Question about Fire Magic FireMagic Grill
I have a Custon II natural gas hook up. When I light the right side burners flames are extrememly low. When turning on the left side burners there are time when the grill shuts down. If I use just the right side flames remain low. I have replaced the burners thinking that was the issue, but no better results.
3 Suggested Answers
gcken
  • 140 Answers
SOURCE: gas is coming out of house but dosen't seem like
It can be 2 things bigger gas line to the grill or the regulator is bad
Posted on Jul 07, 2010
cadesertmax
  • 274 Answers
SOURCE: I have a fire Magic
I don't know how old your grill is, but as grills age, the gas ports in the burners begind to clog and corrode. Flame travesl around the burners like dominoes when you stand them up and knock them down, one port lights the next, etc. All burners light on just one side and there are ports that are designed to take the gas from the outside of the burner to the inside and from one side to another. Depending on how clogged the ports are, you can clear them using a straightened paper clip, or a drill with a bit. Be careful not to make the gas ports larger.
Posted on Mar 20, 2011
Burner comes on at 3.any lower goes out.6 inch yellow flamestarts on rite side under pressure.not burner rite of burner
Troubleshooting :: AZ Patio Heaters and Replacement Parts
azpatioheaters.com/pages.php?pageid=11
How do I replace starting striker switch on a tall patio heater? How do I clean ... Why is my burner flame low? Why does ... Why does my pilot light, but goes out when heateris turned on high or low? Why do I get a yellow flame and black smoke? ... 6. Can I convert my LP gas patio heater into a natural gas patio heater? NO.
Nov 17, 2015 | Heating & Cooling
Natural gas grill low flame
Did you change the reg , lpg burns at 14 inches wg nat gas burns at 4inches wg
Feb 16, 2013 | Char-Broil Commercial Stainless Steel...
Low flame on left front burners high flame onright front burnners
That is food/grease buildup. Clean the holes. TURN OFF GAS to stove, then just clean the holes in the burners with a soft wire brush. Then turn gas back on and immediately relight pilot lights. If that sounds scary, call your gas company, they might come out and help.
Dec 09, 2012 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
REAR RIGHT AND LEFT FRONTBURNER WON'T IGNITE
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
May 12, 2009 | Magic Chef CGR3742 Gas Kitchen Range
No flame on left side/main valve. Right side lights, flames up
Try taking out the orifice on the burner that is not lighting and make sure it isn't blocked.
Mar 12, 2009 | Heating & Cooling
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Fire Magic FireMagic Grill Logo
27 people viewed this question
Top Fire Magic Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
john h
Are you a Fire Magic Grilling Expert? Answer questions, earn points and help others
