Question about Pentair IntellipH pH Controller 521377
I want to use the intelliph without the intellichlor
Pentair intellichlor salt cell keep blowing fuses
The cell will blow the fuse if it is bad. If it is a new unit call Pentair for warranty.
Feb 19, 2017 | Pentair Pool & Spa
Pentair Intelliflo vs. Need bearing replacement for front and back bearings
Pentair WhisperFlo Pool Pump Motor Bearings Replaced ...
? 2:03
www.youtube.com/watch?v=qYRNMCh_7kM
Jul 10, 2012 - Uploaded by Pump Repair Supply
More Help & Information: https://pumprepairsupply.com Watch as Joseph shows you how quite your Pentair
Sep 27, 2015 | Pool & Spa
I would think so but let your installer deal as its a chemical pump so they need to service it..
Jan 07, 2014 | Pool & Spa
How do I clean my Intellichlor salt system?
If you have the manual for the salt system it describes the process for cleaning the cell. I could tell you the process, but the manual covers it well. If you don't have the manual you can find it here... http://www.pentairpool.com/pdfs/IntelliChlorIG.pdf If you still have any questions, let me know. By the way the manual I believe assumes you have their cleaning kit. This kit includes a cap to plug one end of the cell during acid washing. This is very handy and worth the money and effort to pick one up. Should be between $20 to $30. A quick google search will give you several options, or look here http://www.nextag.com/Pentair-Intellichlor-Acid-Cleaning-548264859/prices-html
Sep 22, 2010 | Hayward EC-40 DE Pool Filter with pump
How do i take apart my pentair chlorinator to clean the cells?
If you have a pentair intellichlor, you'll need a cleaning kit or a way to cap one end. remove the union nuts at each end, cap one end and fill the cell with diluted muriatic acid. If you're not comfortable handling acid, call a pool service tech. You may have to drain and refill the cell several times to clean all of the scale out.
Aug 25, 2010 | Pentair Pool & Spa
Where is the intellichlor ic20 serial number
Inside the power box. remove the cover ... serial should be on the bottom of the cabinet on the right hand side.
Aug 20, 2010 | Pool & Spa
Pentair IntellipH pH Controller 521377 Logo
56 people viewed this question
Top Pentair Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Pentair Electrical Supply Expert? Answer questions, earn points and help others
