Question about Scuba Diving & Snorkeling
Changing rear axle bearings - Scuba Diving & Snorkeling
SOURCE: rear axle bearings need replaceing I hear grinding
Go to Jeep and buy a bearings, seals, and collar. The bearing is held in place on the axle by a keeper collar. This must be cut off to get the old bearing and seal off. Use a wizz wheel to cut it and then whack it with a chisle
To get the axle out. Remove rear diff cover, and wheel and start taking apart. It's not a terrible job, but if you aren't very mechanically inclined, take it to a shop. Make sure you use the correct fluid in the differential.
Posted on Dec 01, 2008
  • 1596 Answers
SOURCE: rear axle bearing replacement
REAR WHEEL BEARING/ HUB
Removal Procedure
  1. Raise the vehicle. Refer to Vehicle Lifting in General Diagnosis.
  2. Remove the wheel and the tire. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment.
    1. Remove and support the brake caliper. Refer to Brake Caliper Replacement (Front) or Brake Caliper Replacement (Rear) in Brakes.
    2. Remove the brake rotor. Refer to Brake Rotor Replacement in Disc Brakes.
    3. Remove the ABS sensor wire connector.
    4. Remove the four bolts from the control arm.
    5. Remove the hub and bearing from the control arm.
    6. Remove the brake shield from the control arm.
    7. Clean the control arm face and the bore before installing the hub and the bearing.
    Installation Procedure
    Notice: Refer to Fastener Notice in Service Precautions.
    1. Install the brake shield and the hub and the bearing to the control arm with the four bolts. Be careful not to drop the hub and the bearing, as it could be damaged. Reconnect the ABS sensor. Tighten the hub and bearing bolts to 70 Nm (52 ft. lbs.).
    2. Install the brake rotor. Refer to Brake Rotor Replacement in Disc Brakes.
    3. Install the brake caliper. Refer to Brake Caliper Replacement (Front) or Brake Caliper Replacement (Rear) in Disc Brakes.
    4. Install the wheel and the tire. Refer to Tire and Wheel Removal and Installation in Wheels, Tires and Alignment. Tighten the wheel nuts to 140 Nm (100 ft. lbs.).
    5. Lower the vehicle.
Posted on Feb 22, 2009
Toyota Guy
  • 42 Answers
There are 4 bolts for each rear axle. They are located behind the rear brake drums. Remove e-brake cable from rear drum and take off brake line.(carefully). I recomend draining and changing your rear differential fluid too, because if the fluid by run out of axle housing. also you should replace the seals for the axles of if you are changing the bearings. When you are done don't forget to bleed your brakes, and hooking up e-brake cable. I hope this answers your question.
Posted on Mar 06, 2009
  • 102 Answers
SOURCE: can't get left rear axle out to replace bearing
you must remove the cover on the rear end, remove the 5/16" bolt on center carrier, push the pin that the bolt whent through out, thenp push the axle in, a c clip will fall out of the carrier then axle may be removed,
Posted on May 26, 2009
Rayvin1943
  • 97 Answers
SOURCE: 1994 gmc rear axle removal how to
-Remove tire and brake drum
-put drain pan under axle housing
-remove rear axle housing cover (10 or 12 bolts)
-turn gear untiil the bolt for cross shaft shows and remov e the bolt
-remove the cross shaft.
-push axle in until you can remove "U" clip from axle and axle will pull out,
Remove seal, you need a pulller to remove axle brg.
Posted on Jul 26, 2009
How do I change rear wheel bearings on my 1992 GMC Safari van
Put the rear up on jack stands and remove the wheels and brake drums. Then unbolt the rear differential cover and drain the gear oil. Then, you remove the pinion securing bolt. DO NOT ROTATE THE WHEELS AS THIS CAN CAUSE THE PINION GEARS TO FALL OUT. Push the rear axle shaft inward toward the vehicle and remove the "C" clip that secures the axle to the pinion gears. Then pull the axle shaft outward and out of the axle housing. Inspect the axle shaft for scuffing and excessive wear on the place where the wheel bearings rest. If there is excessive wear, you can use a "repair bearing", which is modified to install so it runs on an unworn part of the axle shaft. Otherwise a regular replacement bearing is fine. You need a slide hammer removal tool to extract the old bearing from the axle housing, and a bearing install tool to insert the new one without damage. Once the new bearing is in, reinsert the axle shaft, secure with the "C" clip, and pull outward to latch the "C" clip into its recess. Install the pinion bolt. Reinstall the differential cover with appropriate gasket or sealer. Fill differential with approved gear oil in the recommended amount. Ensure that if the rear is a positraction rear end there may be an additive required to the gear oil for proper operation.
