Question about LG Dishwashers
Lg ld1419m2 dishwaser has drain fault. Hose looks clear motor sounds good.
5 Suggested Answers
joe_lishman
  • 192 Answers
SOURCE: Dishwater not fully exspeeling from dishwaser
If nothing obvious like blocked / obstructed outlet pipe
You need to check if the outlet pump motor in line with the outlet hose is spinning when in the outlet mode. First check if it is spinning by looking at it and see if the small fan is spinning FREELY. If it is turnning this means that it has power and the internal "impeler" that pushes the water out has become loose. Remove the pump (easy job) and repair. If it does not spin you need to determine if the 2 push on terminals have power on. If there is voltage and the motor does nut spin this indicates that the pump motor is open circuit and must be replaced.
Posted on Mar 26, 2010
heatman101
  • 43501 Answers
SOURCE: water not draining after wash cycle. Pressed
Checkout this tip that I wrote about that problem...
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Apr 15, 2010
rickead1
  • 1998 Answers
SOURCE: whirlpool dishwasher will not drain.
here is the schematic for your entire machine http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Dishwasher-Parts/Model-GU2400XTPT7/1198/0130000?searchedModel=GU2400XTP&blt=06 have you check the drain pump which is seperate from the motor? the motor basicly runs the sump with water going on the inside of the machine the drain pump is drains out the water part number 17 in this next diagram if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks again Rick
heres the pump and motor section link http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0512156-00008.png
Posted on Feb 03, 2011
david_sunrid
SOURCE: dishwasher problem
Change the "Auto-start" switch. Or the "reid switch".
Posted on Jan 05, 2012
Error meaasage 0E Drain Error what to do?
This OE error or fault code indicates that the machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Finally, if the drain line is clear and the pump seems to be clear, you may need to replace the drain pump assembly.
Mar 01, 2016 | LG 4681EA2001D Original Water Pump Drain...
I have wm1814cw lg front loader washing machine with oe light on and not draining we have clean filter unclogged drain hose and reset by unplugging and holding down power putton and start button als
The OE error or fault code indicates that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Sep 16, 2014 | LG Washing Machines
My washer isnt wanting to pump water out like it use to and the spin cycle isnt wanting to spin ,the pumps is making a loud un normal sound.i checked filters they are fine.lots of lent is coming out w
Your drain motor is likely failing slowly. Lint cleaning is a great maintenance step but over time there's lint and debris build up on the motor and probably drain lines. Check your drain hose to make sure it's clear as an easy fix. Otherwise look to getting quotes on parts replacement, starting with that motor.
Nov 09, 2013 | LG Washing Machines
Will not drain. it does'nt look like its spinning very fast.
The washing machine not draining water.This problem is related to few possibilities. 1) The drain pump is got loose to the drain hose. check the connection from drain hose to drain pump. 2) The drain is blocked by any thing.Like cloth or any thing like metallic nails or coils etc etc. 3) The drain hose is got blocked./The drain hose is not letting the water to enter the drain pump. In most of the cases the drain pump has to be removed and checked for any kind of blockages.Also if the machine not draining can effect the spin cycle.But other possibilities for no spin or slow spin are faulty or broken motor coupler or weak spin motor.The motor coupler and motor both can be possible,if the drain pump and drain hose both checked ok.This will clear the fault. ----------- Keep updated with any more queries.Thanks,.
Oct 14, 2010 | Washing Machines
I unscrewed the lower panel on the front and cleaned out the large black round cap on my LG Tromm Washer. I blow thru the small rubber hose and it sounds clear. I am still getting the OE when getting to...
As you know OE is drain error. you still have a drain problem and this could be because the pump impeller has a coin or similar jamming it, or it could be that the pump motor itself is failing. If the drain hose is clear and not kinked and the pump is working the machine should drain........Good luck....Nomess
May 27, 2010 | LG WM2688HWM TROMM SteamWasher
Mar 26, 2010 | GE Nautilus 24" Built-in Dishwasher
LG front load washer does not drain after cycle. Motor runs,drum moves forward and reverse but seems pump doesn't pump. Drain hose clear as well as filter area.
Check for 120 volts to the pump motor while in drain mode, if the pump does not run, or just hums, replace the pump motor. Some LG's have both a recirculating and drain motor on the pump casing, so be sure to replace the correct motor.
Dec 30, 2009 | LG WM-2277HW Front Load Washer
We have a mdb7600aww dishwaser that does not clean proper removed strainer, impeller and water sprayers all looked good. soap residue on the dishes and dispenser still has soap in it
Mine would not drain properly, so I am not sure if that correlates to your problem (water pooled in bottom). I pulled the drain hose off my garbage disposal and put a long wood dowel through it to clear any blockage (about 3 feet long). It cleared the blockage and the dishwasher drained fine after that! I have had to do this a few months later, so it must be a chronic problem.
I have had problems with impeller blockage too, and have had to take that apart. I HATE this dishwasher for the continual problems encountered. NEVER a "Paytag" again.
Nov 24, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
Fault DE ( motor overload?)
DE error code stands for "Drain Error" resulting from no or too long a drain time. Open access door at lower left on front of machine. If small hose is not plugged, you can drain the remaining water out of it, then remove the large screw thing there. (it's the filter.) Clean it and replace. Test. If filter was clear, you may need to replace pump motor.
Mar 30, 2009 | LG Washing Machines
Just purchased and installed the LG LDS4821 dishwasher, instantly got the OE error code when we tested it. After following troubleshooting tips and calling customer service, error code still not resolved....
Try a test cycle with the end of the drain hose placed into a bucket. If the dishwasher does not pump out then, call for warranty service (In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000). If the dishwaser does pump out into the bucket check the entrance of the drain. (if it is draining into a disposer, there is a knock out plug which has to be removed) By the way, that is not an OE error, it is actually a DE (drain error).
Mar 01, 2009 | LG LDS4821WW 24 in. Built-in Dishwasher
Dishwashers Logo
59 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
