Question about Campbell Hausfeld FP209039AV Pump/Motor Assembly
Can I purchase the pump without the motor? Campbell Hausfeld Air compressor Model # FP209402 PUMP/MOTOR ASSEMBLY FP209039AV
    New Friend:
  • 3 Answers
Probably and you could also an entire pump that's good for parts. might be cheaper.
Posted on Aug 01, 2013
4 Suggested Answers
  • 104 Answers
SOURCE: Compressor not wired, no schematic or instruction in manual
There is a schematic under the cover of the elecrtrical connection box. Remove the top of the box ( typically one nut on top of the pressure regulator) and look under the cover you removed.
Good Luck
Posted on Feb 07, 2009
SOURCE: Campbell Hausfeld compressor has trouble starting
Sounds like your unloader valve is not releasing pressure in the line to the compressor. When it shuts off after filling up if you do not here the psssht that they make when it is releasing the air in the line to the pump. then the line is still full of pressure which makes it hard for the motor to start. Check your unloader valve.
Posted on Apr 14, 2009
Need to see a diagram of a campbell hausfeld clean power 37 unloader valve
Most all of the manuals for campbell hausfeld tools are found at www.chpower.com , just look for your model number. Also , campbell hausfeld does not make all their pressure washer pumps. Yours may be another brand. To find who makes yours look on ebay. Make search for {pressure washer pump only} and look for one that matches yours. Then look for that breakdown. Good lu ck.
Oct 12, 2017 | Campbell Hausfeld Air Tools & Compressors
Piston ring for campbell WL506206AI
Most parts lists only show the motor/pump assy (WL373000AJ) for your compressor. Campbell-Hausfeld does however have a breakdown of the motor assy and shows the piston/cylinder assy (WL210300SJ) being available for your compressor. It would be available from any C-H repair center or online at sites like eReplacementparts.com. That is the only way the piston, piston ring and cylinder parts are available, you cannot buy just the piston ring even though that's the main fail part in this assembly.
Dec 07, 2013 | Campbell Hausfeld Extreme Contractor...
My 5 hp campbell hausfeld model hl 7017 pumps up to pressure but when it drops the motor starts but the compressor wont turn the belt just slips until pressure drops off to about 30 psi
Your tank check valve is not closing properly. It's a valve on the tank where the air line from the pump head attaches, It allows air in but not back out of the tank through the pump. When the pressure swtich turns the motor off, valve on the pressure switch lets the air out of the head so the motor can restart without any pressure in the pump head when the pressure in the tank drops. On rare occasion, you can clean the check valve out and it'll work again, more often than not you have to replace it.
Nov 24, 2012 | Campbell Hausfeld Maxus 60 Gallon (Belt...
Can't find reed valve replacements for 1999 campbell hausfeld?
I am a C-H service center and using the model number VS5006 I got the following:
- Your Pump Part Number was originally VS260000KB, now it's VS260000SJ. That's the complete pump and suggested retail is $199.99.
- The valve kit for that pump is part number VS261000AJ. The kit includes all the gaskets, reed valves and valve plates between the head and cylinder, suggested retail is $33.80.
You can go to http://www.ereplacementparts.com/ and, using the model number VS5006, see a breakdown of your compressor or, using VS260000SJ, see a breakdown of the pump to make sure we're talking about the same air compressor and pump. The parts are available through them or you can use the part numbers to search other sites for better prices.
Feb 21, 2012 | Campbell Hausfeld 5HP 20 Gallon Single...
Need to replace bearing on pump/motor unit
if this is oi les pump it was not designed for bearing replacement on the motor. check with your local elected repair shop thy my be able to help you
Oct 14, 2009 | Campbell Hausfeld Air Tools & Compressors
Air compressor not working, campbell, hausfield turns on but doesn't make loud noise it used to seems like it is not kicking in. It just sounds like a loud vacuum cleaner. Campbell Hausfeld WL6501 13...
If your motor is running and not the pump, the malfunction is either in the pump or the coupling between the motor and the pump.
Some of these compressors are manufactured so cheap now that there can be just a set screw that is loose and the motor shaft is spinning free inside of the crankshaft.
If you drain the oil out of the pump and take off the pump crankcase cover, you should be able to see the problem.
Apr 11, 2009 | Campbell Hausfeld Air Tools & Compressors
Campbell Hausfeld FP209039AV Pump/Motor Assembly Logo
446 people viewed this question
Top Campbell Hausfeld Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Campbell Hausfeld Plumbing Expert? Answer questions, earn points and help others
