Question about Exercise & Fitness
ASR 700 console won't stop beeping and won't switch programs
    Top Expert:
  • 12,223 Answers
Reset the machine. press the small swith to the side of power button and disconnect the power cord by 30 seconds.
However you must adjust the REED switch, see the diagram attached. and test for open or faulty. clean it, and tight the connector very well.
Tight the ribbon cable inside of control panel Display very well, and tight the connector in lower parts.
If after you did this steps, you have faulty control Display board replace. see the diagram ASR 700 console won't stop beeping and won't - bd108fc0-c821-4e5b-b45b-800b6bbdfdd8.gif730f3e0b-adf5-420a-a588-7e086e28240c.gif
Posted on Aug 02, 2013
NordicTrack ASR 630 Elliptical Console isn't working
1) replace new batteries with the same type, and o.k polarity.
2) clean the contacts batteries with c.cleaner and retight the spring with plier for a GOOD contact.
3) adjust the REED swtich, test it , clean it and tight the plugs
4) tight the ribbon cable inside for a good contacts keypads.
God bless you
Nov 27, 2012 | Nordic Track Nordictrack Asr 630...
Nordictrack ASR 630 display won't start
see the steps and fix it according. God bless you
Console 1
Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
Nov 18, 2012 | Nordic Track Nordictrack Ack Asr 630...
What is asr button
Anti Slip Regulator (ASR button) stops power to the wheels when they spin (on slippery surfaces ),the ASR is designed to be turned off only when you require the wheels to spin at low speed,EG: when you are on snow or ice,as the ASR will stop the power to the wheels if they start spinning,you would never get anywhere. over 20 M P H is not active and serves no function.......hope this helps......cheers.
Aug 18, 2011 | 2000 Volkswagen Jetta TDI
I have a 2002 VW New Beetle. The ABS light has come on and there is a chiming beep and the ABS light flickers. What could be the problem?
ABS - Anti-lock Brake System.
If the ABS lights on the dashboard permanently the ABS system is faulty. You must access the ABS Electronic Control Unit (ECU) memory for pull out all DTC (Diagnostic Trouble Codes), using diagnostic equipment connected to the data link connector of the car. Then you will be full informed about bad pieces (e.g.: front right wheel abs sensor interrupted, ...). After bad pieces replacement you will be able to erase all faults memored by ABS ECU, in other words reset the ABS system and turn off the warning lamp on dashboard.
ASR - Acceleration Skid Control system.
When ASR warning light blinking the system is activated itself for car acceleration skid control.
For today's typical high-torque engines, traction control (ASR) can increase both comfort and safety, particularly when driving on slippery roads or surfaces offering differing levels of grip. Traction control permits smooth starting and acceleration through the full speed range without wheel-spin or fishtailing.
ASR only operates in conjunction with the electronic accelerator (E-gas) and uses components of the anti-lock braking system (ABS). If one wheel suddenly begins to rotate faster than the others (slip), ASR intervenes in the engine management system and reduces power until the wheel stops spinning.
The ASR system represents a further contribution to active safety as it maintains vehicle traction and directional stability throughout the acceleration phase at any speed. In addition, it reduces tyre wear. Activation of the ASR system is indicated by a flashing indicator lamp in the instrument cluster.
The ESP system means the Electronic Stability Program. ESP system includes the ABS system.
Jun 30, 2011 | 2000 Volkswagen Beetle
What does it mean when a yellow triangle with a surrounding arrow comes up on dashboard says "engin workshop"
The ESP system means the Electronic Stability Program. If the ESP lights on the dashboard permanently the ESP system is faulty. You must access the ESP Electronic Control Unit (ECU) memory for pull out all DTC (Diagnostic Trouble Codes), using diagnostic equipment connected to the data link connector of the car. Then you will be full informed about bad pieces (e.g.: front right wheel abs sensor interrupted, ...). After bad pieces replacement you will be able to erase all faults memored by ESP ECU, in other words reset the ESP system and turn off the warning lamp on dashboard.
Mar 12, 2011 | 2003 Volkswagen Passat
Wat is ars
ASR system:
"The electronic stabilisation program (ESP) makes the vehicle easier to control in handling situations close to the limit It reduces the danger of swerving and thus improves directional stability. ESP identifies the car's intended direction and response. It applies the brakes on individual wheels, thereby generating one-sided forces that help to keep the car moving in the desired direction. The program uses the anti-lock braking system (ABS), electronic brake-force distribution (EBD), the electronic differential lock (EDL) and the traction control (ASR) system, and is permanently active."
"For today's typical high-torque engines, a form of wheelslip regulation or traction control (ASR) can increase both comfort and safety, particularly on surfaces with differing coefficients of friction or on slippery roads. It makes smooth starts and acceleration possible through all speed ranges without wheel-spin or fishtailing.
