Question about Gestetner DSc224 Copier
CANNON NP6025 AFTER PUTTING IN NEW TONER, I TRIED TO MAKE COPIES AND THEY JAMMED ,I REMOVED THE PAPER AND GOT AN ERROR CODE E212,PLEASE HELP ME,I TURNED IT OFF LIKE IT SUGGESTED AND I ALSO UNPLUGED IT AND STILL THE SAME EROR MESSAGE
  • 24 Answers
E212 is scanner home position error.remove the platen glass. Check the scanner and lense assembly.
Posted on Sep 03, 2007
  • Anonymous Sep 05, 2007
    if it is not solved replace the lense home position sensor
SOURCE:
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
Dec 25, 2014 | Cannon Office Equipment & Supplies
Paper jam in rear
Hi Linda,
1.Open the front cover.
2.Pull out the drum unit and toner cartridge assembly.
3.Open the back cover.
4.Pull the tab toward you to open the rear chute cover.
5.Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the tab with one hand as you gently pull out the paper with the other hand.
6. Close the back cover.
7. Put the drum unit and toner cartridge assembly back into the machine.
8.Close the front cover.
If the error is not cleared, turn the power off on your Brother machine.
If the problem still continues, please contact Brother Customer Service from "Contact Us".
9. Make a test copy. If the machine jams again, try the followings:
10. Make a test copy. If the machine jams again, use new paper from a fresh, unopened ream of paper. If the machine still jams, please contact Brother Customer Service from "Contact Us".
Still having Problem Then follow Us For
Brother Printer Support
Feb 19, 2014 | Brother MFC Office Equipment & Supplies
Cannon pc720 error code 8 with checkmark
The error code 8 with the checkmark is an indication of a paper jam. Hopefully, if you remove the paper tray and remove the toner assembly you might see something in the path. You may also try using a can of compressed air to blow anything out of the paper path. There are a couple of plastic spring loaded sensors in the path too. Be careful. This machine is old and next to impossible to find parts for. Wish you luck. Hope this helps...
Nov 02, 2012 | Office Equipment & Supplies
PAPER JAM MESSAGE APPEARS WHEN THERE IS NO PAPER JAM
Please follow the directions below to clear the paper jam error orincase there is one somewhere.
Turn off the Printer. Remove the drum and toner from the front cover. Remove the toner from the drum. Look inside machine incase of possible paper jam. Open back cover and paper tray incase of jam. Close all doors and put toner and drum back in machine. Turn on the printer, and see if the error message is gone.
Apr 04, 2010 | Brother MFC 7420 All-In-One Laser Printer
I have a canon mp830. I had the 6A00 error code.
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 07, 2008 | Copystar CS-1815 Printer
Error code E212
sorry I have'it only in italian
Jul 11, 2008 | Canon NP 6035 Copier
Docucolor 12 error code HELP
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Sep 13, 2007 | Xerox DocuColor 12 Color Copier
122 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Bernard D'Souza
gggg
Adorjani Laszlo
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
