Question about Yealink SIP-T18P
T18p stuck, orange led blinking, sometimes green... no response to inputs, long press trans does not reset it.
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
I am getting this message: WASTE NEAR FULL The waste ink tank* (which holds the ink used for print head cleaning) is nearly full. How can I fix it - the model is a Canon PixaMP110
One of these will reset the message. I reset mine about 2 years ago and have had no need to replace or clean the waste pad.
#1
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
#2
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Jul 23, 2011 | Canon Office Equipment & Supplies
How do I change the Waste Ink collector on a Pixma MP170?
Cleaning or changing the pad is a messy project. This ink pad reset will reset the printer ink use conter to new status and your pad full message will be gone. This is a common occurance with Canon printers and the fix causes no harm. I reset my own MP470 about two years ago without incident.
This reset has been sucessful on many MP150 and simular units and should work on your MP170.
The second works on models with different control pads simular to theMP470.
Mar 27, 2011 | Canon Office Equipment & Supplies
Print head stuck on the right hand side and lamp is flashing alternate green and orange
Found this today (and it worked):
canon waste tank reset for canon i70
Below is a procedure that in most cases should resolve a Canon i70 waste tank issue
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
*** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
Canon i70 InkJet Photo Printer
Feb 21, 2011 | Cannon i70 Printer
Have pixma150. error code e3 (paper jam) do not have a paper jam or bits of paper stuck in printer. Paper will not feed into printer no matter what i do.
Perform an EEPROM reset:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Jan 06, 2011 | Canon PIXMA MP150 All-In-One InkJet...
E 2, 7
MP150/160 resetting errors:
E2-2 No paper (ASF)
Reset the EEPROM:
button pressing
4 times Green Waste ink counter reset .
5 times Orange Destination setting .
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 19, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I GET AN E 5 ERROR
button pressing
procedures below.
procedures below.
Thanks, Joe
Nov 30, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Wont print error 5100
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Turn off printer by pressing the power button
press the Resume button and press Power button.
Keep holding down Power button and release Resume button
Press Resume button 2 times then release BOTH buttons
Green lights will flash and then stop blinking.
When green lights are solid, press the Resume button 4 times.
Press the Power button and the printer should turn off, if not, press the Power button once more.
Nov 19, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Blinking ornge light
reset your printer if you try you can i will give you 6 tips
Here this manual way step by step to resetting waste ink counter on printer canon iP4000.
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. Do not release the buttons. The LED light should be green to indicate that a function is selectable.
  2. While holding the Power button, release the Resume/Cancel button, do not release the Power button
  3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  4. When the LED light is green, press the Resume/Cancel button 4 times. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  5. Press the Power button. The LED lights in green, and the reset is performed. When the operation completes, the printer returns to the menu selection mode automatically
  6. Press the power button to exit service mode.
see you can where is blinking orange light
Sep 02, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
How to reset absober full mp198
PLEASE TRY THIS, Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter
Feb 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Yealink SIP-T18P Logo
Top Yealink Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Yealink Lands Phone Expert? Answer questions, earn points and help others