Sep 24, 2015 | GMC Cars & Trucks
Rear end makes rowing sound above 30 miles per hour also tjere is a leak of rear end grease on the left rear wheel.
THE LEAK is an axle seal leaking the noise is bearings in rear end could be axle bearing of carrier/pinion bearings while driving shift weight of truck side to side see if noise changes if so it is axle bearing if not then most likely differential bearings
May 11, 2011 | 1995 Chevrolet Blazer
How do you change the rear wheel bearings on a 2004 chevy express 1500 van?
Axle Shaft Bearing & Seal Removal & Installation To Remove:
  1. Raise and safely support the vehicle.
  2. Remove the axle shaft.
  3. If replacing only the seal, remove the seal using a suitable seal removal tool.
  4. If replacing the seal and bearing on the 8.6 inch axle, install the slide hammer and adapter behind the bearing and pull out the bearing and seal together.
  5. If replacing the rear axle shaft seal and the bearing on the 9.75 inch axle, install the J 29712 or equivalent bearing puller into the axle housing behind the axle bearing.
  6. Remove the axle shaft seal and the bearing by tightening the nut on the J 29712 bearing puller.
Use a slide hammer, bearing puller and adapter to remove the old axle bearing 88457g81.gif
To Install:
  1. Install the axle shaft bearing using a suitable size driver. Drive the bearing into the housing until the tool bottoms against the tube.
  2. Lubricate the seal lip and install the seal with a suitable seal driver. Make sure the seal is fully seated in the axle tube.
  3. Install the axle shaft.
  4. Fill the rear axle with the correct lubricant.
Oct 18, 2010 | 2004 Chevrolet Express
How do you change rear bearing on 2000 safari?
The rear axle bearing? I'm going to presume that's the bearing you're talking about and not the rear main bearing, so please take that into consideration if you would
You're going to have to jack up the rear of the van, remove the tire and drum. Then you have to place a drain pan under the rear differential and remove the cover. After the cover is removed spin the rear axle (the one with the tire off) to locate the pin in the very center of the differential. On the right side you will see an 8mm (5/16) bolt head.
When you remove the locking bolt (the 8mm) and slide the pin out DO NOT SPIN THE AXLE WITHOUT THE CENTER PIN IN PLACE. Push in on the axle with the bearing to be replaced and a "C" clip will fall out of the differential. SLIDE THE CENTER PIN BACK IN and screw in the locking bolt a few turns. Once the "C" clip slips out, you can pull the axle out. If you don't have a bearing puller, it's best to rent one. Insert the bearing puller and pop the bearing out.
Apr 06, 2010 | 2000 GMC Safari
Rear axle bearing problem on 2002 jeep grand cherokee, changed twice, problem returns
you need to check the rear end fluid level,and you might have to put an oversize bearing in if the housing is scoring the bearing race.have a shop install it.
Jan 10, 2010 | 2002 Jeep Grand Cherokee
How do you remove right rear axle on a 2004 ford crown vic to replace seal on wheel?
Section 05-02A: Axle, Integral Carrier — 8.8-Inch Ring Gear 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual REMOVAL AND INSTALLATION Axle Shaft NOTE: Whenever replacing the rear axle lubricant, use Rear Axle Lubricant XY-90-QL (ESP-M2C154-A) or equivalent.
Removal
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The rear brake anti-lock sensor must be removed before the axle shafts are removed. The rear brake anti-lock sensor is bolted on the rear disc brake caliper anchor plate.
  1. Raise vehicle to desired working height. Refer to Section 00-02 . Remove rear wheel (1007) and tire assembly. Remove rear disc brake calipers (2552) and rear disc brake rotors (2C026) .
  1. Clean all dirt from area of axle housing cover with a wire brush and/or cloth.
  1. Drain rear axle lubricant by removing the axle housing cover .
  1. Remove differential pinion shaft lock pin and differential pinion shaft .
  1. Push flanged end of the axle shafts toward the center of the vehicle and remove the rear axle shaft retaining u-washer from the button end of the axle shaft .
  1. Remove axle shaft from the rear axle housing , being careful not to damage the inner wheel bearing oil seal (1177) and rear brake anti-lock sensor ring.
