Question about IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
I plugged the Gigabank into my Mac laptop and it said it was backing up my entire computer contents. I then erased all of my pictures (assuming they were backed up) in order to make space for new softward. I loaded Mac OS X Snow Leopard. I now have something called a 'time machine' which appears to be a back-up but my pictures are not there. Are these 2 different backups? How do I access the Gigabank hard drive to look for my pictures? Help!
4 Suggested Answers
SOURCE: hard drive backup
Dear aspec,
First u try to perform scandisk the lap hdd. you also confirm wheather the bios is fully supproting the 250gb drive.
Tapa
(91-9830114059)
Posted on Dec 13, 2007
Pegleggedous
  • 15 Answers
SOURCE: backup hard drive to an external hard drive
"what the error actually says is, you have either run out of space, or the backup file (.bkf) is too large for this disk. note: if the disk is formatted with FAT32, the maximum possible size for the backup file is limited to 4 gigs."
That error means that the FAT32 file system only allows 4GB files or smaller to be transfered. The chance that the backup file (.bkf) is larger than 4GB suggests that this file is causing your problems. You could try manually copying around that file (selecting all files from that folder except the large one) and see if that works.
Usually you will get many errors copying a drive directly as system files will be inaccessible and whatnot. Your best bet is to limit your copying to "C:\Program Files\" and "C:\Documents and Settings\", assuming you have Windows.
Posted on Jan 15, 2008
Geekman
  • 32281 Answers
SOURCE: mac cant find the hard drive
Clicking Hard drive When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Posted on Oct 23, 2012
Can't erase on my olympus WS-100
Do you plug into your computer? If so, you can erase from there.
Does your recorder have a "format" setting? That will erase entire contents.
May 26, 2015 | Olympus WS-100 Digital Voice Recorder
Erase my photos by mistake from my phone
So which kind of phone are you using?
If you are using an iPhone, I can help you figure it out.
Way 1: retrieve pictures from iPhone with iTunes backup file
1. Connect the iPhone to the computer with a USB cable.
2. Open iTunes.
3. If you have a new or erased iPhone, iTunes will prompt you to restore from backup.
4. Otherwise, Control-click on your iPhone under DEVICES in the left menu.
5. Select Restore From Backup...
6. Choose the backup you wish to sync and click the Restore button.
Way 2: recover photos from iPhone with iPhone data recovery program.
Read more: how to retrieve deleted pictures from iPhone with Macgo Mac iPhone Data Recovery
May 10, 2014 | Cell Phones
How to initialize disk
Do you want to initialize the hard drive on your Mac? Or an External Hard Drive?
Assuming External Hard Drive:
  1. Go To Applications.
  2. Open Utilities Folder.
  3. Open Disk Utility (You Should Already Have External Drive Attached To Computer).
  4. On left panel select the top name of the external hard drive.
  5. On the upper tabs on the right side of the panel select Erase.
  6. ***Note this will delete any content on the external hard drive
  7. Under Format - Choose Mac OS Extended (Journaled)
  8. In Box Below Name The External Hard Drive whatever name you want it to be.
  9. On bottom right select erase.
The External Drive will be Mac Compatible.
Let me know if you were trying to accomplish something else.
Jan 04, 2014 | Apple MacBook Air
I have a RW CD with info on it. I want to erase the current info and burn audio to CD using a Mac
  1. Insert the disc in the optical drive of your computer.
  2. Open Disk Utility, located in Applications/Utilities.
  3. Select the disc in the column on the left and click Erase.
  4. Select Quick Erase if you don't want to overwrite the old contents with zeros.
  5. Click Erase.
Mar 25, 2011 | Apple MacBook PC Notebook
Hi i have a smartdisk crossfire external harddrive which I have used to save my photos from a windows based pc. However I have now purchased a IMac and wish to be able to load my photos on to this. When I...
congratulations on switching to mac!plug the external hard drive back into the PC, and copy the photo's to the PC, now plug it into your mac and go to applications-utilities-disc utility, the external drive should be listed on the left,click on the erase tab, at the volume format select "ms-dos file system", then click the erase button, this will erase everything on the drive and set it up so your mac can use it (but its ok because you moved all your pictures to the PC) now you can go back to the PC and copy the pictures on the external drive and it will work with your mac.
Jul 04, 2010 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
Safari cannot find the Internet plug-in. The page ?TV & Radio? has content of MIME type ?application/x-mplayer2?. Because you don?t have a plug-in installed for this MIME type, this content can?t be...
What i am assuming, is that you are running a mac. Safari tends to be part of the mac operating system. There is use to be safari for PC, but apple removed support for it, you can technically use the browser on PC, just the old unpatched one (highly not recommended).
1) Run a mac OS update, generally the update section is in the apple app store. See if there is any updates for Safari as well for the MAC OS, update and see if it resolves the issue.
2) More or less if the OS/Safari is slightly older, the app store will auto detect if your current MAC can be upgradable to the new OS with the missing plug in for safari, you can do this without losing any files as long as the power adapter is plugged in throughout the entire upgrade process.
Feb 18, 2018 | Apple MacBook Pro PC Notebook
External wont open on mac
if you have used the hard drive on a windows pc some format types cannot be recognized by mac
follow these steps to make it usable by mac and windows
*THIS WILL DELETE ALL FILES ON THE EXTERNAL HARD DRIVE AND DOE NOT ALWAYS WORK
Go to Finder -> Application -> Utilities
Double click for Disk Utility
Select the external Hard Disk you wish to format at the left column
Click on the Erase tab
At the “Volume Format” select “MS-DOS File System”
If you confirm to format your hard disk for mac and windows, Click on “Erase” button.
Pop up window will ask to verify the erase procedure. Click the erase button again in the window to start the erase process.
Once the erase process finish, your external hard disk may be able to use in Mac and Windows.
Mar 20, 2010 | Apple iBook G4 (Z0AZW13397068) PC Notebook
How can I format this to my mac???
Most external hard drives are formatted to FAT 32 for use in both Mac and PC. If you wish to format it for your Mac only (it will perform better),
Before you begin to use your new external hard drive with Aperture, reformat it to the Mac OS Extended file system:
  1. Be sure your drive is attached and mounted.
  2. If you have already written any data to the drive, back it up before proceeding to the next step.
  3. In the Finder, choose Go > Utilities. The /Applications/Utilities folder will open.
  4. Launch Disk Utility.
  5. Click the icon for your external hard drive in the sidebar on the left.
  6. Click the Erase tab along the top of the window.
  7. From the Volume Format menu, choose Mac OS Extended (Journaled).
  8. Enter a name for the external hard drive in the Name field.
  9. Click the ERASE button.
Dec 17, 2009 | IO Magic Corporation GigaBank (I250HD35)...
Jump drive won't allow me to erase the contents of Memorex product
hi,if you want to erase all the data can your format it?
or try to erase data on another computer
hope this helps :-)
Aug 24, 2008 | Memorex Electronics - Others
Downloading pics with usb drive
Format prompt comes due to the card's data access status.after back up your picture at MAC computer you can proceed for format (FAT 32 Recommended). Also you can use camera to format pictures. Next time it wont show format prompt
Goodluck
Jun 19, 2008 | Olympus SP-550 UZ Digital Camera
IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
42 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
Mohamed Ismail
Mohamed Ismail
Falling star
M_Butkus
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