ASR only operates in conjunction with the electronic accelerator (E gas) and uses components of the anti-lock braking system (ABS). If one wheel suddenly begins to rotate faster than the others (slip), ASR intervenes in the engine management system and reduces power until the wheel stops spinning.
ASR improves traction and can help the driver maintain control even if the limit of adhesion is inadvertently reached while cornering. In addition, it reduces tire wear. ASR activation, is indicated by a flashing light in the instrument cluster; it works with the electronic differential lock (EDL) and it is also part of the electronic stabilization program (ESP). ASR can be deactivated with the ESP switch."
Dec 05, 2010 | 1998 Audi A6
It seems a belt has slipped off nordic track asr 700. How do I remove cover to get a better look?
You have to pull the upper console and console tower before removing the panels, If you have access to a owners manual I suggest looking at the explodes parts it will give an idea of disassembling the unit. If you need a manual the go to iconservice.com click on manual input this info NORDICTRACK ASR 700 ELLIPTICAL (NTEL00607)
May 21, 2010 | Exercise & Fitness
Passat 200, intermittently break/ABS/ASR/STOP lights come ON
Try carefully topping up the brake fluid, this can happen when the level falls as the pads wear down especially when cornering
Dec 04, 2008 | 2000 Volkswagen Passat 4Motion
Asr problem
MB has ASR,  VW now has ESP.  You posted in Jetta TDI, but say you have a SL600.   Both are slip/traction control programs and both can be manually overridden by dashboard button.  When the ASR or ESP is locked out, the light will be on all the time, maybe you can just push the button?   When driving, if this light flashes on, then ASR/ESP is trying to help get the wheel that is spinning not to.
If the light came on after replacing parts, or a repair job,  something may be wrong with the parts (non OEM), the service or a sensor may have been damaged.
Check with dealer for a recall for your vehicle on brake switch ... vw had a recall on these around 2002-2005.
Oct 29, 2008 | 2003 Volkswagen Jetta TDI
Does any one have gateway GT5220 Installation disk ?
Create an ASR Floppy Disk loadTOCNode(2, 'summary'); The following steps can create an ASR floppy disk from an ASR backup operation: 1. Format a 1.44 megabyte (MB) floppy disk and insert the disk into the floppy disk drive of the computer. 2. In System Tools, start the Backup program. When the Backup and Restore Wizard is displayed, click Next. 3. Click Restore Files and Settings, and then click Next. 4. In the What to Restore dialog box, select the media that contains the ASR backup. Ensure that the media is inserted. 5. Expand the Automated System Recovery Backup Set that corresponds to the ASR floppy disk that you want to create. 6. Expand the second instance of the drive letter that contains the system files. Expand the Windows_folder/Repair folder. 7. Click the following files from this repair folder: Asr.sif and Asrpnp.sif, and then click Next. 8. At the Completing Backup or Restore Wizard screen, click Advanced. 9. At the Where to Restore screen, set the Restore Files to: dialog box to Single Folder, and then set the Folder Name dialog box to the root of your floppy drive, for example, "A:\". 10. Click Next. The other options in this wizard are optional and do not affect the transfer of files to the floppy disk. When the wizard is finished, the files are copied to the location that you had previously specified. The ASR floppy disk is ready for use in the event of an ASR restore operation.
NOTE: The Asr.sif and Asrpnp.sif files must reside on the root of the floppy disk drive to be used during a ASR restore operation. Starting the Windows Recovery Console loadTOCNode(2, 'moreinformation'); To start the Windows Recovery Console, use one of the following methods: • Use the Windows Setup floppy disks or the Windows CD-ROM to start your computer. At the "Welcome to Setup" screen, press F10 or press 'R" to repair. After you start the Windows Recovery Console, you receive the following message: Microsoft Windows(R) Recovery Console
The Recovery Console provides system repair and recovery functionality.
Type EXIT to exit the Recovery Console and restart the computer.
1: C:\WINDOWS
Which Windows Installation would you like to log on to
(To cancel, press ENTER)? After you enter the number for the appropriate Windows installation, Windows will then prompt you to enter the Administrator account password.
Note If you use an incorrect password three times, the Windows Recovery Console closes. Also, if the Security Accounts Manager (SAM) database is missing or damaged, you cannot use the Windows Recovery Console because you cannot have correct authentication. After you enter your password and the Windows Recovery Console starts, type exit to restart the computer.
When you use Windows XP Professional, you can set group policies to enable automatic administrative logon.
Use the Winnt32.exe utility with the /cmdcons option to add the Windows Recovery Console to the Windows Startup folder. This procedure requires approximately 7 megabytes (MB) of hard disk space on the system partition to hold the Cmdcons folder and files.
Aug 02, 2008 | Gateway GT5220 PC Desktop
Exercise & Fitness Logo
261 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