Installation
NOTE: Check for presence of rear axle shaft o-ring (4A332) on the spline end of the shaft and install if not present.
sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Care must be taken not to let axle shaft splines damage oil seal or bearing assembly.
  1. Carefully slide axle shaft into rear axle housing without damaging rear wheel bearing (1225) or rear brake anti-lock sensor indicator (2C189) . Start splines into side gear and push firmly until the button end of axle shaft can be seen in the differential case .
  1. Install the rear axle shaft retaining u-washer on the button end of the axle shaft splines, then pull the shaft outboard until the shaft splines engage and the rear axle shaft retaining u-washer seats in the counterbore of the differential side gear .
  1. Position the differential pinion shaft through the differential case and differential pinion gears , aligning the hole in the differential pinion shaft with the lock bolt hole. Apply Rear Axle Lubricant to differential pinion shaft lock pin . Install differential pinion shaft lock pin and tighten to 20-41 Nm (15-30 lb-ft). sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Differential pinion shaft lock pin must be tightened to specification using Stud and Bearing Mount E0AZ-19554-BA (WSK-M2G349-A1) or equivalent.
    NOTE: Axle housing cover must be installed within 15 minutes of application of the silicone rubber or new silicone rubber must be applied.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Make sure machined surfaces on both axle housing cover and rear axle housing are clean before installing the new silicone sealant. Inside of axle must be covered when cleaning the machined surface to prevent axle contamination. Tighten the cover bolts in a crosswise pattern to ensure uniform draw on axle housing cover .
  1. Apply Silicone Rubber D6AZ-19562-AA or BA (ESB-M4G92-A or ESE-M4G195-A) or equivalent. Install axle housing cover and tighten retaining bolts to 28-38 Nm (38-52 lb-ft).
  1. Add Motorcraft Rear Axle Lubricant XY-90-QL or KL (ESP-M2C154-A) or equivalent until it is 6-14mm (1/4-9/16 inch) below bottom of fill hole. Add 118.3 mL (4 oz) of Ford Additive Friction Modifier C8AZ-19B546-A (EST-M2C118-A) or equivalent to Traction-Lok axles. Install fill plug and tighten to 20-41 Nm (15-30 lb-ft).
  1. Install rear brake anti-lock sensor indicator . Tighten retaining bolt to 4.5-6.8 Nm (40-60 lb-in).
  1. Install rear disc brake caliper and rear disc brake rotor .
  1. Install wheels and tires.
  1. Insert Rear Bearing Remover T85L-1225-AH in bore and position it behind bearing so tangs on tool engage bearing outer race. Remove rear wheel bearing and inner wheel bearing oil seal as a unit, using Impact Slide Hammer T50T-100-A.
    Rear Disc Brake Caliper Anchor Plate
  1. Lubricate the rear wheel bearing with Rear Axle Lubricant.
  1. Install rear wheel bearing into the housing bore using Axle Tube Bearing Replacer T78P-1225-A.
    sra~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Installation of rear wheel bearing or inner wheel bearing oil seal assembly without proper tool may result in an early bearing or seal failure. If inner wheel bearing oil seal becomes cocked in bore during installation, remove it and install a new one.
  1. Install the inner wheel bearing oil seal using Axle Tube Seal Replacer T78P-1177-A. Use Premium Long-Life Grease XG-1-C or K (ESA-M1C75-B) or equivalent between the lips of the inner wheel bearing oil seal .
  1. Install axle shafts as outlined.
May 13, 2009 | 2004 Ford Crown Victoria
Rear bearing
rear axle bearings I assume? Pull the diff cover, rotate the carrier so you can remove the pin from the center of the 4 spyder gears, push the axle in slightly, and remove large c clip from the carrier area. The axle will pull right out! These vehicles are hard on axle bearings. Look them all over.
Good Luck!
Apr 02, 2009 | 1996 Jeep Grand Cherokee
Rear axle bearings
Jan 28, 2009 | 1986 Toyota Pickup 4WD
Need to know how to change rear wheel bearing in a 95 suburban
jack & support vehicle. remove rear axle cover drain fluid, removeleft rear tire drum/rotor brakes, remove bolt in axle housing that holds the 3/4 inch pin in place pull pin , push left axle shaft inwards and remove c clip from inside axle case,slide out axle shaft,remove seal,remove bearing and install in revers
Jan 16, 2009 | 2003 GMC Sierra
Scuba Diving & Snorkeling Logo
108 people viewed this question
Top Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
