GN netcom 9120 wireless headset. This product has worked just fine for a year. We recently have a serious of power outages at the office. And since then (2 days ago) I have not been able to get the headset to work. I have unplugged all the cords and replugged everything back together. I have checked the power cable. The regular phone that this is connected to works fine. The green light is on the docking bay to indicate that there is power for the headset. When I speak into the headset, I can hear my voice amplified by the headset's microphone. Yet I cannot hear a dial-tone or anything over the phone lines through the headset. I tried turning the channel selector wheel on the docking station, but nothing seems to change the fact that I cannot hear anything through the headset. What else can I do? Thank you for any help you may offer! -Alan
Posted by avatar on Sep 01, 2007
    • By avataryodafish Sep 01, 2007
    • After re-reading the manual, I realize that it is important to note that the green light on the docking box is blinking and will not go solid. The troubleshooting guide there says to check that it is properly docked (I think it is...) and to check that the battery is in proper place in the headset (uhh...). I'm not sure if I want to crack open the headset. What should I look for? And what if I cannot put it back together? I wouldn't want to break it by trying to fix something simple. What is your best advice?
      Thanks again!
    • By avatarcoryasher Mar 26, 2008
    • I just started having the same problem system was working fine then I can no longer hear the other caller. The system is charged and red light blinking on headset, just no sound.
    • By avatarGuest Feb 06, 2008
    • Recently had a power outage and now cannot hear anything in the headset.
      The arm lifter is working when I lift the headset from the docking station, the green light on the docking station is solid, then when I pick up the headset and replace in the docking station it will flash for a bit. I have check all plugs/settings etc but still no sound from the headset.
      PLEASE HELP!!
Solutions (3)
Best Solution
I was also experiencing the same problem (also after a power failure / storm) -- apparently good battery charge, connections ok, etc. I then tried removing the battery from the headset itself, waited 30 seconds, and then reinstalled the battery. This seems to have resolved the problem.
It is fairly easy to open the clamshell, but you will need a very fine Phillips screwdriver to remove the battery hold-in (it's really not a hold-down, it just keeps the battery in place. Reassemble the same way -- be sure to keep positive to positive and negative to negative.
on the back of the base is a "compatability wheel." try spinning the wheel until sound comes out of the headset.
Hoe can i configure a brand new headset with an old base?
Add Your Solution
See all GN Netcom (9120-48) Wireless Headset Problems
