Question about Amana 31962701 Spark Module
Amana was bought by maytag who was bought by whirlpool..every part number for every one of these companies parts is different, though many of the actual parts are the same. Q- is there anyway to find similar or side by side listings of parts by these numbers? ie- if I searched for amana AKGD3050E , I could find the parts list with Maytag and whirlpool and etc similar / same parts listed or included?
  • 86 Answers
SOURCE: parts list for a Amana model # ARS266ZBS side-by-side
Try this link:
[url=http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167655]Amana ARS266ZBS Parts Listing[/url]
Posted on Feb 06, 2009
dragonsthatk
  • 547 Answers
SOURCE: Amana dryer doesnt heat up
no heat. heat element
Posted on Feb 11, 2009
erpaalai
  • 999 Answers
SOURCE: I have Amana electric dryer, model number LEA30AW.
There are 2 screws along the bottom and the lower panal will drop down and off. You can look in from there.
Eric
Posted on Jun 10, 2009
jumptrout51
  • 3361 Answers
SOURCE: Amana gas oven not working
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Posted on Aug 30, 2009
Testimonial: "Thanks for the good info."
localwonder
  • 6784 Answers
SOURCE: My Amana icemaker & water dispenser has
HI. This is an inlet issue.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush
or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Posted on Sep 14, 2009
My Maytag glass cook top PER5710BAQ stove has broken cook top are the similar product model tops compatible or do I need to buy the exact top... IE could I buy an amana cook top or whirlpool since they are...
It will depend how the tops electrical terminations are. Many internal/fuses/switches/elements are the same, but though may tag is the parent manufacturer it always isn't interchangable. Like a Pontiac g6 and Pontiac sunfire...
They're both 2 door cars
Both made by Pontiac
Some parts are identicle
But some aren't.
Nov 12, 2014 | Kitchen Ranges
No i am not, need info on Amana refridgerator
(Without a specific model responses are generic.)
Controls should come ready to install (coding is pre-installed).
Oct 22, 2014 | Amana Refrigerators
NEED A TECH/REPAIR PERSON TO COME TO MY HOME TO REPAIR WASHER. OUT SINCE JULY 7,2014? HELP ME PLEASE
Amana appliances are now produced by Whirlpool Corp., who purchased Maytag Corp., (previous owner of brand). Whirlpool maintains the previous Maytag parts and repair call center in Cleveland, Tenn. The phone number in your operating manual, even if purchased prior to Whirlpool takeover, for repair should still be good.
Oct 14, 2014 | Amana Clean n Clear Water Filter 12527304,...
Amana green water filter light off
If your machine is only 2 months old and wasn't used when you bought it call the number on the label that has the model and serial number on it that is located either inside the refridgerator on the upper wall somewhere or somewhere on the frame. Being that whirlpool now owns Maytag, which encompasses Amana, you have a one year manufacturer warranty where parts and labor are both covered free of cost.
Apr 27, 2012 | Amana 22.6 cu. ft. Side-By-Side...
WHAT MODEL ICE MAKER DO I NEED FOR A ET18PK FRIDGE?
the part # is 4317943
it is i/m kit that comes with several different wires to match the plug equipped on your ref.
it fits all whirlpool brands including but not limited to; Whirlpool, Maytag, Kitchen Aid, Kenmore,Amana Estate,Roper and many more brands manufactured by the Whirlpool Corp.
at Sears it cost over $120.00 and at the link i have included it cost $70.00(plus shipping)http://www.filtersfast.com/Whirlpool-4317943-Icemaker.asp
copy and paste it if necessary
Jul 22, 2011 | Whirlpool Refrigerators
Need to replace a gas manifold for an Amana GCI 90A30 gas furnace. The part number, D6995003 is an obsolete Maytag part number since Goodman bought out Amana. I either need to find a source for the part or...
You could Purchase the Part from :-
http://www.apwagner.ca/index.php?main_page=product_info&products_id=486717&language=en
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 27, 2010 | Amana Dehumidifiers
AMANA refrigerator manufacturer part no.B8364301 MAYTAG part no.113710 PTC Device Pls advs how to procure or alternate spare if the above is not available
the model that uses this part is TM16G1 / YOURS MAY BE DIFFERENT . Maytag and whirlpool do not make abilab any longer / you can use after market part from supco . ck there web sight . most appl dist will also be able to supply the after market part .. hope this will help / with your model and mfg # i could help you more. thanks mm.
Dec 02, 2009 | Ovens
Is there any better resource for a door handle (ps2172561) for an Amana MVH230W than paying $90+shipping online? That seems outrageous for a plastic 12" handle. I guess when youc an't open your microwave...
The Amana / Whirlpool / Maytag part number is R0713642 and you can get it for far less at one of the places listed here.
Nov 24, 2009 | Amana MVH230 Microwave Oven
Maytag sav571eeww
Honestly, I would either call Maytag once you get the estimate and see if they will do anything for you (ie-cover the cost of the parts and/or labor) even though it is out of warranty. This is costly repair, and that machine was not Maytag's best. When Maytag took over Amana, they built the SAV series on the old Amana platform, and unfortuately it was not able to live up to the Maytag "Old Dependable" name. The new Maytags, however, which are built on the Whirlpool platform, are very dependable and we have had very few issues with the models starting in "MTW...", and we own a Maytag Home Appliance Center so we deal with these issues on a daily basis.
Sep 06, 2008 | Maytag SAV571EEWW Washer
Amana 31962701 Spark Module Logo
15 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
