Question about Cycling
Mongoose fuzz extreme
What is the part that holds the wheele to the fork called? I suppose you can put your feet on them. I ran across one in very good condition and it is missing this part.
4 Suggested Answers
  • 484 Answers
SOURCE: forks
There are a wealth of online stores; search bike stores on Google.
Posted on Sep 15, 2009
SOURCE: New Mongoose 700c Men's Paver bike: Mongoose 700
Local bike shop determined that both wheels were defective. I took the junk back to Walmart and got a refund... PROBLEM SOLVED!!
Posted on Dec 30, 2009
  • 42757 Answers
SOURCE: Mongoose bmx fork
There will be a second half that runs on top of the bearings and this is held in place by a big nut that screws on the threaded bit of the fork. by your film you are missing parts.
Posted on May 31, 2013
Please i just bought a mongoose ledge 2.1 bike today and it became locked,that is the tyers cant move because is very stiff, please what do i do so that it can move?
Still not clear enough to advise you. It would be extremely unusual for both wheels (not tires) to not be able to move. I strongly advise that you take the bike to a bike shop or bike co-op for help. If you have any more details or questions please EDIT the question above or Comment on this answer, rather than putting in another question.
Nov 17, 2016 | Mongoose Cycling
Front wheel shakes bad
Hi,food for thought,have you checked that the wheele bearing is not worn(put bike on centre stand hold wheele on tyre 6 clock and pull with one hand and push with other hand)and see if you can feel eney play in the bearing,if so replace,also with bike still on back wheele spine wheele and see if it pins freely and that the discs are not warped,if not then if there is a fork brace check that it is tight ,check that the head racers are not loose or worn,with bike still on centre stand hold weele with one hand and front brake with other hand push and pull with wheele strate towards and away from bike and feel for play if there is try tightening,if not,then turn front forks left and right still holding the forks and wheele in same place do this slowly and when the wheele gose past the centre piont(strate)feel for eney notchy ness,if not bearing should be ok,if there is notchy ness replace,if its none of these I would get the wheele rechecked that it was balanced right,all the best hope you get to the bottom of the problem.
Sep 04, 2015 | 2002 Yamaha Road Star
Fork alignment
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
Delboy Garage How To Re align motorcycle forks the easy way
Motorcycle Wheel Alignment Demonstration
MOT Prepare Pass Wheel alignment
How To Align Your Motorcycle Wheels
Peachy Place How to realign motorcycle forks
Mar 07, 2014 | Bajaj Motorcycles
Mongoose bmx fork
May 31, 2013 | Cycling
Mongoose mozo m30 forks are sponggy
Change the spring to your load.
Adjust Mozo M30 Fork Suspension - Beckman Du-70 Forum
efratoium.xyz/Adjust-Mozo-m30-fork-suspension/
Results 1 - 15 of 15 - Mongoose XR 150 mozo m30 front forks rebuild. A quick ...Mongoose mozo m30 forks are sponggy on my XR150 mongoose mountain bike.
mozo??- Mtbr.com
forums.mtbr.com/shocks-suspension/mozo-167281.html
Feb 20, 2006 - 15 posts - ‎6 authors
... of a mozo m30? is it the junk im assuming came on my mongoose? ... into a halfway decent bike. and all i can get off the fork is mozo m30 ...
Mongoose XR250 Suspension Upgrades ' Bicycling Magazine Forums
forums.bicycling.com/topic/54635607127666779
Sep 30, 2012 | Mongoose Exile 26 Men's Full-Suspension...
What is the front fork?
bit that holds the front wheel and is turned by handlebars to steer.
Jul 06, 2012 | Mongoose Cycling
I bought a Mongoose Sabrosa 3x8 few weeks ago, and even thoungh I like it a lot, I've been having a few issues with the derailleurs and the rear wheel. First time I wast riding it uphill and the rear...
Quick releases skewers will hold the wheel just fine if tightened properly. They're SUPPOSED TO dig into the paint.
http://www.nashbar.com/images/nashbar/web/PDFs/QUICKREL.PDF
Deralleur and brake cables will stretch or break-in with initial use and always require some tweaking early on. Some shops build that expected tune-up into their sales offering.
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
http://www.parktool.com/blog/repair-help/categories/brake-service-and-repair
May 24, 2011 | Mongoose Cycling
I am trying to put on the front wheel but it is not fitting, there is a washer tightened on each side towards the wheel. Am I supposed to take those off before trying to put the wheel on? Otherwise, what...
If you're talking about the washers which can screw in and out you don't take them off. They hold the ball-bearings, that the axle turns on, in place. If you have moved them you should adjust them so that when you hold the wheel by the axle at each side the weight of the valve, for pumping the wheel, moves to the bottom i.e. next the ground. Any tighter is too tight any looser is too loose. You need to pull he forks of the bike frame slightly apart to get the wheel to fit between them.
If you're talking about washers that can pull off rather than screw off they can be taken off and put on the axle outside the forks next the nuts which hold the wheel on.
Apr 05, 2011 | Mongoose 16 Girls Pizazz Bike
In putting together my 26"
Loosen both nuts on front wheel.
Stand bike straight up, or set bike upside down on seat and handlebars.
With fingers on fork and thumb on wheel, pull wheel so it is centered on fork.
Now tighten one nut part way. Keep holding wheel.
You may need somebody to help.
Then tighten other nut.
Go back to fist nut and tighten a bit more.
Repeat back and forth tightening until nuts are tight and wheel is in center of fork.
Dec 25, 2010 | Schwinn Men's 26" Jaguar Cruiser Bike
Describe how to remove the front tire of a mongoose bmx bike
loosen the bolts on the ends of the axals of the wheels on the forks
Sep 03, 2010 | Freestyle Mongoose Bmx & Owners Manual -...
Cycling Logo
24 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
