Polar wind replacement parts - Heating & Cooling
A manual for Polar Wind model YPC1-09C-1 portable ac unit
Try Googling (Polar Wind)YPC1-09C-1)(manual) without parens.
Apr 19, 2018 | Heating & Cooling
I'm looking for a operating manual for a polar wind dehumidifier
Try Googling (polar wind)(model)(manual) without parens.
Jul 01, 2017 | Dehumidifiers
Need wiring diagram for a single phase brook motor n a broomwade compressor
I suggest you contact Brooks if they are still in business. If not there is lots of motor info on the net.
Traditional single phase motors are fairly straightforward and similar to each other. The main thing to watch out for is to have the start and run windings wired with the same polarity. If the polarity is reversed on either winding the motor will run backwards.
Feb 06, 2016 | Air Tools & Compressors
I have an Onan 3600 microquiet lp. I made the mistake of hooking up a jumper box to the battery with the cables crossed,now it blows the 5amp fuse that supplies power for starting. hope I didn't fry...
It certainly sounds like you have damaged the control board. If you cranked it with reverse polarity, there is a good chance that you have rotor winding damage also. If not you still may have to flash the rotor windings to ensure a correct polarized field. That involves hooking a battery for a couple of seconds to the rotor brushes (with correct polarity) with rotor brush wires disconnected. Only do this if there is no output voltage after you replace the control boards. Bad mistake :)
Aug 05, 2013 | Onan Microquiet Generator Lp Vapor 3600...
Polar wind window air conditioner manual
Polar wind 5000 BTU window frame enclosure, where can I find one?
Jul 18, 2013 | Heating & Cooling
Polar 78x how to wind knife up manually
HOW TO FIX COME ERROR LIKE THIS
WARNING ! KNIFE AFTERRUN (703)
MACHINE POLAR 78X
KINDLY ASSIST ME
Aug 11, 2011 | Office Equipment & Supplies
The circut board on my 6250 blew apart so i replaced it do i need to polarize it because i still have no voltage
I have seen this often, somtimes the circuit/s that power the board will burn out. Usually happens when using generator for powering large air comperssors or equipment that use capacitors. One circuit powers the board, some generators have a second winding for measuring voltage for regulator function. Service center will give you required ohm reading for both windings. For estimate only reading may be between 6 and 9 ohm. Also check that windings are not open or short to ground. Check polarity of brushes, you cannot swap wires to brushes. Circuit board should have come with instruction sheet for wiring. Good luck and post again if you have more questions.
Jul 02, 2010 | Coleman Powermate Premium Plus 6250W...
Fail to spin
Yes and no :) It's connected in series with a set of centrifugal switch contacts and the start winding. The start winding's "polarity" with respect to the run winding is reversed by the timer switches (just below it in the diagram) depending on whether agitation or spin is needed. 9f39237.jpg
Dec 28, 2007 | Washing Machines
Heating & Cooling Logo
134 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
