Question about Pyle 9005 8000K Single Beam HID Xenon Driving Light System
My ballast keeps malfunctioning. I put a new one in and it lasted about 15 minutes. Hid spotlights . What can you suggest that I can look for?
  • 2,544 Answers
Let's start backwards.
First, look at your grounding system.
Be sure it is using heavy gauge wire, and that there is a direct connection with the car battery (or truck, or whatever). All new vehicles are more and more made of non-conductive material like plastics and fiberglass, etc., so that can interfere with all things electric.
Then, see about the wire and the connectors leading to the lights. Do those wires need to be bigger or heavier?One way to tell is if any wire in the system gets warm whilst it is being used.
Finally, be sure the ballast is "stronger" or "heavier" than the load ( the lights) due to the possibility of overload because of a mis-match.
Be blessed.
Posted on Aug 12, 2013
Headlights do not work high or low beam all other lights work
Re: Condensation in Sienna Right Headlight.... - Toyota Sienna Forum
www.siennachat.com/.../4606-condensation-sienna-right-headlight.html
Mar 10, 2009 - 15 posts - ‎9 authors Over the years, I was not a frequent visitor to SiennaClub...but when I did visit, it was... in the right, passenger-side xenon HID headlight of my 2004 Sienna...the light has... Check with your dealer and see if they can do anything about it. .... :o The HID bulb is also a PITA to remove because you are working ... Re: 2004 Sienna no brake lights, radio, heater/AC ...
Jan 4, 2013
Thread: HELP: Both Low Beams don't Work
Nov 27, 2011
Thread: 2000 sienna drl and/or headlight issue
May 7, 2010
Automatic Headlight Option: Useful or Not?
Mar 3, 2010
More results from www.siennachat.com
Toyota 2004 Sienna repair: Replacing HID ballast or ...
toyotarepairsemipro.blogspot.com/.../replacing-hid-ballast-or-computer....
May 1, 2010 - Replacing HID ballast or computer control lighting for the Headlight. Just got a ... Up until now, I did not know I had the option of seeing twice as far with Xenon. Also up to ... In the end after buttoning everything up, the light did work fine. .... Howdo you determine if you have a HID or non-HID light? Reply ...
Oct 15, 2015 | 2004 Toyota Sienna
How to install HID to honda xrm 125
Did you buy a HID bulb or did you buy the kit with the ballast etc? Usually an HID lamp will come with a ballast and wiring loom which is per fitted with relays etc. you would normally plug this loom into the headlight socket of your bike's wiring and then tidy the ballast etc behind the fairing and replacing your bulb with the HID lamp. If you don't have the loom and ballast they're pretty easy to come by on the auction sites.
Jul 14, 2014 | GAS EC 125 Motorcycles
How do I replace front HID light bulb? and where can I purchase parts for replacing?
  1. INSTALLATION GUIDE:
  2. BMW E38 99-01 HID TYPE 7 Series 1PC Halo Amber Projector Headlights
  3. Parts Identification:
  4. Projector Headlight
  5. Halo & L.E.D.
  6. Bottom of the Headlight:
  7. Ballast Bracket, Halo Wires(red/black)
  8. Turn Signal Adaptor
  9. TOOLS REQUIRE
  10. 10mm - 8mm socket
  11. Philip Screwdriver
  12. Crimper/Pliers
  13. For more information about how to install your vehicle, come visit our youtube page on
  14. http://www.youtube.com/spyderauto
  15. Remove the facotry headlight from the BMW. First remove the front panel cover below the headlight to access the bottom screw of the headlight housing. There is also two screws on the top of the housing.
  16. Once you have remove the headlight, turn the headlight around and remove the bracket that holds the Ballast. Then remove the ballast using a philip screwdriver.
  17. Unplug the wire from the ballast, and then remove the Xenon Plug from the housing. Put the Ballast aside.
  18. Carefully remove the D2S Xenon Bulb from the factory housing. Once you have remove the bulb, transfer the bulb to the Spyder headlights.
  19. Remove the bracket from the Spyder Headlight, and then install the ballast on the housing like the original. Once you have put the ballast on, put the bracket back on.
  20. Remove the Panel Cover bracket from the original headlight to the new Spyder Headlights as shown here.
  21. STEP:
  22. Install the Spyder turn signal socket if the orignal does not fit, unplug the factory plug from the harness and plug the new one on.
  23. Install the Spyder Headlight back on to the vehicle. Plug the Harness back on, the halo/L.E.D. Wires is connect to the Parking lights. These wires are optional to your vehicle, you do not have to wire them together.
  24. Factory Xenon Headlight
  25. Spyder Projector Headlight using Factory Xenon Lights
May 21, 2014 | BMW 335i Cars & Trucks
I have problem with hid light
follow this link to u-tube video not the exact vehicle but the principle will be the same,or search for your exact vehicle
How to replace low beam xenon HID bulbs 2006 BMW 330i
May 08, 2014 | 2007 BMW 335i Coupe
I have hid spotlights and the ballast seems to malfunction. I have replaced the ballast only to last 15 minutes. Why is this happening?
What kind of vehicle are we talking about? Does it happen to both lights?
Check the voltage with a multimeter going into the ballast. Should be a constant 12V. If voltage is good swap ballasts and see if issue stays with ballast or side. If ballast is still behaving poorly its time for replacement.
Aug 01, 2013 | Pyle 9005 8000K Single Beam HID Xenon...
99 Grand Cherokee headlights keep popping fuese
The circuit load is much higher with the HID lights, you need to rewire the headlights to a large gauge wire.
Jul 03, 2012 | 1999 Jeep Grand Cherokee
How to install hid on a bmw 325xi 2006
INSTALLATION GUIDE:
Projector Headlight
Halo & L.E.D.
Turn Signal Adaptor
TOOLS REQUIRE
10mm - 8mm socket
Philip Screwdriver
Crimper/Pliers
STEP:
STEP:
pls vote an diam giving you link also for better help BMW e46 HID Headlight Replace
Oct 15, 2009 | 2003 BMW 325
Pyle 9005 8000K Single Beam HID Xenon Driving Light System Logo
74 people viewed this question
Top Pyle Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Pyle Vehicle Part and Accessory Expert? Answer questions, earn points and help others
