Question about Troy Garden
CHANGE BELT tb516 ec - Troy Garden
I have a Panasonic Workio DPC 262 I was getting a message that the transfer belt needed to be replaced and I replaced it. But the message won't go away.
Intermediate Transfer Belt Length Detection Error Causes 1. Belt Initial Point Detection Sensor is defective. 2. Belt Initial Point Detection Sensor connector is disconnected. 3. EC PCB connector is disconnected. 4. EC PCB is defective. 5. Intermediate Transfer Belt is defective. 6. Intermediate Transfer Belt Motor is defective. 7. Intermediate Transfer Belt Motor Connector is disconnected.
Dec 22, 2014 | Panasonic Office Equipment & Supplies
Edger will start, blade won't engage
most likely, have a broken clutch spring.
Jun 02, 2014 | Troy-Bilt tb516 ec lawn edger
I have problem with my ECS A928 motherboard and I want to change it, because I can't find new one. Which other motherboard is similiar with this that I can set on my ECS iBuddie4?
Weird as it may sound, a laptop is made around it's motherboard.
Due to this, it needs to be THE motherboard that came with it.
Very seldom do laptop motherboards exchange with each other.
http://www.pchub.com/uph/laptop/64-25558-3962/ECS-A928-Main-Board-Motherboard-.html
Just a thought. Motherboard may be bad too. Hard to say exactly, unless you have it in front of you, and diagnose.
Out of curiosity what is wrong with the motherboard?
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Post back in a Comment.
Regards,
joecoolvette
Mar 15, 2013 | Computers & Internet
How to replace vacum belt on new Sharp EC-TU5306
remove bottom plate and pull brush roll out. buy a replacement belt and follow procedure to put back on. sounds like you have a clogged hose also.
Jan 29, 2013 | Sharp EC-TU5306 Bagged Upright Vacuum
I CHANGE THE WATER PUMP AND TIMING BELT BUT AFTER I FINISH THE CAR SHOWS CH EC K ENGINE AND TEMP. LIG HT.IS THERE ANY THING TO RESET?MY CAR IS A JETTA 03 2.O
To reset unhook the battery cables and check relay switch sometime the check engine light never go away or there something wrong.
Lisa
Sep 27, 2012 | 1995 Honda Accord
Every thing works nicely and the suckshion works great when you put your hand there however when i try to vacuum it doesn't pick up anything
Try to change the belt, you can use a panasonic UB or UB8 belt which should be easy to find. It sounds like your belt is stretched and slipping on the brushroll when it comes in contact with the floor.
Oct 26, 2009 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Most Vacuums has the belt in the middle of the rotating brush. This one has it on the left side and doesn't go around the brush. Mindboggling !
The belt runs from the metal motor pulley straight to the brush roll. To change the belt you remove the bottom plate, pull the roller straight up, then you put the belt on the metal pulley and then on the roller and you push it back into place.
Jul 05, 2009 | Sharp Twin Energy EC-TU4606 Bagged Upright...
I need to bay a belt
They have them at vascumn cleaner outlet:
http://www.vacuum-outlet.com/belts/sharp.html
There is only one for all uprights made by sharp and another for the power nozzles.
Jun 03, 2009 | Sharp EC-S2365 Upright Vacuum
Garden Logo
165 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
