Question about Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 Screen is Not Bright
My Sony KDF-E42A10 LCD HDTV has suddenly become very dark and I cannot adjust it. Up until now the picture has been bright and clear and could even be watched with bright sun indirectly on it. It can only be watched now when the room is dark and then it is difficult. The lamp on front of TV is not flashing. The TV is only 14 months old and I estimate that it might have a max. of 2000 - 2500 hours since new. Cable box has been replaced with a new one and cable has been through troubleshooting with no effect. Is this the sign of the projection lamp failing? If so, where can I get lamps for best price?
  • 3 more comments
  • Anonymous Nov 13, 2007
    Have the same problem on 60 inch TVĀ
    what is the solultion
  • Vmax93 Feb 29, 2008
    My Sony KDF-E42A10 LCD HDTV has the same problem. It's virtually useless in the day light. It's dark and I can't adjust it any brighter for day time use that then doesn't look way too bright at night/dark room use. It can only be watched now when the room is dark. My TV is apprpoximatley two and a half years old and I have no idea how many hours are on it........a lot. Is this the sign of the projection lamp starting to fail? If so, where can I get lamps for best price?
    The only steps I've taken to try and correct it is adjusting the TV itself. HELP!
  • Anonymous Apr 29, 2008
    I have a Sony Grand Wega KDF-60XS955 and the picture got dark suddenly. I have adjusted all settings, picture,brightness,gamma settings to no avail. Fortunately my set is still under warranty. I will post results of the serviceman's evaluation 4/30/08. My set is 3yrs old.
  • rrotho Dec 22, 2008
    how did you get the burned film off of the lens and bulb reflector area ?
  • wizard-jdjf Dec 28, 2008
    Mine is the same, even after the lamp was replaced
OK, I removed the lamp assembly to inspect it. The lens appeared to be foggy or have a smokey, burned appearance to it. I compared my lamp to a friends that has the same TV. His was clear and clean looking. I installed his lamp in my TV and it worked like new. I went to Best Buy and Circuit City to get a new lamp, neither one stocks or sells the lamp at the store. You have to go online to order one. It's $220.00 shipped from
While I have a new lamp on its way I thought I'd play with the old one a bit. I carefully removed the lens from the lamp assembly and I cleaned and polished the lens to try and remove some of the burned look it has. I noticed after I got the lens out that the bulb reflector inside also has a burned look to it.
So, in cleaning and polishing just the lens I was able to remove about 80% of of the burned appearance. I reinstalled the cleaned and polished lens into the lamp, lamp into the TV and I was amazed. I forgot just how good my pictuire used to be.
I can't wait to get my new lamp and get it back to 100%
Posted on Mar 11, 2008
Try a lamp first, through best buy their about $150 -250. If that fails it might be the optic block assembly which is about $1,000, and i just recently had replaced, and the picture is as bright and clear as when i got it two and half years ago
Posted on Mar 07, 2008
Ony KDF- E42A10 lamp needs replaced, should I replace the fan also, just got a new lamp 8 months ago picture is dark
Usually the lamp gets brighter when it begins to fail. I would check to see how dirty the inside of the set is. There are beam splitters and lcd filters in that set and if they get dirty then you lose picture quality.
Nov 18, 2012 | Sony KDF-E42A10 42 in. LCD Television
I have a Sony KDF-E42A10. No matter what setting I choose for wide screen I can't get the picture to fill the entire screen. Any suggestions on how to adjust the picture to fit the screen?
Download the manual if you do not have one from the following url.
The manual on page 53 have demonstrated the different modes. Have you tried these modes?
Jul 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 rear projection TV. Won't turn on.
Start by changing the lamp. If you got 5 years out of the old one, count your blessings, most folks only get three. The lamp is designed to be replaced by the consumer. Ebay will carry a replacement for you or you can get it directly from They've got good prices. The lamp door is on the back. Its really easy, give it a shot.
Sep 07, 2009 | Sony KDF-E42A10 42 in. LCD Television
Picture is dark
Adjust video settings:
  1. Press Wega Gate
  2. Select Settings
  3. Highlight Video
  4. Press + to select
  5. Adjust/increase the brightness.
  6. Press Wega gate to exit.
If picture is still dark, you need to replace the lamp again. Sony recommends that you replace the lamp:
  1. After approximately 8,000 hours of use.
  2. When the screen becomes dark or the color becomes unusual.
  3. When the lamp indicator on the front of the TV flashes.
Aug 22, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Dark picture after purchasing a new lamp. didn;t help at all
May 05, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Crack in the screen 42" sony kdf-e42a10
You can find a new Sony replacement lenticular screen and fresnal screen for a model # KDF-E42A10 from a major Sony distributor at the following links:
Sony KDF-E42A10 Replacement Part Lenticular Screen
Sony KDF-E42A10 Replacement Part Fresnal Screen
Feb 16, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony LCD KDF-E42A10 Television
Please count flashes on Sony KDF-E42A10 tv and let me know.
Its error signal and shows problem with particular area in your tv.
Sep 29, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10
replace the lamp and you will most likely be good to go.
Mar 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 42 in. LCD Television Logo
867 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
