Question about Pyle 9005 8000K Single Beam HID Xenon Driving Light System
I have hid spotlights and the ballast seems to malfunction. I have replaced the ballast only to last 15 minutes. Why is this happening?
  • 3 Answers
What kind of vehicle are we talking about? Does it happen to both lights?
Check the voltage with a multimeter going into the ballast. Should be a constant 12V. If voltage is good swap ballasts and see if issue stays with ballast or side. If ballast is still behaving poorly its time for replacement.
Posted on Aug 02, 2013
Headlights do not work high or low beam all other lights work
Re: Condensation in Sienna Right Headlight.... - Toyota Sienna Forum
www.siennachat.com/.../4606-condensation-sienna-right-headlight.html
Mar 10, 2009 - 15 posts - ‎9 authors Over the years, I was not a frequent visitor to SiennaClub...but when I did visit, it was... in the right, passenger-side xenon HID headlight of my 2004 Sienna...the light has... Check with your dealer and see if they can do anything about it. .... :o The HID bulb is also a PITA to remove because you are working ... Re: 2004 Sienna no brake lights, radio, heater/AC ...
Jan 4, 2013
Thread: HELP: Both Low Beams don't Work
Nov 27, 2011
Thread: 2000 sienna drl and/or headlight issue
May 7, 2010
Automatic Headlight Option: Useful or Not?
Mar 3, 2010
More results from www.siennachat.com
Toyota 2004 Sienna repair: Replacing HID ballast or ...
toyotarepairsemipro.blogspot.com/.../replacing-hid-ballast-or-computer....
May 1, 2010 - Replacing HID ballast or computer control lighting for the Headlight. Just got a ... Up until now, I did not know I had the option of seeing twice as far with Xenon. Also up to ... In the end after buttoning everything up, the light did work fine. .... Howdo you determine if you have a HID or non-HID light? Reply ...
Oct 15, 2015 | 2004 Toyota Sienna
Headlamps not working.
is the light setup one ballast for high and low beam ? if so the ballast has gone, probably even the bulbs. replace the ballast and bulbs. some aftermarket ballasts don't last, if you cannot find the right ballast for replacement you will need to replace both ballasts. as every ballast set are set the same and sold in pairs.
Jun 01, 2017 | 2001 Oldsmobile Silhouette
How to install HID to honda xrm 125
Did you buy a HID bulb or did you buy the kit with the ballast etc? Usually an HID lamp will come with a ballast and wiring loom which is per fitted with relays etc. you would normally plug this loom into the headlight socket of your bike's wiring and then tidy the ballast etc behind the fairing and replacing your bulb with the HID lamp. If you don't have the loom and ballast they're pretty easy to come by on the auction sites.
Jul 14, 2014 | GAS EC 125 Motorcycles
My ballast keeps malfunctioning. I put a new one in and it lasted about 15 minutes. Hid spotlights . What can you suggest that I can look for?
Let's start backwards.
First, look at your grounding system.
Be sure it is using heavy gauge wire, and that there is a direct connection with the car battery (or truck, or whatever). All new vehicles are more and more made of non-conductive material like plastics and fiberglass, etc., so that can interfere with all things electric.
Then, see about the wire and the connectors leading to the lights. Do those wires need to be bigger or heavier?One way to tell is if any wire in the system gets warm whilst it is being used.
Finally, be sure the ballast is "stronger" or "heavier" than the load ( the lights) due to the possibility of overload because of a mis-match.
Be blessed.
Aug 01, 2013 | Pyle 9005 8000K Single Beam HID Xenon...
One side of my hids worked before something happened. I tried checking all the fuses and none seemed blown. So I tried plugging the broken hid kit on the side that worked and for a few seconds it work
This looks like a poor contact in the socket of the one "that worked before something happened". It may not be enough of a break to be seen easily so I suggest you simply replace it. If that is not possible try flexing the areas of the wires and the socket to see if you get intermittent contact.
Jan 12, 2013 | Cars & Trucks
Vector HID spotlight glass is broken
Go on line with your computer and get to the Vector spotlights web site. Request a parts list for your model.
Nov 28, 2012 | Vector 20 Million Power Series Spotlight
2005 Lexus Rx330 Ballast problem??? First I saw my passenger side HID headlight was on and off and then mostly off. I thought the HID bulb burnt out. I bought a new one and replaced it. After I installed...
Well, we seem to have a real dilema here. I just searched the service manual for your 2005 RX330 and I cannot find any reference to a ballast for the HID headlamp bulbs. According to the wiring diagram, they are wired to the Headlamp Control Relays in Junction Block #2. (Right-hand side of the engine compartment) These relays are "Solid State", so my guess is that the balast for the HID may be built in to them. These are controlled by the Body Control Module. I would recommend scanning the body control module for fault codes before doing anything else. The first step in the diagnostic chart for the headlamp system is to perform a diagnostic systems check. There is a symptom chart to follow if there are no codes present, but if there are codes in the system, you could be shooting yourself in the foot trying to follow the symptom chart without first correcting any fault codes. This is not your fathers headlamp system - it is equipped with tracking control and automatic headlamp leveling...VERY sophisticated. Also lots of stuff that can break...this is what I call JOB-SECURITY- - LOL!
Apr 08, 2011 | 2005 Lexus RX330
2005 Lexus RX330 HID ballast replacement, passenger side headlight. What is the removal procedure please?
I have a 2005 Lexus Rx330 with HID AFS headlight. My passenger side light went out. I thought the bulb burnt out, so I bought a new bulb. After replacing the new bulb, it happened exactly like my old bulb. It light up lightly and then total black out. What's wrong with it? I thought the ballast burnt. I called Lexus dealer and asked for the new ballast/transformer. Surprised me, they don't know what is it. They told me they only know the wiring harness and the socket, but not the ballast ??????? Could you tell me what do I need to replace?
Thanks,
Feb 02, 2010 | 2005 Lexus RX330
Frong lamps
If you replaced your HID (high intensity discharge) bulb and this did not work, I would then check the fuses, if they are all good, there is a good possibility that the ballast is bad. Some manufacturers won't even sell the bulbs separately, you have to buy the ballast and bulb as a set. They both seem to have high failure rates.
Mar 12, 2009 | 2001 Acura 3.2CL
Pyle 9005 8000K Single Beam HID Xenon Driving Light System Logo
74 people viewed this question
Top Pyle Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Pyle Vehicle Part and Accessory Expert? Answer questions, earn points and help others
