Question about GE Profile Spacemaker 1.8 Cu. Ft. Over-the-Range Microwave
The light bulb above the stove under the microwave hood keeps burning out. I have replaced the bulb twice in the last month. The microwave is a Whirlpool Gold model GMH5205XVB.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 114 Answers
Either the wrong bulbs or just bad ones. The oven only gives it the 120 volts. It won't be the microwave oven. Just bad bulbs
Posted on Sep 23, 2014
MicrowaveSvc
  • 9047 Answers
SOURCE: how to change light bulb under microwave
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
The first step is to unplug the oven before changing bulbs!
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
http://www.microwavedisplay.com
Posted on Apr 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: 40 watt night light bulbs constantly burn out short out.
Is they are left on all the time, this can reduce their life, and they are more susceptible to vibration.
Have you checked at home center or home improvement centers like Lowe's, Builder's Square or Home Depot?
You can order quality parts such as lamps by entering your full model number or part number WB36X10003 here.
Always be sure the microwave is unplugged or the breaker is off when installing or removing bulbs, and be sure the bulbs and and your hands are clean when installing them.
Posted on Feb 14, 2009
  • 15 Answers
SOURCE: Light bult in a Microwave oven is burned out.
There should be a panel covering the bulb iside the cookspace with a screw holding it on. Remove screw, cover then bulb.
Posted on Oct 12, 2009
SOURCE: One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Posted on Jun 28, 2010
Light bulb above stove under microwave hood
According to the GE manual it is a 120 v 20 watt halogen bulb, the GE product number is WB36X10213. That is the cooktop light/nightlight that would be on the stove hood. HTH!
Sep 25, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
On our Panasonic the genius sensor 1200w microwave the bulb burned out so replaced. After replaced turned light switch on both bulbs turned on and right away one bulb burned out and now the switch will not...
Mine burned out within a month. Probably due to the poor design of the machine which forces you to slam the door to get it to shut.
My biggest concern is the under counter lightbulbs it has burned out in my kitchen over the last year. I wonder how much leaking this thing really gives off. Moving in a few weeks and will be throwing this cancer machine out.
Sep 09, 2011 | Panasonic NN-H764 Microwave Oven
THE STOVE TOP LIGHT ONDER THE MICROWAVE BLEW OUT. WHEN I REPLACED THE BULB BOTH LIGHTS NO NOT WORK.
Sounds like a power source issue from under the hood.
Unplug or turn off all power and take a closer look in there,. alternatively - this may sound crazy, but are you certain both bulbs are working by testing in another fixture??
Jan 05, 2011 | Sharp R-1480 Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Does stove-top need downdraft if microwave has oven-hood combo?
We have a stove with no downdraft, and a microwave with a hood above it. It works just fine. I expect you could keep your downdraft and put a microwave without a hood above it, and that would also work. I don't think, however, you can buy an above the range mocrowave oven, that slides in on brackets, which will not have a hood.
Jan 08, 2009 | Microwave Ovens
MH1140XMS Oven Stays On
Right, but I wondered if you might want the OLD broken board fixed, too, as a backup? Keep it in mind, It's only $39.95.
Feb 07, 2008 | Whirlpool MH1140XMS Microwave Oven
GE Profile Spacemaker 1.8 Cu. Ft. Over-the-Range Microwave Logo
404 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
