Question about Garden
My gehl ct 5-16 telehandler sometimes wont go forward or in reverse
2 Suggested Answers
  • 4 Answers
SOURCE: shifter is erratic. wont start in park. drives forward when shifted to reverse, sometimes drives forward when in park. sometimes reverse is neutral (which is good so it will start!!!) what is going on
It sounds like the linkage at the transmission has come loose. Have someone get inside and move the shift lever from gear to gear so you can see where the linkage is on your transmission. You'll have to climb under ypou truck to see this, on the drivers side. check to see that all the bolts are tight. Your switch that allows you truck to start in Park or Neutral is located there.
Posted on Oct 25, 2012
Wont go in to reverse and sometimes wont go in to drive
ewprotest.org: SECOND TRANSMISSION ISSUE
newprotest.org/details.pl?1457
Dec 27, 2009 - This time around, the check-engine light came on, and while driving on the ..... my dodge caravan wont go in reverse and only a few feet forward tranny shot i will go ... I have a 1992 Dodge Grand Caravan 3.3L 4-speed xmission. ..... having shifting issues sometimes shifts fine other times I have to cut van off ...
No Reverse - The Chrysler Minivan Fan Club Forums
forum.chryslerminivan.net/showthread.php/19184-No-Reverse
Nov 21, 2010 - 10 posts - ‎1 author
BTW, I have driven it all summer, over 7k miles with no reverse; I just park up hill or in a drive-thru spot! ... 1992 S-10/4.3L V6/249K mi/original 4L60E ... I had a '90 Grand Caravan w/3.3 and same trans. rebuilt at 120k by AAMCO ... I've decided to drive it until the forward gears go out before I pay for a rebuild ...
10 Most Common Transmission Problems
www.transmissionrepaircostguide.com/10-common-transmission-proble...
Ever notice that while driving that the car hesitates or refuses to go into gear? ... that needs to be replaced, but may sometimes point to a more severe problem. ... If the carwill not shift after engaging the clutch and trying to move the stick, take a .... This is a problem because in park a dodge dose not run the the transmission ...
Transmission May Fail Causing Slipping in First or Reverse ...
repairpal.com > Problems > Dodge > Caravan
Jan 27, 2016 | 1992 Dodge Caravan
I have a cat telehandler 407 th, it sais on the computer i have a open curcuit on the front head lights & reverse alarm. How do i solve this.
Open circuit means a break in the circuit like a bulb blown or a broken wire bad earth , check all lights to see if all working and change bulbs etc from there
Mar 09, 2015 | Cars & Trucks
My shredder says it will shred cd's and dvd's but when I tried, a cd went in 1/2 way and now is stuck. Motor runs but nothing happens in forward or reverse
You can turn the shredder over (after unplugging the power cord) and see if you can pull the pieces out from under side.
Sometimes the motor gear teeth break off, and the motor just spins but wont go forward or reverse.
Hope this helps.
Feb 25, 2015 | Shredder Office Equipment & Supplies
How do you get to the starter on a gehl 6635
try this
http://tuffequipco.com/pdfs/Gehl%20Parts%20Manual/Gehl%20Engine%20Parts%20Manuals/Gehl%20Skid%20Loaders%20Parts%20Manuals/SL5635-SL6635-Skid-Loader-Parts-Manual-907844.pdf
Nov 03, 2014 | Computers & Internet
Shifter is erratic. wont start in park. drives forward when shifted to reverse, sometimes drives forward when in park. sometimes reverse is neutral (which is good so it will start!!!) what is going on???
Oct 25, 2012 | Dodge Ram Pickup 1500 Cars & Trucks
My 2001 chrysler neon wont reverse and sometimes wont go forward
I had this problem and it was the transmission was going bad. I am afraid you will need a transmission rebuild
Jun 12, 2017 | Chrysler Cars & Trucks
1985 toyota motor home. 4 cyl. 22re engine. goes slowly into reverse when transmission is cold, but when it warms up, it wont go into reverse. If I give it more gas, it will sometimes catch briefly, but...
Change the fluid and filter. If i remember correctly reverse and third gear share the same band and clutch pack. Some transmissions you could tighten the band on it.
Aug 04, 2017 | 1985 Toyota Pickup
Stuck in 4low on my 99 vitara wont come out
Have you tried trying to get it out of 4wd whilst reversing?Sometimes you get a thing called "wind-up".Its when you go forward and the driveline gets tight due to a number of reasons.Sometimes it is fixed by going in reverse while you get it back into 2wd.Not all cars and models,but I hope it helps you.
Sep 21, 2010 | Suzuki Vitara Cars & Trucks
Peg perego gator wont work in forward but works in reverse
I would replace the high low switch for this peg perego gator.
The high low switch as seen here http://www.shopjandl.com/mepu0002.html will not allow it to go forward. The reverse switch will sometimes not work at all as well.
You can contact http://www.shopjandl.com/. They repair them and know how to figure out what is wrong.
I would also check the wiring on the motors. Sometimes the wiring comes loose and doesn't allow all the speeds to function properly.
hope this helps
Mar 24, 2009 | Peg Perego John Deere Gator HPX Ride on...
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
