Question about Sony ST21i Xperia Tipo Black
Unresponsive touchscreen on sony xperia tl lt30at
Touch Screen on Sony phone not working
Maybe its a hardware failure, the Touchscreen or the Digitizer must be replaced. Send your phone to the nearest Sony Xperia Service Center for repair.
Mar 27, 2015 | Sony Xperia Z2
Tip
You may use Nidesoft Sony XPeria Video Converter.It is excellent Movie Converter...
Sony HDR-SR10E,Share Sony HDR-SR10E MTS to FLV for Mac Users
Do you have some short films shot with Sony HDR-SR10E AVCHD camcorder, and want to share them on your website? It will make your site more attractive with videos. While Apple compete with Adobe, the Flash support on Apple devices like iMac, MacBook Pro do not support exporting to Flash FLV/SWF now. You can not directly export FLV from the Apple QuickTime Player, iMovie or Final Cut Pro/Final Cut Express.
One solution is to upload videos to YouTube and embed YouTube videos on your site. If you do not want to embed YouTube videos, you can convert Sony HDR-SR10E MTS files to FLV with Mac Sony MTS converter, and put the FLV videos on web server with Flash player. Aunsoft MTS/M2TS Converter for Mac is the recommended Mac Sony HDR-SR10E MTS converter for you. It exports Flash videos with automatic deinterlacing function, which makes the FLV videos play without interlacing artifacts. It could also help you merge several Sony .mts video clips and export as one file.
Here is the step-by-step guide to convert Sony HDR-SR10 videos to Flash on Mac.
Step 1. Load Sony HDR-SR10E videos to Aunsoft MTS/M2TS Converter for Mac.
Run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony HDR-SR10 converter, and click the "Add" button to load .mts files for conversion.
Step 2. Choose Flash FLV output format.
Click the "Format" option, and choose Flash Video > FLV-Flash Video Format(*.flv) as output format. You can also choose the profiles like FLV H.264(*.flv) or F4V(/f4v).
Tips:
With The above mentioned output, you shall use Flash player like JW player, Moyea PlayerBox player, or Flow player to play the Flash videos. If you want the video to play automatically, you may choose SWF-SWF Forma(*.flv) as output.
Step 3. Transcode Sony HDR-SR10 MTS to Flash.
Click the "Convert" button under the preview window, and the conversion from Sony MTS to Flash video FLV/SWF will start right away.
Wait for a while, and you can upload the Flash videos to your sever and embed them on your web page.
PS:
1. The "Merge into one file" on the main interface is to join/splice .mts files.
2. If you are using camcorders like Sony HDR-CX350, HDR-XR520, HDR-TG7, or Cyber-shot DSC-TX7, DSC-H5V, you can also use the Mac Sony MTS converter to export FLV files for web sharing. Aunsoft MTS/M2TS Converter for Mac also works with Canon HF S21, Canon HF100, Panasonic HDC-TM700 and other AVCHD camcorders.
on Jul 23, 2010 | Cameras
My sony xperia tipo(DUAL) touch screen freezes after every 15-20 minutes of standby . plz helpp !!!!
There is a solution by Sony for this problem.
Just follow the instructions: http://talk.sonymobile.com/t5/Xperia-miro-Xperia-tipo-tipo/TIPO-TOUCHSCREEN-FIX-PATCH-HERE/td-p/262920
Sep 27, 2013 | Sony Xperia Tipo Dual ST21i2 Black Android...
How do I remove the battery from my sony xperia tl?
I think Sony Xperia tl has Non-removable battery like iPhones. But if you want to remove the battery, you may contact any mobile repairer around you.
Aug 17, 2013 | Cell Phones
Back Remove of a sony xperia tl
there should be a lil slot to put you finger nail in. or a botton. push in and pull out at the same time
May 22, 2013 | Sony Xperia Tl 4g Mobile Phone - Black...
Unresponsive touchscreen Xperia Tipo
you have to go local store to purchase cheaper spear parts if you send me your address I can help you to which market you have to go for cheaper spear parts
May 18, 2017 | Sony ST21i Xperia Tipo Black
Touch screen problem
If you're still having touch-screen problems with your Tipo, you might need the screen calibration patch.
Download this file:
http://www.4shared.com/rar/3p6YulVl/ST21i_calibrate.html
The file is the official screen calibration patch from Sony for issues with the touchscreen of the 2012 range phones (I'm 100% sure it works on: Tipo, Tipo Dual, Miro and Xperia J)
Dec 20, 2012 | Sony ST21i Xperia Tipo Black
I need my sony xperia mini unlock to any network
Hi visit Mobileunlocksolutions.com to unlock your Sony Ericsson Xperia mini from network lock .Here they ask you the network name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
Sep 21, 2012 | Sony Ericsson Sony Experia X10i Mini Pro...
Sony ST21i Xperia Tipo Black Logo
83 people viewed this question
Top Sony Cell Phones Experts
M_Butkus
john h
Eric Sutherland
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
