Question about Zenith VR4206HF VHS VCR
The cst in light keeps flashing until the machine shuts down it won't play either
I have a dyson DC 3.5 model 11-6300 d1 it will run about 30 sec then shut down the green light will keep flashing whenever I tried to run it then shut down
the flashing light is to tell u that there is something blocking the suction of machine , most times its a full dust cup or hepa filter blocked this if allowed to continue will over heat the motor so it shuts off to prevent motor damage
Nov 30, 2016 | Dyson Vacuums
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Shuts off and on while trying to watch, the power light flashes 30 times when off then the tv comes back on again
Power supply trouble. The TV keeps trying to start then operates for 2 seconds and shuts down. The cycle keeps repeating until eventually the TV will not start at all.
Nov 27, 2013 | Sony KDF-60X5955
Cst in
Please tell me what Cost in flashing
Terry
Jan 09, 2013 | Emerson EWD2203 DVD Player/VCR
Uniden 6.0 phone keeps flashing incoming call but there is no call
press menu
scroll down until you get global settings
press menu
scroll down to vmwi reset press menu
scroll to yes
press menu
then press end
write this down as it will continually happen
Dec 06, 2017 | Uniden DECT 6.0 Cordless Phone ID
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
The cst in light keeps blinking how to turn it off
Hello
I managed to find a PDF manual for your VCR Combo, However i couldnt find anything to indicate a reason for the Cst in light flashing. I did find however find that the TIMER REC Light flashes if T-SET is pressed for a timer recording, but there is no tape in the DVD/VCR. It also flashes when all timer recordings or One-Touch Recordings are finished. So possibly this could be the light you see flashing.
The PDF can be found Here
Hope this helps
Mar 06, 2011 | Symphonic WF803 DVD Player/VCR
What is CST? light keeps blinking and the power won't stay on. how do i get it to turn off?
There are lots of meaning of CST, it could be:
- Central Standard Time
- Computer Simulation Technology
- Cell Signaling Technology
I'm not sure, but I have not heard of TV that requires to have a time settings. If the TV needs it, then it could be the Central Standard Time.
However, flashing light could mean that there is a lamp failure that shuts down the high voltage supply to your screen.
Check back lights ( there are small diameter lamps behind the LCD screen). Replace the defective back lights and that should fix the problem.
But if you're not sure about checking it, I would suggest to contact the manufacturer or a local repair shop and have them repair it.
Mar 20, 2010 | Televison & Video
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Televison & Video Logo
    27 people viewed this question
    Top Zenith Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
