Question about Campbell Hausfeld Air Tools & Compressors
I need to replace the pump on my Campbell Hausfeld Air Compressor mdl# FP209402 but I can only find pump/motor assembly. Does anyone know if or where I can purchase just the pump?
digritz
  • 530 Answers
SOURCE: i need motor brushes for campbell hausfeld WL611105AJ air comp.
If you can find a match to the brushes that came out of the motor they will work. When I say match, I mean the size. Height, width and depth, length only needs to be close to allow for wear over time. The longer the brush the more wear you will get. If you can't find the exact size then you can always file a larger brush to fit. I just had to do that for a small motor in my shop-vac, works great. Also another consideration is how the line coming off the back of the brush connects to the Stator. If you can't match the connector soldering it is fine or crimp the appropriate connector to it. Beyond those two elements brushes are pretty much the same.
Your biggest problem is finding an assortment of brushes. Some hardware stores will carry some, (check the bins with all the small nut, bolts and other connectors), also automotive parts stores carry them, (for alternators),. Your best bet would be an electric motor repair shop.
Good luck
Posted on Jun 11, 2009
  • 98 Answers
SOURCE: I have a Campbell Hausfeld Quick Air DK618300AV without a fuse...
3.5 amp fuse
Posted on Jul 22, 2009
SOURCE: Campbell Hausfeld Air Compressor won't start
The compressor starting problem is common to most of the small portable compressors. Poor design and undersized components are to blame. If you have one of these units i suggest looking into a product called the Smart Start by Conrader Valves. It is interchangeable with the standard air filters and allows the compressor to start without fail. check it out- www.conrader.com.
Posted on Jul 23, 2009
SOURCE: electric compressor motor problem
Unloader valve on switch. That switch is not bleeding off cylinder head pressure,when it shuts off.
Posted on Apr 07, 2010
Testimonial: "thank you, this has had me stumped for days now. simply flipping the pressure switch off then back on again solved the problem. "
SOURCE: Need a copy of a manual for an air compressor
Go to Campbell web site,then call them
Posted on Jun 01, 2010
My Campbell hausfeld air compressor runs to 20 psi and then motor starts to bogg and then stops but motor still trying to run? Please help!
dont know size of unit ---if 220 check power in- under that will bog motor same with 110v --if using extension cords to long a feed from source and your voltage drops from resistance in wires ---motor may need service oil bearings --same with compressor motor oil change/needs oil added
Jul 12, 2016 | Campbell Hausfeld Air Tools & Compressors
Piston ring for campbell WL506206AI
Most parts lists only show the motor/pump assy (WL373000AJ) for your compressor. Campbell-Hausfeld does however have a breakdown of the motor assy and shows the piston/cylinder assy (WL210300SJ) being available for your compressor. It would be available from any C-H repair center or online at sites like eReplacementparts.com. That is the only way the piston, piston ring and cylinder parts are available, you cannot buy just the piston ring even though that's the main fail part in this assembly.
Dec 07, 2013 | Campbell Hausfeld Extreme Contractor...
My 5 hp campbell hausfeld model hl 7017 pumps up to pressure but when it drops the motor starts but the compressor wont turn the belt just slips until pressure drops off to about 30 psi
Your tank check valve is not closing properly. It's a valve on the tank where the air line from the pump head attaches, It allows air in but not back out of the tank through the pump. When the pressure swtich turns the motor off, valve on the pressure switch lets the air out of the head so the motor can restart without any pressure in the pump head when the pressure in the tank drops. On rare occasion, you can clean the check valve out and it'll work again, more often than not you have to replace it.
Nov 24, 2012 | Campbell Hausfeld Maxus 60 Gallon (Belt...
Can't find reed valve replacements for 1999 campbell hausfeld?
I am a C-H service center and using the model number VS5006 I got the following:
- Your Pump Part Number was originally VS260000KB, now it's VS260000SJ. That's the complete pump and suggested retail is $199.99.
- The valve kit for that pump is part number VS261000AJ. The kit includes all the gaskets, reed valves and valve plates between the head and cylinder, suggested retail is $33.80.
You can go to http://www.ereplacementparts.com/ and, using the model number VS5006, see a breakdown of your compressor or, using VS260000SJ, see a breakdown of the pump to make sure we're talking about the same air compressor and pump. The parts are available through them or you can use the part numbers to search other sites for better prices.
Feb 21, 2012 | Campbell Hausfeld 5HP 20 Gallon Single...
Need to replace bearing on pump/motor unit
if this is oi les pump it was not designed for bearing replacement on the motor. check with your local elected repair shop thy my be able to help you
Oct 14, 2009 | Campbell Hausfeld Air Tools & Compressors
Air compressor not working, campbell, hausfield turns on but doesn't make loud noise it used to seems like it is not kicking in. It just sounds like a loud vacuum cleaner. Campbell Hausfeld WL6501 13...
If your motor is running and not the pump, the malfunction is either in the pump or the coupling between the motor and the pump.
Some of these compressors are manufactured so cheap now that there can be just a set screw that is loose and the motor shaft is spinning free inside of the crankshaft.
If you drain the oil out of the pump and take off the pump crankcase cover, you should be able to see the problem.
Apr 11, 2009 | Campbell Hausfeld Air Tools & Compressors
Air Tools & Compressors Logo
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
