Question about Ricoh Office Equipment & Supplies
Right side of my copies are faded from my ricoh aficio 2022. It has a new photoconductor unit. It makes nice copies right after we vacuum the inside, but quiclkly fades out again. How can I test the transfer roller? And replace it if necessary? What else can it be.
  • caryn rasmussen Aug 05, 2013
    I did a halfway test, and the image on the drum is also lighter on one side. And printing an internal report also came out light on one side.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 32 Answers
Check your laser section and clean all the mirror there also the polygonal motor
Posted on Feb 12, 2014
  • RONALDO PANLAQUI
    RONALDO PANLAQUI Feb 12, 2014
  • 990 Answers
SOURCE: RICOH AFICIO 401 COPIER- COPIES FADED ON ONE SIDE
Hello sir; You have to replace drum and developer meanwhile you have to clean up image roller, then it will take care the problem.
Posted on Nov 06, 2009
  • 320 Answers
SOURCE: Lexmark T644 left side of prints faded
pull the toner cartridge out leave the bottom front cover open and bring down the top cover. with a flashlight check to make sure the charge roller is comming down straight if it comes down even. check to make sure the transfer roller has spring tension on the left side if the pring tension is present you will need to clean the flat leading edges of the mirror motor drive inside of the scanner located under the top cover.
Posted on Nov 07, 2009
  • 903 Answers
SOURCE: ricoh aficio 1515 printing faded images on one
Could be one of a few things:
Most likely is the transfer roller. If it's dirty or old and not applying enough charge, it may not be pulling all the toner away from the drum. Replacing the transfer roller is easy if you can get a new one.
Are you sure you have the correct toner? The wrong toner can definitely cause copy quality problems.
If the springs that hold the press roller against the hot roller are not properly in place (or if they have started to lose tension) the toner won't be fully fused onto the paper.
I'd start with the transfer roller (black roller that sits opposite the drum on the right side door) first -- it's the most likely culprit.
Posted on Jun 19, 2010
SOURCE: Ricoh aficio 1515 printing faded images on one
provavelmente o problema ? na porta lateral, no rolo de transfer?ncia, aquele rolinho preto no meio da tampa, ao tirar ele tem uma mola em cada lado, o lado da c?pia fraca est? com a mola com pouca press?o, estique um pouco a mola e coloque-a de volta, deve resolver...
Posted on Aug 06, 2010
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Grinding noise
Could be photoconductor gears are bad will have to replace unit or fuser unit you will have to decide which one first
May 28, 2014 | Ricoh Aficio 1018D All-In-One Laser...
Replace photoconductor unit setting error
What did you repair? as the pcu is an assy and cannot be rebuilt
Oct 30, 2013 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh aficio 2022 replace photoconductor unit
Photo conductor unit is the drum unit inside the copier . It contains developer and toner which are the ink as some people refer to it. It is a consumable part and needs to be replaced every 60k copies but can and dies last longer. You can ignore it and once copy quality is ok I wouldnt bother changing it but you will eventually need to replace it.
Oct 02, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Reset photoconductor units aficio 410dn
www.ricohpr.com/.../Ricoh%20Aficio%20SP%20C410DN%20LTR%20%5B34245%5D... -
in order to reach the Ricoh restore factory menu, you need following steps.
1. push the yellow small "C" buttom. you can hear beep.
2. push the 3 numeric buttoms, in following order: 1,0, 7 .
3. push the big red "C" buttom, don't release for 5 minutes until you saw a copy windows popup on the screen.
choose the "copy sp", then trun off the power, and turn it on again.
now done, you have reseted the factory settings for the Ricoh Aficio munti-functional copier;printer.
If you really need the actual "Chip" then you will have to get a Service manual, inside there are circuit diagrams and circuit details.
May 06, 2010 | Ricoh Aficio SP C410DN Laser Printer
How to replace image unit ricoh aficio 220
Do you mean the photoconductor unit? To replace the photoconductor (PCU), open the front cover and the right side covers (the duplex door and the main side door). The PCU sits to the right of the toner bottle -- it is a black unit that has the blue cylindrical drum facing the right side of the copier.
On the upper left side of this unit is a ridged tab. Push this tab in and slide the PCU all the way out of the machine. Open the box with the new PCU and remove all of the tape and paper, then slide the new PCU in where the old one came out of. When you shut all of the covers, the copier will recognize the new PCU.
Apr 23, 2010 | Ricoh Aficio 220 Laser Printer
Copies are half printed and half almost not printed (very lite)
If the copy count is around 150,000 or higher and you haven't replaced the developer as well, it should be replaced. That symptom can cause light copies if it hasn't been replaced every 150,000 cycles.
Aug 23, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
RICOH PHOTOCONDUCTOR UNIT CLEAR CODE????
Actually, there isn't one! But, you can get rid of the message. Press clear modes, 1,0,7, and then press and hold clear stop. Choose copy sp. Scroll to 5, (mode) then scroll to PCU alarm setting. There are 2 options. Display will shut the message off. If it is a 1, make it 0, or vice versa. Interval, will set the count. You can make it an 80, and that will give you 20000 more prints. Personally, I would change the PCU really soon, other wise you will pay for it in toner.
Mar 17, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
103 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
