Question about Pioneer PRO-99 TV
Wont power on
My tv won't power on. It started making a whinning noise coming from the tranformer and now when you hit the power but it tries to turn on the light goes green and then back to red. I would like to know if there are any service manuals online and if it is the transformer, can I change that myself. thanks
  • Anonymous May 04, 2008
    Will not power on
    Genius:
  • 1,694 Answers
See Speargunner Oct.26,2007.........................T.
Posted on Nov 15, 2007
SOURCE:
1996 manual jetta won't start. It won't even crank. There is a whinning noise when I turn the key from the engine but that's it.
Sounds like the starter drive is not fully engaging with the fly wheel... might try to tap firmly on the body of the starter while you turn the key but be careful not to hit the wires... Might get you going enough to get to a garage and have it checked. good luck!
Jul 20, 2011 | 1996 Volkswagen Jetta
When I turn it on, it makes a buzzy noise but nothing else., no picture or tv sound.
The set has a high voltage problem, "the flyack transformer is defective" It generates the high voltage in the picture tube and with the help of the video circuits it produces a picture. It is not cost effective to repair the tv, cheaper to replace.
Jan 30, 2011 | RCA 27V530T 27" TV
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Rubbing/grinding noise
Usually the strut bearing will make this noise upon turning a corner and hitting a rut or pot hole when turning. A wheel bearing will make a low pitched whinning sound constantly
Jan 16, 2010 | 1998 Ford Ranger SuperCab
I have a 1998 GMC Jimmy. Cranks, but won`t start. Fuel is full. Engine stopped while driving. Battery light came on. Any suggestions?
the battery indicator light usually comes on after a lose of power. Sounds to me like either bad gas, clogged fuel filter or a bad fuel pump. Easiest way to check this is have someone turn the key while you stand at rear side of vehicle and listen for the whinning noise a functioning fuel pump makes as it pressurizes the system.
P.S you dont have to start vehicle to check pump. only requires turning the key to the on position. Good Luck
Dec 07, 2009 | 1998 GMC Jimmy
High pitched sound comes from tv ---no controls on tv work--you have to unplug it to get the high pitch to go away
Is this a tube tv?IF it is the Flyback tranformer have a little still bar tranformer hight current volt make that noise take off the tv cover put some glue on the little steal bar should stop the noise or lower it very good.
Aug 12, 2009 | Televison & Video
Whinning noise from front of vehicle
check your idler, and tensioner pully's, i've seen a few trailblazers that whine and it turns out to be an idler pully, also check the power steering fluid and make sure its full in accordance with your owners manual
Jul 30, 2009 | 2005 Chevrolet TrailBlazer
Picture wont come on, makes noise like it is on, but no go
when u plug the set in does it make a whinning noise or a poping noise. this might be a lamp or a color wheel stalled.
Jun 16, 2009 | Samsung HL-R4667W Rear Projection...
Loud whinning noise then no picture or sound
Color wheel is the noise you are hearing. It can also keep the lamp from firing up if it has seized up. Remove the lamp and inspect it. Replace the color wheel for sure.
Jan 10, 2009 | Samsung HL-R5678W 56" Television
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
83 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
